I have a samson meteor mic for a few months now.. i used to record from it..but now i cant record anymore using the mic.. im using audacity as audio recorder.. when i start recording it presents only straight line on audacity.. howcan i fix it??
  • 83 Answers
SOURCE: Audio Input Problems
buy a creative sound pcmcia card with stereo inputs...it runs aboout 50 bux at compusa...another solution would be usb audio input, they are also available at compusa,tigefr direct...i hope this helps...
Posted on Jul 30, 2007
TJBeta
  • 67 Answers
SOURCE: Recording Issues In Vista
Microsoft moved the particular option that you need to enable since Windows XP, and have also changed its default to MUTE.
To hear what is playing through MIC IN...
  • Go to Control Panel and select "Sound"
  • Under the "Playback" tab, double click on your enabled speakers.
  • Select the "levels" tab, and look for "Mic In Volume".
  • Click once on the speaker icon that is muted to un-mute it.
I really hope that this has solved your problem, if it has not, please let me know and I will do my best to help you further. Good Luck!
Posted on May 15, 2008
SOURCE: tips on Using the Samson C01U with Cakewalk Pro Audio 9
What computer are you using?
Posted on Aug 30, 2008
alisondking
  • 4 Answers
SOURCE: no recording?
In garageband when you have the gtrack set up , it will show you 2 options for input source 'USB Audio CODEC'. This is because you have 2 lines in, the mic and the jack. Make sure you have picked the correct one to record the vocals...otherwise it is expecting the jack input and will record nothing.
Hope this helps!
gypsykingthing (AKA alisondking coz there's not enough space for my trad tag!)
Posted on May 14, 2009
JulesPCaut
  • 702 Answers
SOURCE: when recording my voice sounds like a chipmunk
Even though you say you did not mess with the settings, I'd suggest you check the audio recoding settings in Vista anyway. Better make sure all those are correct.
If you are using an internal microphone, I'd suggest trying an external one (if you already have that, try a different one). Even a webcam with built in mic will do. That way you can isolate the cause.
Based on my experience I'd say that chances are bugger that it is a loose contact, so make sure to check your plug if it's an external mic.
Jules
Posted on Jun 08, 2009
Why is it suddenly way too quiet?
Try a different mic to see if problem follows. If yes then it is a setting. If not then the mic is bad and needs to be sent to mfg or get a new one.
Dec 18, 2015 | Samson C01U - USB Studio Condenser...
How to unmute my Samson Meteor Mic?
There are 2 ways to mute or un-mute the mic:
  1. Push the button on the front of the mic
  2. On the computer, open Recording Properties and go to the Levels tab and click the speaker icon next to Microphone slider.
Jul 06, 2014 | Samson Audio Players & Recorders
I have a samson c01u and using audacity. i set the input level in the control panel to 100 and also in audacity, but the the volume is still too low. i can barely hear my voice. what do i do?
1. Did you select Left channel only in Audacity for the track you're recording?
2. Maybe it's a defective mic. Try it on another computer/software/USB cable/USB port and if it still doesn't work get Samson to replace it.
Apr 05, 2014 | Samson C01U Consumer Microphone
Mic sound muffled static
Buy a better mic! This question reminds me of the musicians who invest in a nice JBL public address system but then use Radio Shack microphones. A good quality mic, not GREAT but just good will cost you a minimum of $100. Quit playing with toys and invest in real recording gear. Computers and hard drive recorders can easily record CD quality audio, and-so why would you use a $70 mic?
Sep 10, 2013 | Samson Samtr Meteor Mic Usb Studio...
I connected the microphone on my computer and the system rec.ognized the microphone but I don't know how to use it with the computer to bring out sound
The thing is that the Samson C01U was not designed for live applications. Your solution, if you like delayed sound, is to use Virtual Audio Cable. Otherwise, I would get either a Samson GTrack, or invest in a cheap but functional mixer with a good mic. If you want to record however, you go into your audio recording settings and select the C01U as the recording mic. If you record and hear little sound, go into sound manager... Click on properties and select on Samson C01U. A one channel volume control will pop out. change the volume and record. BTW, a good audio program is Audacity... It's free. I hope that I have helped you...
Apr 27, 2011 | Samson C01U Consumer Microphone
The mic does not record stereo anymore. when playing back a stereo works fine but when recording in stereomodus only the left channel records, the right channel seems to record silence/noise
This Mic is not a stereo Mic. If you're using a windows computer, check your sound control panel to see if the mic wasn't suddenly set to two channel device.
Sep 30, 2009 | Samson G-TRACK USB RECORDING MICROPHONE...
Microphone records very quietly. i'm not sure if it's the Audacity program i'm using or if it's the microphone. any suggestions?
go into control panel/sounds and audio devices/voice and in the voice recording and click the volume button and on the slider that's labled mic pull it up.
Jul 31, 2009 | Samson C03U Professional Microphone
Samson C01U USB mic not working on my PC.
try this;
1.using different usb inputs on your pc desk top
2.update drivers on both your desk top and laptop
3.using a different usb cable
if it works fine on your friends computer most likely its not the mic
Feb 25, 2009 | Samson Audio C01upak C01u Microphone and...
Cannot record
Im having the same probz, got a Hp Pavilion Vista using mobile pre amp usb when i record using a condenser mic XLR nothing is picked up from the channels in Cubase or Nuendo. Im trying to record vocals but the Mic is not picked up and i cannot hear myself in the headphones and it wont transfere to cubase.
It has worked before when i had a desktop, but this only worked with a separate m-audio sound card inside the desktop and i plug in the output jax leads from the desktop (soundcard) to the m-audio usb pre amp
Is this why it is not working for the laptop do i need a Jax connection and where is this audacity
Sep 15, 2008 | M-Audio M AUDIO MOBILE PRE - USB MIC...
No recording?
The static after several seconds seems like this is a problem with certain versions of OS X. You might be able to fix it by downgrading or upgrading. Apple Forums say that it's fixed in 10.5.6.
You can double check that this is the problem by trying it on a Windows computer.
Jul 28, 2008 | Samson G-TRACK USB RECORDING MICROPHONE...
Computers & Internet Logo
125 people viewed this question
David Payne
David Payne
