Question about Maytag Washing Machines
Having problem with Maytag LA506. It seems if the load is to large I can smell something like a belt maybe sliping . (Like a car) Can't find the maunal so guess I'll try it myself. If anyo
Series 10 SN 201901 XP I think its older than I am and I ain't no spring chicken
SOURCE: maytag spinning loud noise
bearings are bad need to replace
Posted on Mar 14, 2007
  • 1462 Answers
SOURCE: Maytag stactable wash/dryer LSE7806Ace
probably the rear bearing
Posted on Oct 02, 2008
  • 79 Answers
SOURCE: A burning smell while Maytag neptune was washing.
Shut down and unplug machine a.s.a.p.! It could be your door latch wax motor failing which will burn the R11 (resistor) and Q6 (triac) on the machine control board. You did not mention which Neptune you had... If it is a MAH3000, MAH4000, MAH5500A or a 2000 stacker and you have not replaced the door latch wax motor (12002535) then your time is up. See www.neptunewaxmotor.com for details for the repair kit or you can purchase a new control board and 12002535 wax motor and be up running quickly before the clothes pile get too high.
It could be the seal and/or bearings if the machine is starting to get loud in the high speed spin cycle. If so, See www.neptunebearing.com for the seal and bearing kit plus they offer a special Neptune bearing tool for rent called the tony tool. A Maytag technician will want to charge you $900 to replace the whole outer tub? Why replace it when just the bearings and seal kit need changed?
Posted on Dec 10, 2008
SOURCE: Maytag Washer Stopped Working
I was about to order a new lid switch assembly, but I decided to try one more thing. I disconnected the wires from the check switch and cleaned the connections - there was a layer of oxidation. The machine started right up after I reconnected the wires and plugged it back in.
Posted on Dec 18, 2008
  • 1937 Answers
SOURCE: Kenmore series 90 washing machine clunking and burning smell
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.26902691
See the section on the Machine Base.
There are a number of balance springs and vibration pads that help keep the tub from vibrating and going out of balance.
It's possible that one or more of these is broken, loose or damaged.
Following is a description of how to remove the cabinet to get access to them.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=135
Also see the Whirlpool Service Manual for their direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
For the vibration, I'd check the springs and vibration pads.
While you have the cabinet off, I'd pull the pump and motor and check the Motor Coupler. This could be the cause of the "burning smell"
Posted on Nov 22, 2009
The bearings have been replaced but now it is smoking (mostly seems from the inside) and smells like the belt is burning, but the belt isn't hot. HELP!! :)
i think this washer has a heater with doing the bearing probably wires crosed over or damaged [heater goes on and no water smokes then ] ceck your wiring on the element green is ground.
Jan 22, 2013 | Maytag Neptune MAH5500B Front Load Washer
I have a Maytag MAV6300AWQ top load washer that is making a LOUD noise during ALL cycles. We lifted it up in front and looked underneath; the belts look okay; the large one had some slack in it; maybe...
If the belts are old they will allow the motor too much outward room, so that the motor shaft can rub against the bottom of the machine. Also make sure the motor rollers are not cracked, which they have a tendency to do.
May 08, 2011 | Maytag Washing Machines
Maytag washer model # MAVT236AWW Ser # 11354800GV This thing will not wash or drain or spin. It will fill up with water. I have smelled a burning smell and smoke filled the back room. To me it has...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 20, 2011 | Maytag Washing Machines
My Maytag Top Load Washer was in the beginning of the wash cycle with a large comforter when it began squealing, sounded like from a belt within the machine. I smelled a burning smell and stopped the...
The belt has been ruined. Basically there was to much load on the belt. You will need to replace the belt, maybe a 20 dollar fix and should take no longer then 15 minutes. Just make sure that before you go to the parts house, your remove the old belt and take it with you along with the model and serial number of the machine.
Please rate.
May 05, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Maytag washer MAV208DAWW does not spin out the water completely from clothes after spin cycle.
do you smell anything burning or a burning oder,your belt could be glazed from over loading the washer and now the belt is slipping,also check the drain hose for kinks making for a slow drain,do you hear any noises when draining like something could be stuck in the pump, maybe to much detergent and it's oversudsing, or you could have a bad trainy,check the belt first belt part number is 21352320 and it's around 25 bucks
Feb 26, 2010 | Maytag Washing Machines
Burning smell when my Maytag top load washing machine is running
Sounds like the belt is sliping. ether it's loose, or the trans needs lubed, or both.
Jan 14, 2009 | Maytag SAV5710 Top Load Washer
Fills with water, agitates, won't drain
how to replace the Maytag belt at this location
http://www.repair-help.com/kb/index.php?article=187
Diagrams and belt orders here http://www.pcappliancerepair.com/model-display.php
Dec 05, 2008 | Maytag Atlantis MAV6451 Top Load Washer
New maytag washer
hi there,
since your washer is under warranty, have a tech take a look at it.
sounds like you may have a loose belt.
is there an error message on the display?
Sep 10, 2008 | Maytag Neptune MAH5500B Front Load Washer
WASHER STARTS MAKING LOUD NOISES WHEN SPINNING SOUNDS LIKE IT IS OFF BALANCE BUT NOT. ALSO FAINT SMELL OF BURNT RUBBER.
The washing machine will do this if the load is unbalanced. Usually due to either an excessively heavy and/or large load. The burning rubber smell is just the drive belt dealing with the imbalance. Often the washing machine will self-balance itself, but it's a good idea to open the lid and re-distribute the load. Or remove some stuff if it seems too heavy.
Sep 06, 2008 | Maytag Washing Machines
Burning Smell when spinning
8 yrs old....The LATs were the best models for Maytag...Maybe it's time to replace the belt..Slipping belts smell bad.
Jun 09, 2008 | Maytag Dependable Care LAT9416
Washing Machines Logo
26 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
