Question about Sharp LC-65D93U Television
Sharp Acquos power indicator flashing and won't turn back on
LC-65D93U lost power and then when atempting to turn set back on power indicator began blinking with no image. Tried unplugging and plugging back in but unsucessful
Power indicator blinking is an indication that the protection circuit inside the unit has been activated to prevent further damage. You may need to have the unit checked by qualified technician. Most probable cause is a damage component in the power supply circuit or those directly connected to it (mostly output component).
Posted on Jan 05, 2009
  • Merali456 May 28, 2012
    Did this work? I am having same problem.
Sharp aquos TV lc-42d64u has blinking power light
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Jun 07, 2016 | Sharp Televison & Video
Sharp Aquos LC-6OLE745U Blinking Code
2 fast blinks indicates a problem to its main power regulator circuit. If you wish to get more details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by its left side bar, or view it in Timeslide option.
Jul 07, 2013 | Sharp Aquos Televison & Video
Sharp Aquos LC-60E79U has flashing green power light and OPC light but won't turn on
Try to I unpluged the power, push volume and channel down, pluged power again
While it's flashing unplug your TV from the main power source for 15 seconds,Then press Valume Up and Channel Up, while holding it plug the TV back in, you should see the TV Turn on. How to Reset Your Sharp LCD TV TV Repair
Jun 15, 2013 | Televison & Video
Sharp model lc-20sh1u won't turn on, just makes a clicking sound and indicator light flashes red.
The clicking sound may be a power relay coming on and then off--problem indicates a trouble in the main power supply.
Nov 02, 2012 | Sharp LC-20SH3U 20 in. EDTV-Ready LCD...
Sharp lcd tv
Have you opened the set and looked for puffed up caps on the power supply board?
If puffed caps they need to be replaced and if set will not turn off--unplug for a while and plug back to see if it will reset itself.
Apr 04, 2012 | Televison & Video
Lc65d93u is not turning on. led blinks continously in blue. need your help.
count the number of times the led blinks and let me know. Do you hear any clicking from the back of the unit???
Sep 09, 2011 | Sharp LC-65D93U Television
LC-65D93U Sharp LCD not powering up just the blue light blinking
Our experience solving this was fairly long and I hope FixYa will excuse me for posting a link to it rather than copying all of it.
It's a free share of our experience and some hints on troubleshooting Sharp LC-65D93U with blinking power LED.
Of course your problem may be different, but the know-how we gained and share should still be of help in your quest:
http://blog.coppelltvrepair.com/2014/06/sharp-lc-65d93u-blinking-blue-led.html
Hope it helps!
Jul 05, 2011 | Sharp LC-65D93U Television
Sony 3 lcd rear projection tv hd w/ wega gate. kdf-e42a10. tv will atempt to turn, shuts down, greem power light blinks 12 times on average. red standby light blinks 4 times. i replaced lamp [ xl 2400...
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Mar 02, 2011 | Sony KDF-E42A10 42 in. LCD Television
My sharp LC-37d62u display problem
This problem very common in sharp tv.The POWER,OPC flashes.First turn on have power LED indicator light stable at all? Tries the power again couple times will have backlight come back on,than it will work.Not at all more than 5-6 times than ur main turner signal board is the problem,must replaced.
Jan 05, 2010 | Sharp LC 37D62U 37 in. LCD HDTV
Sharp LC-65D93U Television Logo
157 people viewed this question
Top Sharp Televison & Video Experts
Dave Naylor
Dave Naylor
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
