Question about Technics SA-EX400 Receiver
Technics sa-ex400 av control stereo receiver no output
Plugged in it appears to have power, the help/reset button is lit up but there is no output
SOURCE: need a new power cord....misplaced mine...
i did the same thing. replacement at radio shack.
Posted on Mar 29, 2009
VOTIT
  • 2071 Answers
SOURCE: How do I conect my ipod to the Technics AV control
You just connect it in the auxilliary input then switch your reciever to auxilliary so you can the sound of your ipod. First buy a wire connector from ipod to reciever.
Hope it may helps;
Regards:
VOTIT
Posted on Jun 17, 2009
Sparky2012
  • 102 Answers
SOURCE: My Technics AV Control Receiver SA AX530 is in overload
An amplifier should never be turn on without speakers, it will overload internally.
make sure speakers work and try again.
Posted on Dec 04, 2009
SOURCE: volume control blew out
i hade the same problem with the same unit and fixed it my self.
turns out the chip that is screwed to the heat sink was blown, and the resister that controles the fan burnt as well.all i did is ,get a datasheet of the unit and toke if apart went to the parts store and bought what was needed. the chip that is screwed to the heat sink has a part number on it whitch if you cant find the same can be switched with equivilant chip (find a datasheet of chip).
then my fan would not run ,i notesed that the risister was shot , the resister is color code witch means the resisters values. its a prety big job since the reciever has to be almost completely taken apart but very worth while .its ben workin like new for about 4 years since the repair with no problems or isues. hope this helps ad good luke.
Posted on Oct 28, 2010
dunnbiker
  • 8546 Answers
SOURCE: I have a Technics AV control stereo receiver
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Posted on Jan 28, 2011
HOW CAN I CONNECT A MIXER TO A TECHNICS SA-DX940 AV
I used the manual downloaded from http://www.manuals365.com/technics/sadx940.html
Try using the final stereo output of the mixer as the input to the CD or Tape or VCR inputs.and use the switches on the fromt of the DX940 as necessary.
The specificatios state input sensitivity is 27 mY so your mixer needs a low output..
No reason it shouldn't work.
Sep 18, 2014 | Technics SA-DX940
Connect laptop to technics av sa-ex400 reciever
you will have to buy an 1/8" stereo jack to rca plug....insert the headphone jack into the headphone out of laptop and plug in to any input of choice in the back of the receiver (i.e. aux, video in, cd)...play some music or whatever on laptop and turn your reciever to that input....
Jun 22, 2013 | Audio Players & Recorders
Technics sa ex400 help reset light staying on
I to have a Technics SA-EX400 Receiver, The reset light stays lit also, I assumed it is normal. When I push it, it says operating normaly...
Jan 04, 2012 | Technics SA-EX400 Receiver
Dec 04, 2009 | Technics SA-AX530 Receiver
How do I connect to computer for music?
Please clarrify? Do you want to connect your computer to a amplifier and play music from your computer through the amplifier? If that is the case, you will need to get yourself a cable from your local sound shop. Ask for a "Stereo to RCA" cable. Plug the stereo jack into the back of your computer (where you would normally plug in your desktop speakers) and plug the RCA cables into one of your open channels on your amp. And there you go
Aug 01, 2009 | Technics SA-EX400 Receiver
Dish Network Box, Technics Receiver, RCA LCD TV connections
I would use the s-video out & red & white rca audio out on dish box to s- video & audio in on the t.v., then audio out from t.v.(RCA, red & white) to one of the inputs (RCA) on the receiver.
May 25, 2009 | Technics SA-EX400 Receiver
Need a new power cord....misplaced mine...
Jan 17, 2009 | Technics SA-EX140 Receiver
Probleme with my home theatre...technics..av control stereo receiver- model SA-G76
just an idea maybe check the position of speaker select switch some models have
a or b
or a+b
Apr 24, 2008 | Audio Players & Recorders
Open Questions:
See all Technics SA-EX400 Receiver Questions
56 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
