Question about Danby Heating & Cooling
I had a danby DPAC11012 and when i used it as a dehumidifer the room turns very hot. what will i do? i just bought it last summer. tnx
Here's my email address. weng_amurao@yahoo.com thank u and more power
koolbreezes
  • 540 Answers
SOURCE: AC doesn't blow cold air
Threr are suppose to be two sounds comming from the window unit. One, the fan sound and the compressor sounds, (this compresses the refrigerants aove room temperatures (around 240*) & send it to the back coils and remove it to room temperatures and send it to the front coils which if enough freon, it will cool to at least 40*. Turn the thermostat all the way up or down while its off and see if you hear a clicking noise which tells you the thermostat is working which that what calls for cool. If it started loosing cools little by little, then you have a leak, and leaked all the freon out! If it stopped cooling all of once, then your compressor is not kicking in.
Posted on Jun 18, 2008
SOURCE: I have a Simplicity dehumidifier/humidifier
I contacted the Danby Co. and found out the unit was still under warranty. They gave me the name of a local repair shop who replaced the float sensor "free of charge".
Thank you for your time and interest. If I have another problem later I will be in touch with you.
mef
Posted on Jul 03, 2008
  • 653 Answers
SOURCE: Danby ALSO does not cool 3 days old
Take it back where you bought it. A 12,000 BTU unit should be more than enough for a 192 square foot room, so there is some problem with the unit.
Posted on Jul 10, 2009
  • 4736 Answers
SOURCE: HI, When using the Danby model DPAC 8399 as a
Yes, you certainly do. The unit has to exhaust either as a AC unit or a Dehumidifier.
Posted on May 29, 2011
  • 1033 Answers
SOURCE: I bought my Haier HWR
Hello, it can be a few things. 1) plugged air filter and evaporator coil 2) low refrigerant charge 3) the compressor is not engaging If you are willing to check out a few things i can tell you exactley whats going on with your ac
Posted on Jun 07, 2011
My air conditioner worked fine last night, but when I tried to turn it on today in the 101 heat, it displayed E1 (blinking). I've unplugged it because it would not let me turn it off either.
If your air conditioner displays E1 in the display panel and won't turn on, it means that the Room Thermistor (a device connected to the thermostat that detects room temperature) is shorted or defective, and you need to have your air conditioner serviced
Jul 22, 2011 | Samsung AW1203B Air Conditioner
I have water dripping from my Kenmore Air Conditioner Model #58074055400. I have misplaced the manual so I don't know what the problem might be. Can you help me or tell me where I can get a hold of...
It's suppose to drip water, just tilt the AC a little downward on the outside, so that it drips outside. The water is condensation that's being removed from you room's air... it's called dehumidification... it's a good think for the Summer.
Jul 20, 2011 | Heating & Cooling
I have a Danby Dehumidifer SDR408H. It seems that the compressor won"t cut in. The machine will turn on.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jun 02, 2011 | Danby Dehumidifiers
I have a danby model DPAC5799 was given to me with no manual i would like to use the dehumidifer in the basement ...how do i set it
You don't need to have an external exhaust if you are going to use it as a dehumidifier. Go to the mode button and click it until it goes to dry and then set the temperature a lower than the room. This should be all you need to do. I have had mine running all day and the room seems dry however I have had very little water (almost none) to empty from the reservoir. I don't know if this is a problem but maybe you can let me know how yours performs.
Aug 27, 2009 | Danby DPAC7599 Air Conditioner
Jul 10, 2009 | Danby Portable Air Conditioner
Same Problems as Everyone Else
I have a Danby DDR 458EE dehumidifer that I purchased May 27, 2008.
Used it for the summer and stored it until May this year. At the end of July of this year it started not working. It freezes up. Called Danby, they told me it was out of warrenty and to take to a repair shop. Problem being it was leaking freon so have it recharged. Called the repair shop and they explained that it is a closed system and if it is leaking Freon, they can not recharge it until the leak is found and repaired. It's against the law to discharge freon in to the atmosphere. Stated cost to repair it would be greater then buying a new one. Called Danby back and explained what repair person said. Still waiting to see if they will give me a pro-rated refund.
Jun 13, 2009 | Danby DDR6588EE Dehumidifier
I have a Simplicity dehumidifier/humidifier model SHCC6026 by Danby, bought new, used 2 months last summer as a dehumidifier, was emptied and dryed before storing for the winter. On start up this summer,...
mef
Jul 02, 2008 | Danby Heating & Cooling
Danby air conditioner model #DPAC10060(R)
here is the manual link: http://www.danby.ca/manuals/DPAC8020.pdf
Jun 03, 2007 | Danby DPAC8020 Air Conditioner
Dehumidify mode also cools
Some units do cool/dehumidify only im afraid why cant you let the unit dump its hot air into the room then it wont heat or cool the room?
Sep 03, 2006 | Danby DPAC9031 Silhouette 9,000 BTU...
Heating & Cooling Logo
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
Dan Webster
Dan Webster
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
