Question about Sony STR-DE475 Receiver
What does the digital in cabel and connection look like
Trying to set up digial audio to maxent 42 inch plasma tv
    Scholar:
  • 73 Answers
Its either an orange input and output, that is one RCA style digital cable,
or a TOS that is a square female, and the wire looks like it has a little light bulb on the end.
Charles
Posted on Jan 05, 2009
I how a 42 in maxent monitor. How do I hook up tv tuner?
the tuner or a set top box etc would have to be connected to one of the sets of audio/video inputs and that input selected.
Jul 17, 2012 | Maxent MX-42HPM20 42 in. Plasma HDTV
I have a 42 inch maxent but i dont know where to plug my cable cord because i have a comcast box and theres no where in the t.v to plug my cable cord
If your comcast box has video (yellow), audio R (Red), audio L (White) out, just connect RC cables to the input of the TV at video, audio-in RC Jacks. If your comcast box has only RF out, buy one RF to audio-video converter and then connect these to the TV.
Jul 11, 2012 | Maxent MX-42HPM20 42 in. Plasma HDTV
How do i hook regular cable to Maxent MX-42EPM20 42 in. EDTV Plasma Television
Your Maxent MX-42EPM20 is not a TV (Television) it is a Plasma panel. The difference being your Panel does not a TV Tuner (no Coax jack or electronics relating to a tuner) Below is the spec sheet that shows this
http://reviews.cnet.com/flat-panel-tvs/maxent-mx-42epm20/4507-6482_7-32139310.html?tag=mncol;subnav
You can use a cable box or a cheap Digital TV receiver. You can buy them at walmart, You need one with A/V out puts such as Component. Here is a link to one. This will give you a tuner.
http://www.walmart.com/ip/RCA-Digital-TV-Converter-Box-DTA800/8343230
Feb 18, 2012 | Maxent MX-42EPM20 42 in. Plasma EDTV
I have a 42" Maxent plasma tv. When turned on,
one or your tv mainboard was crashed, change it with new one
Jan 18, 2011 | Maxent MX-42HPM20 42 in. Plasma HDTV
I've got a LG 42 inch HDTV model GP-DVB-EU When I
When you have just the cables as you describe, you are using composite inputs. By default, yellow is video, red is right audio, and white is left audio.
Nov 28, 2010 | LG 42LC2D 42 in. LCD HDTV
Maxent plasma tv no picture or sound
Check and replace that board. Just visit the site linked here. Y Sustain board faults and symptoms of plasma display is given in details. http://electronicshelponline.blogspot.com/
Apr 07, 2017 | Maxent MX-42XM11 Television
I have a Maxent 42 inch plasma.When you turn it on, it flickers for 5 minutes then comes on.recently the flickering continues non stop and now is almost unwatchable.Any idea what I can do to fix this? I...
What is the Product Name or Model number of your Maxent 42" Plasma TV? If it is a MX-42X3, Model # P420542HM8, I think I can help you. I have encountered this exact same problem with 2 Maxent MX-42X3 Plasma TV's. I found that C766, a 220uF, 16V surface-mount electrolytic capacitor on the main board is bad. This capacitor is located just to the left of the green multi-fin processor heat sink. This capacitor will test good using capacitor meter or an ESR meter, but if you spray it with Freeze-It with the power on, you will find out that this is the problem! To get it out, I found I had to remove the little 10uF 16V surface-mount capacitor just to the left of it. I then replaced these 2 capacitors with regular (radial), high-temperature, low-ESR capacitors. I cut the leads short, and bent the ends out just a little bit so you can solder them back onto the surface-mount pads. You can get these parts from Digi-Key Corp. I used Digi-Key part # P12383-ND ($0.32) for the 220uF capacitor, and P11212-ND ($0.30) for the 10uF capacitor. Both of these capacitors are rated for 25V and high temperature, so they won't go bad again. You can purchase surface mount capacitors there too, but I find them very difficult to solder back into those locations due to the tight placement of other capacitors in that area. If you're not an expert in soldering, I suggest you take the main board to a qualified electronic technician, and let him do it. But you better put the board in an anti-static bag before you take it anywhere! Hope this helps!
Oct 31, 2009 | Maxent MX42X3 42 in. HD-Ready Plasma...
Maxent plasma tv is showing only vertical lines.
Common problem on these sets are many many bad caps on the digital board. Repair kits are available for these containing the necessary parts if you're savvy with a soldering iron. Otherwise, replacement of the digital board is necessary and you'll have to contact either Maxent or a local repair shop. Tracking down which caps are bad can be difficult even with the right equipment as some tend to check good while in circuit when they are actually bad.
May 19, 2009 | Maxent MX-42V1 42 in. Plasma Television
Maxent 42 inch TV Keys locked and Remote will not work
See if you can reset the electronics to factory defaults. Also check with the mfg about this. If nothing works you have one sick puppy on your hands.
Try this - turn set on then pull the power plug. Then push and hold the power button to on position for a few minutes.
Release button and plug back in Turn on and see what happens.
Sep 21, 2017 | Maxent MX-42HPM20 42 in. Plasma HDTV
Maxent MX-42XM11 Plasma HDTV
finding correct tv code for mexent 42 inch plasma tv for direct tv receiver
Dec 31, 2007 | Maxent MX-42XM11 Television
Sony STR-DE475 Receiver Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
