Question about Symbol AP-2411-5AZL-01 Network Adapter
Timing out I have two Spectrum 24 AP-2411 access points in my warehouse that talk to Symbol RF bar code readers models 3840s and 6840s. I use the pre-802.11 'spring' protocol and this set up has worked very well for years. Since Febuary 2007 I have been having 'timed out' issues on the warehouse floor. After logging into the reader the user does their job and places the reader down. After a small time frame, 5 minuets or so, the user goes to the reader again and the unit will not connect to the 2411 access point. The unit will time out and the two ways to reconnect are to, 1.) reboot the unit (reader) or 2.) wait an undetermined amount of time. (20 min.+, the readers will connect eventually, but most of the time the just log off) I use a static IP address in all my bar code readers and the two access points. I have timed the response from reader to access point and have seen the time to live go over 2000ms. I have been trying to swap different access points in (I have back ups and another warehouse where this problem is not happening) but nothing has worked yet. Again the problem is when a reader goes idle. If the gun is logged off it will connect with no problem. The problem has even happened while the user was in the middle of a transaction. For no good reason, the reader will lose connection with the access point, but this is very rare. If anyone has ever dealt with trouble like this I could sure use a helping word. Thank you, Brian Silcock
    Scholar:
  • 132 Answers
Hi, the units I dealt with were in a restaurant environment to their loading dock. Somewhat similar situation. During the day it would cut out whenever, or not connect at all between 11 and 2. After a LOT of investigation, came to find they installed a new microwave in the kitchen area. When they were using this unit the signal for the wireless was being interfered with and it was really busy between 11 and 2. The solution was to move the microwave. Have you installed ANYTHING new? microwave, radio, phones, intercoms, TV?Did a neighbor put something in?to test just unplug and see what signals you get. And just to let you know, when you start your unit, you get a fully function connection, when it sits idle sometimes it will drop to half duplex. Didn't figure that part out.
Posted on Oct 04, 2007
This AP is in network x.x.102.0, which has it's own DHCP server. Only lan-port and WLAN are used on AP. I need this AP not to have it's own ip-adress, but devices, that connect to it,using WLAN,...
Ideally, there shouldn't be any configuration needed. Access points are transparent and only work as a bridge between wireless and wired network so devices should obtain their IP info from your DHCP server not the access point by default.
If you face problems, then there might be a DHCP server in the access point, disable that.
good luck
Othman
May 20, 2011 | Symbol AP-5131
I have 5 scanners and 3 access points in my warehouse and the scanners only stay connected when I only have one access point turned on and the scanners set to connect to that access point (Mandatory), then...
Hi, that is happening because your 3 APs have the same fixed IP address. you have to change the ip address on 2 APs, right now it seems to be that your 3 APs have the same fixed IP address, for example in my warehouse, for AP #1 is 10.20.40.30, for AP #2 is 10.20.40.31 and for AP# is 10.20.40.32 hope it helps!!
Dec 06, 2010 | Symbol MC9090 Barcode Scanner
I need user manual of Symbol Spectrum24 4131 Access Point 802.11b
Hello minhaj,
You can download the structure manual of Sympol Spectrum 24 4131 by Clicking Here
Thank you for using FixYa.
Apr 12, 2009 | Symbol Spectrum24 4131 Access Point...
We have an industrial setting. We're using RF devices, scanners on lift trucks that move through our warehouse. We are losing connection when the device gets out of range of one access point and tries to...
Plz check for 3 things:
1. All of your AP should given access to roaming devices, for this all of your AP are should connected with each other.
2. WiFi chennal for your device should be same for all AP.
3. Configure 802.11b or 11Mbps speed on devices.
Plz revert in case
Thanks for contacting Fixya
Mar 23, 2009 | 3Com Wireless LAN Managed Access Point...
Does the Symbol AP 3021 Access Point accept WPA encryption?
on the info i could find it only supports WEP.
but if your issue is to be more secure look up if it supports a sort of mac filter.
this will only keep everybody out of your router but your signal will only be WEP encrypted.
Feb 09, 2009 | Symbol Spectrum24 AP 3021 802.11b
RF GUN
IS this connected through a Keyboard Wedge or USB or 2385 Serial port
PLEASE I need to know
Aug 30, 2008 | Symbol MC9090-G RFID Handheld Barcode...
Reset to default a symbol spectrum24 ap-3021
On the Symbol Spectrum24 AP-3021 and what looks like all of the Spectrum24 AP models. There is not a reset button. We only have the RS-232 serial port to work with.
Start with the power off.
Short pin 2 and pin 3 together.
Plug in the power.
Wait 15 secs.
After the two network lights become solid.
Remove whatever you used to short pins 2 and 3.
(make sure to only jumper pins 2 and 3 - if you ground against the outer shield it will not work)
Cycle the power on the unit.
The password is Symbol and it is case sensitive.
Apr 09, 2008 | Symbol Spectrum24 4131 Access Point...
Problems with Symbol 5100 switches
Call tech support! That's why these people get paid. Sites like this wouldn't need to exist if they did their jobs correctly!
Mar 11, 2008 | Symbol WS 5100 6-Port Gigabit Wireless LAN...
Manual
Is this a bar code scanner?
If not what piece of equipment is it.
Jan 18, 2008 | Symbol AP-2411-5AZL-01 Network Adapter
Symbol AP-2411-5AZL-01 Network Adapter Logo
189 people viewed this question
Top Symbol Computers & Internet Experts
 Brian
Brian
George Etukudo
George Etukudo
Norman Al-Anbar
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
