Question about Panasonic CT-36SX31 36" TV
Sony trinitron flickering
Takes a long time to warm up. once warm, keeps flickering from completely black to picture and back again When you turned it on, it took a long time to warm up, then you got a picture. Eventually the picture started flickering, and finally the fuse would blow.
Any ideas what the problem is, and how to fix it?
andersonkwans@hotmail.com
    Sergeant:
  • 378 Answers
It sometimes happens if the unit is getting over current from the power outlet where the unit is connected.change the socket where the wire is connected try checking in any other socket.as the fuse is getting blowned up this is also the issue of short circuit in the  main pcb board,the fuse gets blowned up to save any major damage going to occur to the board and also there is something short in the board .just get it checked properly.as this issues are very risky and dangerous to do it manually without any proper tools and parts.
Posted on Jan 05, 2009
    President:
  • 1,990 Answers
What your describing sounds like two differant problems OR the power supply is causing these two problems .. One would of course be the tuner and the other would be the vertical circuit .. Your going to need to seek out a profesional if you havent a clue about solid state electronicsand A tv is not a place to experiment! Good Luck
    Sergeant:
    Novelist:
  • 326 Answers
Its the problem of overheating on the main board that causes this problem of fuse blowing.the capacitors and ic on the main board needs to be checked with a meter to locate the faulty.
I have a Sony Trinitron 32" tv. When I turn it on, it has started taking longer and longer for the picture to come on. Sound is fine. Now once the tv is on for a while, the picture goes black for...
Yes.... u must adjust the screen voltage going to picture tube....located on the CRT module>>>little board connected directly to picture tube (take back off TV and you will see ) play around with screen control on the CRT module......can be adjusted at times to keep from losing picture!!! tube is bad...i know sure looks good when showing a picture....TRY adjusting screen voltage ( YES while TV is ON>>>CAREFULL ) gl
May 19, 2010 | Sony FD Trinitron WEGA KV-32FS100 32" TV
I have power but it will not turn on. unplugged from power cord overnight then plugged into wall worked fine until i shut it off again, now it keeps blinking the delay light
go to turn tv on,hear a poping noise,once then tv standby lite blinks 3 times repeatily but no picture or audio.can you help me out with this thank you
Feb 14, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
TV switch light flickers 11 times but no function
Hopefully it is only a board component that needs replacing and your dry joints that need re-doing. I would advise that you take it to a television repair shop as this type of repair can be very complex (replacing resistors and capacitors just to name a few).
Dec 03, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony Trinitron Colour TV Stopped showing and switch light flicker
The vertical output IC has failed/Power to the vertical IC is out/ or there is bad solder on the pins of the vertical output IC.
Dec 01, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony Trinitron it 36 fiickering
Sep 13, 2008 | Televison & Video
Screen flickers upon power up
Looks like your picture tube is dying, or there is a bust capacitor(s) inside...I'd recommend taking it to a service shop to get it repaired.
Cheers!
IrishDruid
Jan 08, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony kv36fs76u
hi there, your set has a capacitor problem, most of it are on the horizontal section and video section., usually 100 microfarad electrolytic capacitor with a high voltage is damage. try to test some parts. ty
Dec 02, 2007 | Sony FD Trinitron WEGA KV-36FS120 36" TV
TV sometimes flickers to black
just check ur tv settings,with user manuals,check close caption it must be turn off,check antenna or catv lead for loose connection. i hope i help u?
May 07, 2007 | Sony FD Trinitron KD-34XBR960 34" TV
Picture takes hours to appear
Spounds like the b+ feed filter capacitor off the flyback that supplys voltage to the three drive transistors on the crt board is bad.
Apr 16, 2006 | Sony KV-32V16 TV
Panasonic CT-36SX31 36" TV Logo
51 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
