SOURCE: My Miele 1374 washing machine
heres your problem..
3.33 Fault code F63, water path control unit
In normal operation mode the display shows Technical fault.
The Check inlet LED flashes rapidly.
The programme is interrupted. The drain pump is activated for 120 s.
Cause
Water path control system faulty.
The power-programme module (ELP) cannot register a valid position of the water path control unit within approx. 80 s of it being switched on.
Note:
Water intake monitoring is not active if a valid position of the water path control unit cannot be registered.
Remedy
Check the water path control system.
Check the water path control system circuit for an open or short circuit, and correct insulation.
