Question about Whynter WC-211DZ 21 Bottle Dual Temperature Zone Wine Cooler Stainles
The temperature reads 99degrees even thought the temp inside is as programmed therefore it runs continuously and never shuts off.
I have programmed the lower zone to 54 degrees. It seems to be holding that temp inside but due to the display reading 99 degrees the fan runs constantly and is in the cooling mode 100% of the time. I had to unplug the unit so my electric bill wont go through the roof. The upper zone does not have this problem.
2 Suggested Answers
  • 4736 Answers
SOURCE: My everstar portable ac is not running properly.
Ed, there are several things that can cause this problem, but all are solvable.
1. The current temperature setting is not low enough.
2. The air intake filter needs to be removed and cleaned.
3. The water collection tank is full and needs to be drained.
4. Obstruction in the exhaust hose(s).
Be sure to turn the unit OFF & unplug it, before attempting any service work on the unit.
Hope this helps you to troubleshoot & solve the problem. Thanks for choosing FixYa.
Posted on Sep 12, 2011
I have a Coleman Presidential II in my mobile home and it is summer time and I have my thermostat set to 76 and my unit keeps running even though my the temp is showing it is 72 in the house.
It could possibly be in the unit but my first guess would be in the tstat or the wire. If the compressor contactor was sticking the coil would freeze because I don't think the blower would continue to run. Check the wire near the unit for rodent damage or simply dry rotted. Therefore the wires are touching each other and not shutting off. Also be sure your tstat is not overshooting the set point because it is trying to get to your humidity set point. This is referred to as temperature droop. Also verify it does not have a minimum run time. Good luck
Jun 17, 2017 | Coleman Heating & Cooling
Beko sensordry 6kg gets hot on sensordry programs but won,t get hot on timed programs and keeps stopping and starting, any ideas please?
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.htmlGOD IS So GOOD !!!!
Feb 13, 2015 | Dryers
A/c runs for 10 min. then shuts off for 3 min. temp will not com down over 4 degrees.
Check the thermostat to ensure it is calling for cooling. If you are savvy disconnect all electrical energy from the A/C and jumper across the terminals of the temp control, if the A/C runs as is should you need a new control. You can also test it by setting a multi-meter to A/C volts and putting one lead each on the connections to the thermostat, if when the machine shuts down at a warmer than desired temperature and the meter reads volts it is open and not demanding cooling, replace it. if the thermostat continues to demand cooling but the machine shuts down call a tech, you may have a safety causing the shut down.
Sep 14, 2014 | Dometic Rooftop RV Air Conditioner
My dryer works fine...heats tumbles the timer just doesnt advance once it starts therefore the dryer wont turn off on its own
the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.htmlGOD IS So GOOD !!!! AND THAT'S WHY MY ADVICE IS FREE
Jul 11, 2014 | Whirlpool LEB6200 Electric Dryer
My Dometic thermostat reads -05 degrees on zone 1 for the inside temp.It is at least 80 degrees inside. When it reads -05 it won't let the AC kick on. Any ideas?
Instant thought- bad bateries in the stat! Second thought, bad Stat- sometimes they have intermitant problems, and being soldered PC boards with chips, relays, diodes, resistors, etc. they are not fixable nor tracable on intermitant problems, simply toss it & replace with a new one. The -05 leads me to believe the internal Thermister (electronic temperature sensor) is causing your problem, it sends the chip resitance values based on the temperature it's sensing- if it sends the wrong resistance value to the chip, the chip thinks the temp is different than it really is. Make sense? Hope this helps!
Mar 23, 2013 | Dometic Rooftop RV Air Conditioner
Car runs great until it get about 180 degrees andthen shuts off let it cool off a lil bit its starts back up until it shuts off again why
I am thinking that perhaps the temperature sensor is reading wrong and therefore sending a message to the computer that the car is running too hot. This can happen, my VW presently reads 20 hotter on the guage than a heat gun records at the temp sensor location on the head. If you have access to a heat gun it might be a good idea to check out the actual temperature, but it probably won't hurt to change the sensor.
The other problem that occurs to me is the oil sending sensor. While a temperature sensor won't shut an engine down, the oil sender can. If it is reading a large drop in oil pressure it will shut the engine off. Since oil gets thinner as it gets hot, perhaps a defective sending unit is reading it as too low. Once the oil cools off, it would restart until the temperature gets too high again. I would think that upgrading to a heavier oil might cure the problem. I don't know what you are currently usung but certainly you could go to 10W30 or 10W40 without too much trouble, at least for a test. Hope this helps.
Nov 17, 2011 | 2000 Chevrolet Cavalier
How hot should my onboard CPU temp. Run at and when is it to hot
40-49 degrees celcius (104-120F) is normal temperature for most systems. It is not uncommon to see higher temps when doing process intensive programs such as video games or encoding.
Sep 19, 2011 | Dell Computers & Internet
Outside fan and compressor does not shut off
the system is wrong, the blower must run continuously , and the compressor is the will stop if the temperature setting is reached. The outside fan is the same as the comp.
Jun 16, 2009 | Heating & Cooling
GE JKP26GOP1BG Electric Oven won't maintain temperature
You will need to replace the temp probe Call704-891-6557 we'll tell you how to do it safely.
Mar 14, 2009 | Ovens
Honeywell oil radiator
Press the *power button* once to start the heater on high power, continuous run. If left at this setting, the unit will run continuously on high power (1500 watts, 12.5 amps) and will not shut off until the unit is manually turned off.
Press the *power button* again, to change to low power, continuous run, (900 watts, 7.5 amps) and will not shut off until the unit is manually turned off.
Set temperature:
Press the temp/timer button until the temperature icon blinks. Use the up and down arrows to set the desired temperature.
The temperature icon will stop blinking and the current room temperature will reappear after the desired temperature is set.
The heater will turn off and on to achieve the desired temperature.
Set timer: (auto off)
Press the timer/timer button until the timer icon blinks. The hour display will appear. The auto off icon will also appear.
Use the up and down arrow buttons to set the heater operation time between 1 and 10 hours. This function will activate once the timer icon stops blinking. The heater will automatically turn off whn the times runs out.
Set timer: (auto on)
Press the temp/timer button until the timer icon blinks. The hour display will appear. The auto on icon will also appear.
Use the up and down arrow buttons to set the heater start time between 1 and 10 hours. This function will activate once the timer icon stops blinking.
The heater will automatically turn on when time expires.
Hope this helps!
Sep 24, 2007 | Honeywell /KAZ HOME ENVIRONME HZ-705 7Fin...
Whynter WC-211DZ 21 Bottle Dual Temperature Zone Wine Cooler Stainles Logo
48 people viewed this question
Top Whynter Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Whynter Furniture Expert? Answer questions, earn points and help others
