Question about Refrigerators
Knocking sound in Whirlpool Conquest
There is an intermittent knowcking sound in our Whirlpool Conquest Side by Side Refrigerator. Any ideas?
SOURCE: whirlpool side by side water dispenser not working
I had the same problem and it appear the cable set between the freezer door and refrigerator body has some wires broken. The cable is in the bottom right hinge. You can try moving the cable with fingers at the same time you're pushing the water lever.
While this is not going to be a permanent fix, at least it confirm where the problem is.
Posted on Nov 28, 2007
  • 262 Answers
SOURCE: Ticking noise
this is the motherboard part number 2252189 it is getting ready to go out but before you replace motherboard make sure the unit is grounded a bad ground can also make the same problem happen
check ground at wall and all green wires on or around compressor and door hinges
Posted on Dec 07, 2007
SOURCE: whirlpool conquest 2001 GS6SHAXKQ01 refrigerator side by side top part is not cooling
Don't let them tell you that the problem is related to "sulfur" in your water. It's a scam so that they don't have to repair the problem. The actual problem is that they don't use quality parts to build these units anylonger.
Posted on Jun 28, 2008
ghappliances
  • 126 Answers
SOURCE: Whirlpool gold Conquest side by side refrigerator-- water dispenser doesn't work but ice dispenser does.
WHAT IS THE PROBLEM WITH YOUR FRIDGE
MOHAMED
Posted on Sep 20, 2008
freetek
  • 5568 Answers
SOURCE: knocking noise coming from Whirlpool Gold refrigerator
The compressor is normally mounted in sound-dampening rubber shock mounts and it sounds as if one or more of these have decayed on your fridge.
Accessing the compressor from the back, you might try (gently) to rock the compressor to see if you can duplicate the noise you are hearing.
Posted on Dec 15, 2008
The whole unit is making an irritating clicking noise,like a stopwatch.Not continuously but intermittently,sometimes into the night. Very very irritating.
Dear I want to service for my whirl pool refregerator in mohali
please send me contact no of whril pool refrigerator
Regards
S.K.JHA09855475624
Mar 26, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool gold refridgerator light not working and is making funny noise
switch of your refrigerator then try replacing the light that doesn't work then try to switch it back on. the light might be the cause of the noise. it might be grounded. replacing the light might reduce the noise then observed the noise for a week then if it still making noise that's the time for you to get a technician that could fix your refrigerator.hope it helped... send us a message for more concerns thank you...
Jun 03, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Knocking Noise from the front, suspect the gearbox
If you know what you doing crack it open if not remove and get second hand box heaps cheaper.
It maybe somthing in the clutch either way you have to take out the box.
Feb 14, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool conquest 2001 GS6SHAXKQ01 refrigerator side by side top part is not cooling
the first one sounds like it is slowly leaking freon.
  •  the second Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items. If it still has a problem then it might be the compressor and you should probably replace the machine.
Jun 28, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
May 29, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirpool
check the overload and relay on the compressor if the fan at the bottom is working then it sounds like the relay overload combo or the compressor is the problem
Apr 19, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
