Question about Apple iMac Computers & Internet
How to remove foreign object in iMac cd player
    Genius:
  • 1,689 Answers
You have to take the unit apart and dump out the object. With most of these devices, the access screws are located under rubber pads, or under a label. These devices are not designed for servicing. I have seen some completely sealed and not accessible for unassembled.
Posted on Nov 08, 2012
How do I fix the recording door from constantly opening and closing?
hola
cambia la correa de la bandeja y funcionara, eso pasa por que no tiene fuerza para cerrar el mecanismo.
suerte
Feb 06, 2015 | Philips CDR775 2-Disc CD Recorder
General error L200, what is solution? I try to turn off and switch again...It Error again..
Delete all print jobs and turn the printer off. Remove any foreign objects from inside the printer. After a few minutes, turn the printer back on. but not working printer.
Sep 30, 2012 | Epson L200 Original Continuous Ink Tank...
CD player turns on but code F61 come on and it turn off automatically. I was wondering if anyone has a fix?
Not sure if this CD Player you speak of is a Panasonic or not but I would first try using a CD cleaner disc in the unit as this code could be a protection code from damage to the unit, indicating a foreign object in the unit also make sure the unit is dry as a small amount of moisture in the right spot on some units can cause this code. If this does not fix the problem I am sure you will need to have it looked at by a certified Technician.
Be sure all inserted disc's are dry and clear of foreign debri.
Thumbs up if helpful!!!
Jun 19, 2011 | Panasonic Vacuums
A dvd is stuck in the drive. It resists all attempts at removal including the ''eject cd'' command in Open Firmware. Can I manually remove it?
The iMac (Slot loading) computer's disc eject mechanism is electrical instead of mechanical. To eject a CD-ROM disc at startup that contains system software, press the mouse button until the computer ejects the disc. If the disc does not contain system software, wait for the iMac to start up and drag the disc icon to the Trash.
If either of these steps fails to eject the disc, push the drive's manual eject button with a small, blunt object like a paper clip. This button is located to the right of the CD/DVD slot as shown in Figure 1. The computer must be turned on to eject a disc in this manner.
ht3007_1.gifFigure 1 Manual eject button
Once the disc is ejected, it extends just beyond its center hole so you can remove it from the drive. If the disc fails to eject, while holding in the paper clip, use another CD to gently push against the inserted CD. This gentle pressure may help to release the inserted CD.
Important: After ejecting the disc with the manual eject button, you must restart the iMac in order for the CD-ROM or DVD-ROM drive to work.
DONT FORGET TO VOTE
Oct 10, 2009 | Apple iMac G4 Desktop
My cdj1000mk3 just started to act up, i would load up a cd and it would play but sound like it is getting scratched inside the cdplayer, 20 seconds onto the cd, the cd player spits out the cd and the cd on...
I've repaired similar faults in the past and the problem has been foreign objects stuck inside the mechanism - usually pieces of paper / labels that have come off CD's.
Moral of the story - write on your CDr's with a marker pen, DON'T put on sticky labels.
http://www.technicsdjuk.com/
Aug 06, 2009 | Pioneer CDJ-1000 CD Player
CD/DVD drive will not accept any disk I try to put in it.
Do you have any small children in your house?
Seriously, I have 6 children. One (or two) of them put a quarter and two flat washers in my slot load CD drive. Took me over an hour to take it apart to fish them out.
I've also had a friend whose young children managed to get 2 cds into the slot load at the same time.
So, my primary suspect is a foreign object has gotten into the drive. I've never had a CD/DVD drive fail on an iMac other than that.
However, if it is a foreign object, you will need to take it in for repair, most likely. It is difficult to see in there. and even more difficult to grab the object.
I suppose that the cable could have become disconnected. I really doubt that the drive was a lemon, seeing that it worked for a year.
Apr 05, 2009 | Apple Mac OS X 10.4
Help!!
take out and take top off and look down in it and see if there is a foreign object inside maybe broken disc or paper, remove and clean eye put back together.
Mar 03, 2008 | Pioneer DEH-1600 CD Player
Rotel cd player Rotel 1070 cd player
Well I fixed the problem myself by taking yhe cover off and cleaning the laser with a cue tip and alchohol very gently of course. I guess it was not reading the disc the first time it closed because some foreign object , works fine now
Mar 03, 2008 | Audio Players & Recorders
Player displays -UI-
According to the manual: U1= "The disc may not be loaded properly in the rack." Countermeasures: Reload disc Check for foreign object on disc Check for foreign object on rack
Apr 07, 2007 | Pioneer PD-F1007 301-Disc CD Changer
Computers & Internet Logo
147 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
