Question about Parrot SA Parrot Ck3100 Lcd Handsfree Bluetooth Cellular Kit With Display
I've got a Parrot CK3100 with the connectors cut off both sets of the 8 speaker wires, any ideas to test which are the inputs and which are the outputs? Cheers
    Problem Solver:
  • 11 Answers
What?
Posted on Nov 07, 2012
5 Suggested Answers
dancandoit
  • 436 Answers
SOURCE: cannot pair up n95 with parrot ck3100
you willhave to send the contact manually to the parrot you can try making all but if this dont work you will have to send them one by one.
Posted on Jan 18, 2010
dancandoit
  • 436 Answers
SOURCE: Parrot CK3100 cutting out/Blank
try pushing the wire into the display, this commonly comes loose.
Posted on Feb 08, 2010
  • 95 Answers
SOURCE: Connected Parrot Ck3100 in Toyota Rav4 with Alpine
First, you will have to ensure that the vehicle doesn't have an amplified system build in it. Cause in that case the kit should use the two wires line in and line out and check behind the autoradio if you have the entries line in line out. (with this solution, no accessibility with the mute when you have the radio and you receive a call).
But the general idea is to ensure about the vehicle system build in it, cause with an amplified system, you have to avoid it to passing the sound directly to the speakers. (may be wires to wires or a specific harness which is taking acount of it).
Posted on Mar 17, 2010
SOURCE: how to wire my parrot ck3100 into a sprinter van
Hook up the 12v red on the parrot kit to the red/black on the iso connector.
The black goes to the brown on the iso.
The orange goes to the red/brown wire located in the middle of the previous wires.
That should be the power sorted out for you.
The tricky bit is the mute which I am currently working on, you can either cut off the black box and connect the red wire and blue wire to a speaker with the black connected to the mute wire. Or you could buy the correct iso adapter for around
Posted on Sep 13, 2010
My blackberry bold 9780 won't automatically connect to my parrot CK3100
when pairing your blackberry, the phone asked to accept connection, just below this there is a small box saying (dont ask again) you must tick this for auto connection. hope this helps
Jan 20, 2013 | Parrot CK3100 Advanced Bluetooth Handsfree...
IPhone not pairring with parrot ck3100: I pressed "forget this device"
remove other paired devices on your device, may be the device has crossed the limit of phones it can connect.
start pairing fresh on both devices- phone and bluetooth device.,
Jun 06, 2017 | Apple iPhone 4S
I have a parrot ck3100 and had it installed and it worked well for a day or so then it stopped audio from the parrot. It still says connected but no sound is heard from any function. Can anyone help?
If the parrot kit sound comes from your car speakers and your radio is working then the problem may be a wire in one of the connectors that are plugged into the Parrot blue box, I have seen wires pushing out when the plug is inserted.
Feb 27, 2011 | Parrot SA Parrot Ck3100 Lcd Handsfree...
My Parrot CK3100 will not seem to switch off when the ignition is turned off and the car is locked. The display seems to remain on 24x7 and now seems to be draining the car's battery. Any idea how to...
Hi there, my Parrot CK3100 screen just says "Goodbye" how do I switch it back to the Parrot symbol, so I can pair it up to my Samsung Wave via bluetooth. My phone is connected to the device, but the divice is not connecting to my phone?
Jan 24, 2011 | Parrot SA Parrot Ck3100 Lcd Handsfree...
How to wire my parrot ck3100 into a sprinter van can u give me the wiring diag as i dont have any connectors on my parrot kit as its from my old car im having trobule with the mute wires and speaker...
First, you will have to know if the vehicle has a facra or an iso norme build in it.
If it is a Facra, the wires to wires install is still possible but complicated and will necesarly need to get the diagram. Especially if the vehicle has an amplified system build in it. Or maybe optic fiber somewhere in the vehicle.
The vehicle has maybe an mute included into the autoradio, then the hot question you have is about the existing cable harness existing.
In that case I will advising you to get in touch with the manufacturer of the kit to get informed.
Aug 03, 2010 | Parrot SA Parrot Ck3100 Lcd Handsfree...
I have a new phone nokia 6303 and tried pairing with my parrot ck3100 and it will not connect. It asked for a passord on the phone I typed in 1234 but it comes back with pairing rejected by other device?
you need to go to settings / paired devices / delete any old phones that are still stored as the parrot will only allow 5 paired devices. then try again. You may want to check your software and if your software is over 12 months old it will be a good idea to update your parrot, try parrot.com/support for more.
Dan
Mar 02, 2010 | Parrot SA Parrot Ck3100 Lcd Handsfree...
Connected Parrot Ck3100 in Toyota Rav4 with Alpine 5897 aftermarket head unit. Tapped the Parrot harness into the speaker wire between the Front driver side speaker and amp, per instructions and phone...
Feb 27, 2010 | Parrot SA Parrot Ck3100 Lcd Handsfree...
Jan 19, 2010 | Parrot SA Parrot Ck3100 Lcd Handsfree...
Installation of Parrot hands free car kit - bluetooth
In the parrot kits I've seen, they insert a relay to switch the audio to the phone. This only works with 2 speakers generally. Your vehicle either has dedicated amp channels for each of the 3 speakers/door or the installer tapped into the wrong point. If it has individual amps for each speaker, they may need to force the amp to shut off to get it to mute the audio.
May 13, 2008 | Car Audio & Video
I can't connect Verizon Gleam SCH-U700 to Parrot CK3100
This solution came from Parrot Tech Support and it worked for me:
We were able to get the two to pair using the following steps:
The phone will stay saying pairing, then the parrot will say pairing successful, pull the battery on the phone, when you turn it back on, the phone will display PARROT CK3100 WANTS TO PAIR, ACCEPT? Say YES.
Mar 11, 2008 | Cell Phones
Parrot SA Parrot Ck3100 Lcd Handsfree Bluetooth Cellular Kit With Display Logo
90 people viewed this question
Top Parrot SA Cell Phones Experts
Al
Al
Miroslav Rusev
Miroslav Rusev
Are you a Parrot SA Cell Phone Expert? Answer questions, earn points and help others
