Question about Akai PT5598HD 55" Rear Projection HDTV-Ready Television
Dtv switch is my tv ready for dtv i have a akai tv is it ready for the switch
    Champion:
  • 240 Answers
Yes if runing sat or cable, if your using antena you will need dtv antena and dtv box for reception.
regards,
daniel.
Posted on Jan 11, 2009
What is DTV initial
Direct TV means the TV came with a DTV receiver built in. So if your not paying for direct tv then its a mute option for you.
Oct 18, 2014 | Akai Televison & Video
Dose my tv (Hisense TL3000) is hd-tv ready
Not all units were fitted with the DTV tuner before the switch over occurred. you set should have an insignia that sates that it is DTV ready. if this insignia is not on the box or actual set, you will need a converter box to receive this DTV signal.
Jun 21, 2009 | Hisense TL3000 30 in. HD-Ready LCD...
Akai not working since digital conversion
It most likely has nothing to do with the DTV. It is your power supply. Do a search on power supply issues on how to fix this. Try unplugging it for a minute or more. Also try leaving it on cable and then once it is on switch to DTV.
Jun 14, 2009 | Akai LCT2721AD 27 in. LCD Television
Conversion to DTV from analog
IF YOUR UNIT HAS AN ATSC TUNER THEN IT IS HD READY. SEE YOUR OWNERS MANUEL. HOOK THE ANTENNA TO THE RF (ANTENNA) CONNECTOR .GO INTO THE MENU AND AUTO PROGRAM CHANNELS. GO TO CHANNEL 5 AND SEE IF YOU HAVE 5.1 OR 5.2 IF SO YOUR DONE.
Jan 30, 2009 | Akai LCT2721AD 27 in. LCD Television
Dtv ready?
Going to the following link will help you to find out if your television is DTV ready or not:
http://www.dtvtransition.org/index.php?option=com_content&task=view&id=51&Itemid=94
Using their online tool, select the Brand (Akai) and the Model from the list. If you cannot find your model in the list (which I was not able to for your television), they are saying that you most likely do not have a digital tuner.
All is not lost, however. As stated on the aforementioned site, you can consider one of the following options:
  • Purchase a digital-to-analog converter box that plugs into an existing television. The boxes, which are expected to cost between $40 - 70 will be available for purchase in 2008. Beginning in February 2008, U.S. households can request up to two coupons valued at $40 each. Each coupon can go toward the purchase of a single set-top converter box that will allow you to continue watching FREE "over-the-air" television on an analog set.
  • Subscribe to a cable, satellite or telecommunications service provider if all desired local broadcast stations are carried by that service.
  • Purchase a new television set with a built in digital tuner.
    Listed on the page is further information that may help you to determine the status of your TV:
  • Consult your owner's manual. If that's not possible, you may be able to look up information about your TV set on the manufacturer's website. Or, you can take an up-close look at your TV set. You are trying to find out if your set has an input connection labeled "digital input" or "ATSC" (for Advanced Television Systems Committee, which is developing the DTV format).
  • If you bought your TV set before 1998, it probably doesn't have a digital tuner at all. Almost every TV set made before 1998 was a traditional "analog" set that can't display digital TV signals without either a special converter or a cable TV connection. If you bought a big-screen, projection TV between 1998 and 2004, it's possible there's a built-in digital tuner inside. But chances aren't great. Only a limited percentage of projection TV sets (and generally only those 42 inches in diameter or larger) included digital tuners before 2004.
  • If you've purchased a new TV set since 2004, your chances of having a built-in digital tuner improve dramatically. Starting in 2004, many of the TV sets sold at popular electronics stores have featured digital tuners that will let you receive the new digital over-the-air broadcasts starting in February 2009. But be wary: It's not a sure thing. Even some of the newer TV sets are purely display monitors that lack the internal circuitry needed to pick up digital broadcasts. Usually these sets have been advertised as "HD-ready" or "HDTV monitor" sets. That means they can display digital and high-definition signals, but they need help getting those signals in the first place. You'll still need a special converter or a cable TV connection.
  • Jan 12, 2009 | Akai PT5492S 54" Rear Projection...
    Stuck in DTV mode
    Did you hit the source button till you get it back to the mode you want?
    Jul 03, 2008 | Akai LCT3201AD 32 in. LCD Television
    New DTV remote # RC64R does not control Akai lct3201TD
    They have so many revisions that it will take time to get the codes out but . you wanted to know the code here they are in all their nakedness. don't laugh
    http://www.akaiusa.com/img/support/akai_remote_code.pdf
    Oct 22, 2007 | Akai LCT3201TD 32 in. LCD Television
    Actually...it's a Akai PT5299HD
    I HAVE A AKAI PT5299HD TV AND WHEN I PUT ON THE AUTO FOCUS THE TV KEEPS TRYING TO FOCUS ENDLESSLY BUT DOES'NT FOCUS. IS THERE A WAY TO MANUALLY FOCUS THIS TV-MY WRITING ON THE SCREEN IS BLURRY?
    Jul 31, 2006 | Akai PT5598HD 55" Rear Projection...
    Akai PT5598HD 55" Rear Projection HDTV-Ready Television Logo
    94 people viewed this question
    Top Akai Televison & Video Experts
    Jaime Hernandez
    Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
