Question about Ariston Technologies Washing Machines
Ariston A1637 lights flashing on delay timing and rapid buttons
SOURCE: Ariston A1637 Washing Machine
how to open bolts
Posted on Apr 20, 2008
SOURCE: ON/OFF & Time saver Button keeps flashing
For mine, it started flashing the on/off light along with the "drying high heat" and the "reduce crease".
Unplugging the unit for 30 minutes appears to have reset the machine and it is now working.
Posted on Sep 01, 2008
SOURCE: ariston a1600wd not working
There is a filter of sorts in the pump inlet pipe, its a big item catcher coins etc, but thats got nothing to do with the module error wich is a pricey item at £120! I've had one go already and in the last year, a inlet valve plus a control pcb panel in fact its almost a NEW machine! i'll never buy another hotpoint or ariston again. The machine is two yrs old!
Posted on Apr 29, 2009
  • 123 Answers
SOURCE: Dishwasher, Ariston LI62, kept flashing on R
hi there.....this usually happens when the base of the machine is full of water.....switch the machine off ....remove the two plactic inspection panels at the bottom of the machine and dry out the base....check that all fittings and fixtures in the main cabinet are secure and not leaking..particularly the transfer tube from the wash pump to the upper spray arm..(machine needs to be pulled out of its position to check this as it is at the rear)
regards Sir Galahad
Posted on Aug 18, 2009
SOURCE: Fault with Ariston Washer/Dryer
Make sure the filter is clean, its behind the front bottom panel which just pull off, then unscrew the filter thumb wheel until it comes out. Check it is clean and replace, Now unplug the machine and set the programme to your normal start setting leaving the door open. Remove the screws retaining the back panel and unplug all the connectors to the circuit board found in the bottom left hand corner. Turn the power back on ensuring the red LED illuminates and leave for 2 or 3 minutes before unplugging the power again and reconnecting the circuit boards and replacing the back panel. Reconnect the power and turn the machine on, close the door and with luck it will work. If this does not clear the fault repeat the process again or look on ebay for a new machine!
Posted on Apr 22, 2010
I have an ariston ll64 and it is stopping a the last cycle button which is the picture of wine glasses. It then flashes with a green light.any ideas?
Error messages:
Your dishwasher is equipped with a safety system which is able to detect any operating anomalies. These anomalies are reported by one or two wash cycle indicator lights "E" flashing rapidly.
24432725-0h3kxpflbez5mdeb5anq3st4-3-0.jpgFlashing Led diode below button with the image of wine glasses means faulty thermistor NTC. So, could be faulty: thermistor NTC (defective or not positioned), wiring, control board.
Dado
May 16, 2014 | Ariston Technologies LL64WNA Built-in...
How to repair - no water is entering the dish waterr
Your dishwasher is equipped with a safety system which is able to detect any operating problems. These anomalies are reported by
one or two wash cycle indicator lights "E" will flash rapidly.
Any flashing combination of LED diodes (Intensive wash, Regular wash, Eco wash, Rapid wash, Soak and Crystal care) means different error code. Take a note of which lights are flashing?
If you have problem with fill water than following two LED should be flashing.24428775-0h3kxpflbez5mdeb5anq3st4-3-0.jpg
In this case could be:
  • Water valve disabled
  • Turbine disabled
  • Control board faulty
Dado
May 15, 2014 | Ariston Technologies LL65 Built-in...
Ariston avxl 140
Check that you don't overload the machine. This can happen if the load is too heavy.
Jan 31, 2014 | Washing Machines
Ariston A1637 delay wash and key lock flashing won't complete a cycle
Most likely the problem is a clogged or jammed drain pump impeller. First shut off power to the washer by unplugging it or turning off the breaker. Then remove the screen in the bottom of the washer,clean it out reinstall then run washer
Jul 28, 2013 | Washing Machines
Garage door programming doesn't work
try resetting the homelink system by holding down the first and last buttons at the same time until the light flashes rapidly on your visor. this could take up to a min. then at the same time press whichever button you want to program on the visor and the garage door remote button at the same time until the light on the visor flashes rapidly.that could take up to a min. after that is complete you need to go and push the learn code button on the back of the openers unit, then go and push and hold the button on the visor you just programmed until you hear a click or you see the light flash on your opener unit. after that try using your homelink. note there is about a 3 second delay when using homelink. you need to push and hold the button until you see the door operate.
Sep 10, 2012 | 2007 Mercury Grand Marquis LS
The On-Off door lock LED flashes rapidly at the same time with Delay, Timer and Rapid LED. and it wont start.
Many times faults like this can be cured by Uplugging the washer from the mains power supply and leaving for 10mins. Also check all filters, drain and supply lines are clear and not kinked.
May 04, 2011 | Ariston Technologies AW129NA 16 Lbs Front...
Ariston L64 dishwasher first 2 lights flashing what does this mean please!
Ariston LI6401-Washed a load. Last light on R control panel (Eco Wash) is blinking rapidly and didn't dry the dished.Turned pwer off then on. Did same type of wash. New maching-This is about the 6th wash
Mar 16, 2011 | Ariston Technologies LI640S Dishwasher
I have an Ariston LL65 and the eco and rapid light are flashing
I have the same issue, so Dish-washer Ariston LL65 with Eco and Rapid light flashing. Can you help me to undestand the issue and solve it ? thank you, Regards.
Sep 01, 2009 | Ariston Technologies LL65 Built-in...
Ariston a1400wd washer dryer will not start and delayed timer, rapid and on off lights continiously flash. checked pump and nothing appears to be affecting it.
Bolody thing will not tumble dry, it goes through the motions but the washing still comes out wet after 3 hrs, have tried continuosly but same result - certainly wont be buying another one of these pieces of junk
Sep 07, 2008 | Washing Machines
Washing Machines Logo
110 people viewed this question
Top Ariston Technologies Washing Machines Experts
Darren Moxam
Darren Moxam
Gerry Harvey
Gerry Harvey
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
