Question about Dryers
Belt diagram for Whirlpool AWA970B
Does the belt simply drive off the motor shaft or is it intended to have a small sheave (mine doesn't have)
  • 77 Answers
SOURCE: I have a whirlpool gas
I assume you mean the cone shaped plastic on the motor shaft. this is not necessary, it is there to keep a worn belt from riding onto the shaft. if the belt and idler(should be replace with belt) are good it shouldn't cause a problem.
J
Posted on Jun 12, 2008
  • 66 Answers
SOURCE: How do you replace the drive belt on Whirlpool dryer?
What is the model number of the dryer.
Posted on Nov 14, 2008
appldoctom
  • 311 Answers
SOURCE: Need belt diagram for Whirlpool Dryer LER5636P
its on the bag of a new belt.but its eazy to put on .put the belt with ribbs down on the drumthis is with the drum on the rollers in the dryer .now have the idler pulley in place and put the belt in between the idler pully roller and the pully bracket,then pull back on the pully and place belt on motor pully.check alinment before starting or will throw belt off again.God bless,tom
Posted on Jan 01, 2009
dragonsthatk
  • 547 Answers
SOURCE: Need to replace dryer belt.
screw on bracket of motor for tentsion release
Posted on Feb 12, 2009
SOURCE: lFitting drive belt to Hotpoint VTD00P tumble drier
boil the kettle...drop the belt in for a few minutes... hold the belt and put under ur feet.. stretch itttttttttttt!!!! a few times.. it will stretch believe it or not to approx another 1 to 2 inches.. then fit the belt.. it WILL be tight..and SHOULD be... little elbow grease to take it that last few centimetres and BINGO!!
Posted on Mar 14, 2009
Riding Mower-Trouble trying to change belt
Probably corrision between the bolt and idler bushing. Put the nut back on leaving it loose and tap with a soft face hammer *(brass hammer) and it should loosen it.
Jun 17, 2015 | Garden
Air condition not works
The simple things to check: fuse and drive (fan) belt. With the engine running and the A/C set to on, open the hood and locate the the A/C compressor. The drive belt should be present and spinning the sheave on the compressor. With the A/C set to on, a built in solenoid couples the spinning sheave to the compressor's shaft. If only the outer sheave is spinning, the solenoid is not energized.
A missing drive belt would need to be replaced to work the A/C compressor. If missing altogether, could indicate a bigger problem (seized compressor, etc.). Installing a replacement belt is usually not that expensive.
An open, blown or missing A/C fuse in the car's fuse block can cause this, as could a defective solenoid (not a common occurrence) in the sheave or a low refrigerant charge level (pretty common problem). Only the fuse is something you can check easily. An automotive A/C mechanic will need to service the solenoid or recharge the refrigerant however. Be aware that a refrigerant system is designed to be sealed. If refrigerant has been lost, there's a leak. Small, slow leaks are acceptable, but you don't want to be spending $100 or more every season (or less) to recharge the system. Locating and repairing the leak will cost a little more money up front, but should save you from constantly recharging the system.
Sep 18, 2013 | Mercedes-Benz Cars & Trucks
How do you fit a new drive belt to a rockworth compressor because there doesn't seem to be ant adjustment
if this is a small compressor say 2 hp you leave everything alone make sure you have the right size belt and stretch it on like a rubber band.. The belt will be quite tight but thats the way they come. If you are concerned that the new belt is too tight or too loose mark the position of you motor with a felt pen remove the belt and move the motor forwards or backwards a small amount in line with your marks, then refit the belt. The main thing is that the motor shaft stays parrallel or close to it with the drive shaft of your pump.
Jan 16, 2013 | Air Tools & Compressors
Replacing a belt
Replacing the Drive Belt
IMPORTANT: To aid in reassembly, note the orientation
of the drive belt on the two idler pulleys and the engine
flywheel pulley prior to performing the following steps.
Refer to Figure 10.
The edger drive belt is subject to wear and should be
replaced if any signs of cracking, shredding or rotting
are present. To replace the belt, proceed as follows:
1. Working in front of the edger, loosen the flange
lock nut on top of frame, allowing the idler pulley
assembly to pivot slightly out from the frame. See
Figure 10.
2. With your other hand, carefully reach under the
rear of the unit and remove the belt from around the
engine flywheel pulley.
3. Remove the spindle sheaves belt guard by removing
the two self-tapping screws which secure it to the
blade plate assembly. See Figure 10.
4. Carefully remove the belt from the pulleys,
again making sure to note the orientation of the belt.
Discard the belt.
Install the replacement belt (Part No. 754-04032B) in the
same configuration that the original belt was routed as
follows:5. Working from the front of the edger, place the belt onto
the spindle sheaves, route it back onto the two idler
pulleys, and then place it onto the engine flywheel
pulley.
IMPORTANT: Make certain that the "V" side of the belt
is seated into the top pulley and the flat side of the belt is
seated into the bottom pulley.
6. Reinstall the spindle sheaves belt guard with the self
tapping screws removed earlier.
7. Make certain that the drive belt is on the engine
flywheel pulley and idler pulleys, and retighten the
flange lock nut on the top of the frame.
IMPORTANT: Make certain that the drive belt is seated
correctly and that it is riding smoothly on the spindle
sheaves and is not pinched between them. Repeat the
first three steps if the belt is pinched.
You don't want the belt pinched between those spindle sheaves...trust me ;)
the manual
Oct 13, 2012 | Troy-Bilt tb554 lawn edger
Changing speeds on Powermatic Drill Press
Katie,
Refer to the picture below. Loosen the locknuts (the one on the right side of the drill is shown, there is another on the left side). Use the lever to move the motor toward you, thereby loosening the drive belt(s). Open the top cover to expose the belt(s) and sheaves (most people incorrectly call them pulleys). You might have one belt and two sheaves, or you have two belts and three sheaves. The drill will go fastest when the belt is on the biggest motor sheave and the smallest sheave on the drill spindle. Of course the opposite sizes apply for the slowest speeds. Make sure the belt uses a pair of sheaves that are at the same height as each other (the belt has to stay in one plane). Now tighten the belt(s) by pushing the lever pretty hard away from you, and while holding it with your right hand tighten the left side locknut with your left hand. Now tighten the right locknut. Close the cover. ----- OK, so now you know how to CHANGE speeds, what about drilling glass? This can be tricky. You must use a pretty slow speed (maybe the slowest, depending on the size of hole you are drilling. And you must keep the spot you are drilling flooded with water to keep the glass cool. And you must apply pretty gentle pressure. And the use of a drill bit intended for drilling glass helps a lot. And don't try the first hole in something expensive! Practice on something disposable first. Take your time. AND WEAR SAFETY GLASSES!
Jun 15, 2012 | Powermatic Drills
Belt keeps breaking when put a new one on that controls aternator,water pump,etc on my 1995 Nissan pick up truck
if it keeps breaking you either have atension or alignment problem. Alignment will show on the edges of the belt and you should be able to catch a bit of burnt rubber smell on the belt. Unless you have done major work orpulled something thatbwould have moved a pulley my bet would be on tension. on a serpintine belt there is atensioning pulley and these do wear out. When the tension is out the belt can slap and break
Jun 06, 2012 | 1995 Nissan Pickup
THe engine run but it doesnot pump any water
First of all, check to see if you are getting water to the pump. Sometimes there is a screen to prevent minerals and what not from getting into pump. If you are getting water to pump , insure that it is rotating, Is it a direct drive or a belt drive pump? If it is a belt drive, Insure the belt is in place on the drive sheaves. If the belt is in place on the sheaves, check to insure that the sheaves are not rotating freely on the shaft. You need to check for Keystocks. They will be in a groove, machined into the shaft and used to hold the sheaves in place. If there are no grooves machined into the shaft, then you will have a flat side on your shaft. Check the setscrews on your drive sheaves for looseness. Tighten as needed. If all of these items check out, remove the compression tip on the wand and try to get water out of the pump that way. If you get flow you may have a clogged tip. Unclog with compressed air through the opposite end or a paper clip should push out the clog. If that does not clear up your problem Insure there are no leaks around the pump, no leaks? Well then its time to borrow your neighbors, rent one, get your money back on that one or hire someone else to do the job while you sit in your lazyboy and watch the game.
May 22, 2012 | Garden
Need replacement pulley for a Delta DP350
I have a $14 fix for your dead Delta DP 350
My Delta DP 350 died as well...the Reeves pulley disintegrated....
I found a real beefy adjustable drive pulley on eBay called a ' Congress Drive'
http://www.ebay.com/itm/290686861949?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
All I did was bore it out to .5880" ( just picked a drill bit closest to that size ) on my friends drill press... I opened it up to a small diameter and locked it in place with the set screws on it.... I used the speed knob on the press to adjust the belt tension..... works perfectly !!!!! And these drives are available, rugged, and cheap... $14...... email me with any questions...... Bill
actnbill@yahoo.com
May 05, 2012 | Delta DP350 Shopmaster 1/3 Horsepower 12...
Need help with my whirlpool dyer a white wheel came off dont know were it goes
The small white plastic white wheel goes to the idler pulley. It is located to the left of the burner assembly on the bottom cabinet behind the blower fan assembly. This is what keeps the belt tightly around the drum. There is an excellent illustration of this at pcappliancerepair.com. Just type in your model number and look for item 13 under the "Cabinet Parts" heading. The idler pulley attaches to the idler bracket (item 39).
There should be a small triangle shaped retaining clip that keeps the pulley in place on the shaft. It is known as a "tri-clip". If the clip has broken off, you can purchase replacements at pcappliancerepair.com for about $3. The part number is 690997. There is also a thrust washer on the idler shaft. The part number 233520. Make sure it is still in place.
If the pulley needs replaced, the part number is 279640 and it comes with the thrust washer and tri-clip retainers for about $14.
To access, remove the toe panel directly below the door and remove the air blower assembly cover. Make sure you UNPLUG the dryer while servicing the cabinet interior. Dangerous voltage is still present while the unit is turned off. You should be able to reach behind the drive motor and find the spring activated idler bracket. The wheel mounts on the back side of it with the thrust washer installed first, and the tri-clip inserted last. Refer to the parts drawing for details.
NOTE: Without the tension on the belt, the idler bracket will trip a small switch that prevents the drive motor from running. This is known as a "broken belt switch" that keeps a broken belt from wrapping around the motor shaft and burning. So, if your dryer is running, this is why. You should be able to hear the switch toggle as you move the idler bracket up and down.
For details on how to reinstall your dryer belt, go to repairclinic.com and click on the "Repair Help" link. On the following page, click on the "Dryer Belt Diagrams" link under the "Special Features" section. Locate the Whirlpool dryer belt link and refer to diagram K.
If you have questions, please let me know. I hope you find this information helpful.
Oct 18, 2009 | Whirlpool GGQ8831L Gas Dryer
Jan 24, 2009 | Whirlpool LEW0050P Electric Dryer
Dryers Logo
41 people viewed this question
Top Dryers Experts
