Question about Emerson MW8108P Microwave Oven
Microwave works intermittently
I'm using an Emerson Professional Series Mocrowave #MW8108P. When I heat up an item, the microwave works fine, when I stop sequence and restart..the magnatron does not work, the timer runs okay. Can someone please help..Thank you..Joe
  • Joe Wagner May 28, 2007
    Thanks so much, it was due to a failing door switch..changed the switch, and it works great now...This is a wonderful website..thanks again..Rengaw
  • Emerson Master
  • 9,098 Answers
This is most commonly due to a failing door switch or door switch mount. But it may also be a bad connection or bad relay on the control board, which we repair nationwide for $39.95. Also, it could be a loose connection at the magnetron. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams for similar models here: http://tinyurl.com/gv383 You can order parts at http://www.wehaveparts.com
Posted on May 22, 2007
  • William Miller
    William Miller May 29, 2007
    Thanks for your kind words and I appreciate your kind ratings!
What size is this microwave
Free Emerson Microwave Oven User Manuals - Kitchen ...
kitchen.manualsonline.com > ... > Emerson > Kitchen Appliance Emerson
Products 1 - 48 of 48 - Emerson Microwave Oven and Grill Owner's Manual. Pages: 0 ... Emerson OWNER'S MANUAL Microwave Oven MW8103SS. Pages: 0 ...
Aug 06, 2015 | Emerson MW8108P Microwave Oven
Mw8108p doesn't light or heat
Depending on the age of it, you're better off properly disposing it and buying a new one.
May 03, 2012 | Emerson MW8108P Microwave Oven
I just purchased an Emerson 1000W Microwave, Model #MW8115SS. I took out of box, removed the blue covering that protects the finish and when I plugged in and turned it on to heat something up, it was very,...
The unit may be more powerful than your last one. if its probably is normal 1100 w is a lot of power. if it works well and you in joy it, then you will soon be used to the new sound of power Good luck DFD
Apr 13, 2009 | Emerson MW8108P Microwave Oven
Emerson microwave oven model number MW8115SS
You don't state how old your oven is, or if you tried other food items afterwords. I also assume you inspected for foreign metal objects in the oven? If it does this whenever you attempt to cook in it, then it sounds as if your oven may have a wave guide cover malfunction or burned area.This part can be replaced by the consumer in most cases, but only after consulting with a trained technician or your parts supplier.
May 23, 2008 | Emerson MW8108P Microwave Oven
Emerson Micorwave oven MW8108P
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part such as high-voltage rectifier diode
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and
replacement, and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Oct 30, 2007 | Emerson MW8108P Microwave Oven
Microwave Keypad Is Hot
check blower fan, and maintained gap between oven and wall at last 2 feets. some heat comes to pad very heat may be some prolem. check every thing and reply me.
Aug 21, 2007 | Emerson MW8108P Microwave Oven
Emerson microwave oven model mw8115ss
There is not much you can do about this. There may be a reset button on the control panel, try it. You can try slamming the door a couple of times & looking on the back for any fuses. If this fails, scrap the oven & get a new one, as they are generally not worth repairing.
Jul 02, 2007 | Emerson MW8108P Microwave Oven
Unit does not work
open microve cover find magnetron crimp connections to magnetron
Feb 12, 2007 | Emerson MW8108P Microwave Oven
Need a turn table
It depece on where you live?? Go online and type in Emmerson MW8108 microwave. I got lots of links. Good Luck
Jul 12, 2006 | Emerson MW8108P Microwave Oven
Emerson MW8108P Microwave Oven Logo
769 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
jason
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
