Question about Samsung LN37A530 37 in. LCD HDTV
37'' LCD Samsumg TV
My 37'' LCD Samsung TV some times will not shut off when using the remote control pointed at thesensor and the sound indicator bar will show on the screen but cannot be adjusted.
  • bob_mcallist Jan 05, 2009
    The 37" samsung tv is new, 10 days old (Dec. 26th) and the problem dose not happen all the time. We know when it is going to happen because the volume bar shows on the screen.
    Bob
  • sing ah May 11, 2010
    Are you using the original remote that came with the unit? Try changing the battery for the remote, try the fresh new battery. If still doesn't work, you may have a loose/cold solder in the remote unit. Always the case since the remote is born to be dropped most of the time even in a pail of water, he .. he .. happened to me.
  • 98 Answers
Need to get warranty service,
It seems not a big problem.
need to check the s/w & related cable on the TV.
Posted on Feb 09, 2009
Why does my Samsung not turn off my cable box?
It sounds like the box and TV are out of sync. If the DVR is shut off, turn off the TV manually (NOT with the remote.) The next time you hit the power on the remote, both units should power up together. Make sure the remote is pointed at both device at the same time and slowly sweep the remote to hit both of them while holding the power button. I have always used the cable/DVR remote to control my devices and left the TV remote in a basket for setup stuff only on the TV.
Jan 31, 2016 | Samsung UN65HU8700 65"" Curved 4K Ultra HD...
How do i set up a new remote control for a samsung ht ws1 sound bar
2-Function Remote Stopped Controlling my Sound Bar - Verizon Forums
https://forums.verizon.com/t5/Fios...Remote...Sound-Bar/td.../559715
Apr 6, 2013 - It won't even control volume through the TV (Samsung). ... Did theremote ever turn on the sound bar, or have you been controlling ... Does the sound bar or TV have sound (sound but not volume control)? ... NO, UNFORTUNATELY THE FIOS REMOTE NEVER POWERED ON/OFF THE SOUNDBAR - I HAD ...
Your remote reprogramming woes solved - Rogers RedBoard
redboard.rogers.com/.../your-remote-reprogram...
Rogers CommunicationsJun 18, 2014 - Once the TV turns off, press the SETUP button once to lock the code.... the Rogers remote to turn TV on/off but can't get the remote to control volume. ...New Samsung smart TV and I have entered all the proper codes but the ..... Doesanyone have a code for volume control of Samsung Soundbar HW-J250.
Wireless Genie remote Doesn't turn on/off the soundbar - AT&T ..
Jan 08, 2016 | Samsung HT-WS1 Speaker System
Volume bar stands at 200 every time i start my Samsung LCD
set the volume down extremely low power the tv down by plugging out and put on again should be then at set volume,the tv's now days have memory so it should start up at volume preset
Dec 21, 2013 | Samsung LN-S2651D 26 in. LCD Television
Samsung 37
Look for any jammed buttons on remote or on control panel. Try removing the batteries of remote and see. Look for any loose contacts in RC jacks/sockets/Cable or even the power outlet.
Aug 04, 2012 | Samsung 37 in. Flat-Panel LCD HDTV
I have a Samsung hw c-451 sound bar.I have it connected with optical audio out. I want to adjust volume of sound bar with DISH /LG remote and eliminate tv speakers
Dish doesn't appear to have a code for Samsung receivers but try the Sharp codes listed. Here's a link
http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml#amp
Same thing for the LG remote
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=3252
I recommend connecting your sound bar to your dish receiver as well as to the television. Play around with optical and RCA to see which one you prefer the sound of. The television isn't always the best center channel so you might find that you like this set up better with the dish receiver connected directly to the sound bar. Then you can shut of the television speakers. Some people turn the television speakers back on and leave the sound bar off for early morning breakfast news viewing. Not being sure which dish receiver you're using you might have to indicate to it how you wish to output your audio, or all outputs might be outputting at the same time all of the time.
Jan 27, 2011 | LG 50PK550 50 in. TV
Turns on automatically
use your camera on your phone and point the remote at the camera lense, you will probably find the remote is lit up and the remote is the problem, button on the remote is stuck and sending signal to the tv all the time until the batteries go flat. if its not that then the tv main av controller board has a fault. there area on the board for remote signal control.
Jan 09, 2018 | RCA L37WD12 37 in. LCD HDTV
Cable Set-Top Box remot won't change sound vol. Only TV Rem. does
They volume indicator you are seeing is meant to show the volume of content if it were to be recorded on the cable's dvr. This indicator has no effect on the volume of content as it is being watched. This feature allows recording of sound at a set volume even while the tv is off. It sounds as though you'll just have to use the volume buttons on your tv's remote, though you might want to try seeing if there is alternative set-up for those cable volume buttons.
Jan 05, 2009 | Samsung LN19A330J LCD TV
Samsung LN37A530 37 in. LCD HDTV Logo
107 people viewed this question
Henry  Thomas
Henry Thomas
