Question about Cyberhome CH-DVD 300 DVD Player
Lost picture when set dvd player to progressive scan.
I switched the dvd settings to progressive scan and lost all picture but not sound. And now theres no way to see any menu options to set it back to factory. Someone suggested pushing on of the buttons for at least 10 sec. and I did this to them all to reset the player back to factory settings, no luck. My televisions progressive settings are dysfunctional so you see my dilemma. At any rate perhaps the unit can be set by pushing a combination of the buttons? Only things is which ones and if so.
Any help would be greatly appreciated. I bought a new phillips dvd player but do not want to throw this one away but rather keep it for another room if possible. It may be a cheap player but up till now its been good to me. Thank you.
  • fearlessloki Jan 05, 2009
    Hello everyone,
    I found a manual online at retrevo.com. MANY manuals here. I also found the solution to my own problem here. On the Cyberhome CH-DVD 300 (dvd player) you can reset the output back to interlace mode from the progressive scan mode by opening the drive door and pressing the stop button for 5 seconds. This will reset the player back to factory specs. Good luck with all other problems and thank you fixya for being here if in the future I should need your help.
  • Anonymous Mar 18, 2009
    just a comment to say that this advice works great and really did the trick for me as I had the exact same problem....that will teach me to fool around with my dvd player menus, lol. so thanks!
    Master:
  • 416 Answers
To Reset Player to Factory Settings:
If you selected Progressive SCAN and your TV does not support type of display, the display may
go blank and you will not be able to view the Setup Menu to change back the video settings. If this happens,
Turn OFF (Standby) the player, Turn back ON Player, Open Disc Tray and Press and hold the STOP button
on player for 5 Seconds.
Good Luck
Posted on Jan 05, 2009
    President:
  • 846 Answers
To Reset the DVD Player’s Video Mode Setting:
Warning: If you selected PROGRESSIVE for the SCAN
MODE and your TV does not support type of display, the
display may go blank and you will not be able to view the
happens, Turn OFF (Standby) the player, Turn back ON
on player for 5 Seconds to reset the Scan Mode.
  • Quickfx PC Repair Jan 05, 2009
    Hope this helps these are the instructions straight from the dvd player manual (fine print)
    Have a good evening from all of us at Fixya.
    dantechcom
    Sergeant:
  • 378 Answers
You will need to reset it for sure to make it work but if its not possible its necessary to call a service center tech of the device they will set it for you.not to worry.it will definately start working.
  • 45 Answers
Hello Fearlessloki, Welcome to Fixya.
Would you mind posting some of the details on this DVD player that is having issues?
I was playing with settings on my Zenith xbv342 and set the menu to progressive scan. I now have a blue screen with the words "progressive scan mode" I cannot get a picture and it is stuck in this m
Progressive scan mode is used by DVD players to artificially scale standard resolution DVDs to HD resolution, usually 720i. Is your set capable of receiving HD resolution? If not, that is probably why you are getting the blue screen.
Dec 18, 2014 | Zenith XBV342 DVD Player/VCR
Dvd, sound, no picture
If your DVD is external, I'd check TVs input settings: if your DVD on "progressive scan" mode, it delivers video signal via "component" connections: green, blue, red plus 2 separate red/white for the sound. If you trying to use 3 wires: yellow, red, white( composite), good chance, that the only sound is delivered. Try to switch DVD off 'progressive", if you only have 3 wires. It will deliver "picture". Or, verso-visa: using "component", 5 wires, but DVD set off "progressive scan". I've seen that confusion many times! Unless you have 'built in" DVD player. no matter what, it's must be broken! Use external DVD player, instead! $30 and trip to the store, will solve your problem. Don't want to fix TV, if everything else is alright. Myself, I never liked those "combo" units. You got stuck with mediocre TV and lousy DVD player. Better: separate them!
Good luck,
Alex.
Dec 25, 2011 | Toshiba Televison & Video
Problem with my Magnavox DVD player, DP100MW8, picture dark and lines across the screen
Hi, if the lines are diagonal sounds like it is set to progressive scan mode-which means if there is not a switch on back saying P/S and interlaced then you need to connect to T.V. with component video inputs ( indicated by red,green,and blue colored R.C.A. plug inputs) and Pan and Scan capable-then in menu setting select interlaced picture output. hope this was of use, good luck prodzilla
Mar 30, 2011 | Televison & Video
Hi, I've a small problem cocerning this dv-363 player. I accidentally set it to 'progressive'. Now I cannot undo. I tried holding the buttons on remote and on machine itself, still not working, can you...
Progressive Scan is a menu option relating to video output of this player. Assuming you have the original DVD remote, this should be easy.
* From the user manual (pages 50-51 of the pdf document):
About progressive scan video
Compared to interlace video, progressive
scan video effectively doubles the scanning
rate of the picture, resulting in a very stable,
flicker-free image. Progressive scan video is
available only from the component video
output.
If you connect a TV that is not compatible
with a progressive scan signal and switch
the player to progressive, you will not be
able to see any picture at all. In this case,
switch everything off and reconnect using
the supplied video cable (see Easy
connections on page 14), then switch
back to Interlace. Switch the player to
standby then, using the front panel
controls, press STANDBY/ON while
pressing 'back to Interlace.
Hold these 2 buttons together for about 10-15 seconds or so, but only while the player is in standby mode. *
If you have lost the manual, you may be able to download the user guide (as an adobe reader (pdf) document) from:
http://www.retrevo.com/support/Pioneer-DV-363-K-DVD-Players-manual/id/385bh937/t/2/
(it will ask you for an email address prior to downloading - use a blank address if possible and enter the security code in the fields then save the document)
If the above suggestion does not switch it back to interlace, you will need a TV with progressive scan function to enable you to access the player's on-screen menu and in 'Initial Settings' 'Video Output' 'Component Out' section, select 'Interlace'. and press OK from remote as required.
Either way, it should NOT require a workshop service, and is simple enough to do at consumer level with the right TV type.
Mar 05, 2011 | Pioneer DV-363 DVD Player
I have a (cyberhome ch-dvd 300) dvd player and changed setup menu now lost video cant see to change back is there a reset code or something
I wish I could find the website that gave all the repair hints for this DVD player, but I downloaded the info, and can no longer find the site. Here is what it says with regard to your symptoms. I hope this helps. I have done all the mods the site suggested, but continue to have difficulty with the remote, tray opening, etc. I have 2 machines and used to love them, but frustration has taken it's toll. Recovering from a condition with no TV picture
Accidentally switching to PAL and getting a rolling black & white picture happens all the time to baffle users, especially on models with a System or P/N key on the remote. To get back your color and sound just switch to the proper system in the menu or put in a movie of the correct type and it can switch automatically or try the procedure below for resetting to the defaults.
Sometimes owners will accidentally switch to Progressive Scan in the menu then get no picture at all. You can fix the no picture condition on the CH-300 by resetting the defaults to interlaced as mentioned in the users manual:
"To reset the VIDEO OUTPUT, turn Off the player, turn back On, open the disc tray and press and hold the Stop button on the player for 10 seconds to reset the scan mode."
The Reset procedure doesn't seem to work on all versions but you can sometimes get a usable B&W picture allowing you to get to the menu and change the settings by connecting the composite video input of your display to the Red Pr/Cr or Green Y component output jacks on the rear of the cabinet.
You can also go into the Menu and set it blind with the following key presses on the Remote:
1. With the unit Stopped, press Setup.
2. Press Enter.
3. Press the Down Arrow 3 times.
4. Press the Right Arrow Once.
5. Press Enter.
On 300Z & 300ZS models if the video is set to Progressive Scan and you can't get a viewable picture on the Red or Green jacks try going into the Menu blind and changing it back with the following key presses on the Remote:
1. With the unit stopped, press Setup on the remote.
2. Press the Right Arrow Once.
3. Press Enter.
4. Press the Down Arrow 2 times.
5. Press Enter.
6. Press the Up Arrow 2 Times.
7. Press Enter. This should switch it back to Interlaced scan with S-Video and Composite output.
To change the Parental Control setting on the CH-300 use the factory password of 3351. For the CH-400 use 1379.
Nov 02, 2009 | Televison & Video
I have a HD TV with cable and a go video DVD/VHS player hooked up. I went to change the time and accidentally changed the setting on the DVD player from auto scan (I think) from off to on and now when I...
It sounds like you may have enabled the progressive scan output on your DVD-VHS combo. This is a correct setting if your TV support it. However most DVD players that support progressive scan will not support an interlaced signal and a progressive signal at the same time.
It would appear that you are using a composite type cable (3 RCA ends. 1 for video and 2 for audio) for this hook up. This means you have two choices.
#1 Look in the manual for the unit for the FACTORY Reset option. Its usually a combination of plugging the unit in while holding the power button or something similar to that. Without a model # I can't help any further with this option.
#2 Use a component video cable (3 RCA red/green/blue) to plug your DVD/VHS player into a compatible input on your HD TV. Your TV will pick up the progressive scan output from the unit and give you back your on screen display. At this point you can go back into the menu and disable progressive scan. And now just reverse the process to plug the DVD player back in using the composite cable.
It should be noted that if you have a progressive scan TV which HD TV's support you will get a better picture if you use the Component video cables instead of switching back to the composite cable. If you decide to use the component cables you will still need to run audio cables though.
Best of luck.
Trevor
Aug 11, 2009 | GoVideo Go Video DVD/VCR Combo
How to set the "Progressive Scan" to "off"
I did the same thing. Hit progressive scan and now I have sound but no picture. I can't get to the menu to turn progressive scan off! Help!
Feb 23, 2009 | Sony DAV-SB100 System
Magnavox MDV560VR DVD/VCR combi
f you accidentally set Progressive Scan to ON (within
Analog TV), press STOP 9 for five seconds to restore the
picture to normal operation.
Aug 13, 2008 | Philips Magnavox DVD/VCR Dual Player
Zenith DVT412
If you are using analog video output to connect to your tv set and accidentally selected progressive scan from the setup menu you will loose the analog signal output.
Turn the unit on with no dvd inside and after the " no disc" message press stop (on the front pannel button) holding it for about 5 seconds. It will restore the original progressive scan configuration (value= no).
Jul 06, 2008 | Televison & Video
I'm not getting any color pictures in my home theater system
Well, assuming were talking about a dvd player with dvd's,you dont specify what type of cables you are using to conect it to your tv, it appears that it has something to do with Progressive Scan been turned on. Progressive Scan is a feature built in your dvd player, wich by using it, it would give you a better picture//resolution on your tv, you need to use Component or HDMI cables to hook up the dvd to your tv if you want this settings, but if you are using composite RCA cables (Red,White & Yellow) and the Progressive funtion is turned on by accident, it may give you a split screen, black & white, or no picture problems. Also if you are using Component (Blue, Green & Red) cables, if one of them is unplug, the picture can be out of colors, or no picture. Check this things, if not, write back with more details about your set up.
Thanks...
May 23, 2008 | Audio Players & Recorders
Cyberhome CH-DVD 300 DVD Player Logo
244 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
