SENDS FAX BUT CAN'T RECEIVE AND COPY
I HAD TO CLEAN PAPER AFTER IT GOT CLOGGED
    Champion:
  • 320 Answers
You still have paper stuck in the machine
Posted on Jan 20, 2009
SHARP UX-A1000 - sends all BLACK page (to all
Noisy line? is all that strikes true when you ensure me it makes great photocopys, but then you receive OK, very strange, All the mechanisms for doing a local copy is the same as sending a fax the difference is the conversion to phone noise so it has to be electronic, I;d guess lightning/power surge, cant think of much else....sorry
Nov 04, 2009 | Sharp UX 510 Plain Paper Thermal transfer...
My Panasonic kx-fhd351 won't feed paper to receive a fax.I assume I need to clean something, but I am not sure what and how.
Does this model also act a copier? If so does it make a copy? If so mite be fax issue. Use alchol to clean rollers, remove draw and clean them.
Aug 15, 2009 | Panasonic KX-FHD351 Plain Paper Thermal...
Can receive a fax but when sending a fax it sends a black sheet
YOUR SCANNER LED LAMP IS DEFECTIVE. IF ITS NOT UNDER WARRANTY YOU SHOULD JUST PURCHASE ANOTHER FAX
Aug 04, 2009 | Brother IntelliFAX 775 Plain Paper Thermal...
My brother fax machine - only receives black pages
do a quick check on 2 things.
- Copy a document(put a printed page on document feeder and press Copy button) , has the Copy come ok? if copy is also blank that means toner/ink problem, needs to be replaced.
- check with your Fax receive Print settings. is any setting of econo mode/ contrast/brightness Off the track? If found any of such issue then Reset it or put it on average (middle).
Hope this will put your Brother on the track
Jul 14, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
Machine sends fine. Machine does not receive readable copy.
Is this connected to a computer? if so you can run head cleaning utility from the print driver properties. This will pump ink to the head and flush out the clogs. That is the easist way to make sure you don't have a head problem. If it is not connect to the PC then scroll thru the menu to see if there is a maintanence section and look for head cleaning.
Hope this Helps
TankMurdock
Apr 24, 2009 | HP 920 Plain Paper Fax
Not receiving faxes
Folio is not what you want. The usual is letter (LTR) or 8.5 x 11. You may have to check the settings to set the default paper size.
Jan 14, 2009 | Canon PC-1080F Plain Paper Laser Fax
Copying and fax sending problem
  1. Just check & clean the dust in the original feeding area.
  2. if not solved, clean the Document feed sensor or replace the same. But for this you need to open the body of the fax machine.
Mar 11, 2008 | Canon FAX-B820 Plain Paper Bubblejet
Receive a black copy
scanner problem. if you receive faxes that are good. the scanner is used when you copy or send. Lawrence
Feb 26, 2008 | Panasonic Panafax UF-490 Plain Paper Laser...
Paper failure
If you can see the black rubber feed rollers, clean with isopropyl alcohol
Oct 24, 2007 | HP 920 Plain Paper Fax
jasbo
jasbo
