Question about Technics SA-AX720 Receiver
Technics SA-AX720 Moved system for decorating, hooked it up exactly as before. Now I can hear sound from the right channel but the left chennel produces a clicking sound, changing the speakers over produces the same effect.
  • randomex Aug 23, 2008
    Technics SA-AX720 Receiver Problem:
    Hi there!
    I need specific advice for this receiver which I recently bought from yard sale.
    Irrespective of inputs, viz. phono or tuner,
    symptom:
    when the logic/prologic selector on the left is turned to "off", i.e. 2-way stereo only, it works ok with either speakers A or B and or with surround sound speakers.
    However, when this selector is turned to Surround Sound, or Stereo 3, or in any one of the Pro logic modes, the sound from all speakers & headphone may suddenly go off or may come back some time later, but often NOT.
    Some times when I turned off the power and turned it back on, it works again, but often NOT.
    If I switch off the speakers (A) and/or (B), the headphone works.
    Any solid solution (e.g. suggest whichever component may go wrong) will oblige!
Look for lossing solders points or bad conections. Start to look on those components of hi wattage and components to get hot alot, those are the most common to have weak solders spots.
Also some equipment need to be clean because the dust can make problems.
good luk.
Posted on Feb 18, 2008
Can i hook a amplifier to my technics receiver model no sa-ax720
If the Amplifier has more Output Power and Better Quality Sound then it is worthwhile to do so -Yes you can connect Amp to Technics Receiver you have mentioned
Jun 24, 2015 | Technics Audio Players & Recorders
Can i hookup a television to my receiver for sound
Yes. You can hook it up using a digital coax or optical cable. Use can also use old stereo, analog, left and right channel audio. Use any audio input on your Technics, that will accept any of the inputs above.
Feb 09, 2015 | Technics SA-DX940
My component is well working, but when in use, if switch on other components like fan. light or the like it comes big sound and then stops. this occur only on its right side speakers
Purchase an AC line filter /. surge protector.
Also , do you have the system connected to a Grounded AC plug ( one that has 3 holes?)
Jan 28, 2014 | Technics SA-AX720 Receiver
Trying to hook up SH-AC500D to SA-AX720 Receiver. I wanna know the right wires to use. Thank you
Connect the 6-channel analog outputs of the AC500 to the 6-channel analog inputs on the AX720 using 3 RCA cable pairs.
http://archiwumallegro.pl/technics_shac500d_procesor_surround_ddigital_dts-1215399983.html
Digital sources will enter the AC500 and be converted to 5.1 analog output.
Be advised, that input on the receiver will not allow any internal DSP manipulation. WYSIWYG.
Feb 04, 2011 | Technics SA-AX720 Receiver
Looking for user manual for Technics SA-AX720 receiver
You can download them, depending where you are, I have one!
Jun 07, 2009 | Technics SA-AX720 Receiver
Max. wattage for speakers w/ Technics Receiver SA-GX100?
I too have a Technics SA-GX100 and it's rated at 2 x 40W @ 8 Ohms. I have the Technics SB-2840 floor model speakers hooked to it, which are rated at 200W Music Input - 8 ohms. It sounds very nice just to be a 40W receiver.
Apr 06, 2009 | Technics SA-AX720 Receiver
SA-AX720 no subwoofer signal?
THIS UNIT HAS NO SUB WOOFER AMP IN IT. THE ONLY WAY TO OVER COME THIS IS TO HOOK THE LEFT AND RIGHT FRONT SPEAKERS STRAIGHT TO THE SUB WOOFER AND THEN GO FROM THE SUB WOOFER BACK TO THE INPUTS ON THE BACK OF THE UNIT FOR THE FRONT SPEAKERS. THE SUB WOOFER THIS WAY WILL EXTRACT THE BASS AND THE FRONT WILL RECEIVE THEIR PART. THIS SOUNDS CRAZY AS HELL I KNOW BUT THAT'S HOW I GOT MINE TO WORK. THE OUTPUT FOR THE SUBWOOFER IS USELESS AND PUT THERE FOR YOU TO HOOK UP AN AMP FOR A SUB WOOFER. EVERYTHING HAS SHORT COMINGS, AND THAT'S THE ONE FOR THE AX-720.
Sep 22, 2008 | Technics SA-AX720 Receiver
Technics SA-AX720 AMP
The audio amplifier IC of your device are damaged you need to replace it.
Jul 04, 2008 | Technics SA-AX720 Receiver
Very low sound in main left chennel.
disconnect the cabel of left channel from your amp disconnect the cabel of right channel and put it in place of left channel if the problem goen your problem is in left speaker itself (cabel or speaker).if the problem excit the problem will be in amplifier output stage
Jan 28, 2008 | Yamaha DSP-AX1 10-Channel Amplifier
Can't hear any sound from the large left or right speakers
is sterio in a ch ? not b or is it in b and not a when u hooked it back up
Jan 26, 2008 | Technics SA-AX540 Receiver
294 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
