Question about Maytag Performa PAV2200
WASHER STOP OPERATING WHILE LOADING WATER - Maytag Performa PAV2200
    Top Expert:
  • Maytag Master
  • 9,472 Answers
Did it fill to the correct water level? Check the lid switch for continuity. Here is the lid switch to order in case you find it bad.
Posted on Nov 06, 2012
Washer won't stop filling with water
What's the model? Could be a bad water valve that's stuck. If it's an older top loading washer, it could be a bad air dome hose that senses water pressure.
Jan 12, 2014 | Maytag Washing Machines
Siemens Front Load Avant Garde Not loading water
Have you checked that there is water coming out of the connection without the machine pipe connected ? Close off the stop cock first before removing the machine pipe and then with with a bucket under the connection get someone to slowly open the stop cock to see if water flows. Most times the plumbing washer connectin has a built in valve ..... Is it on
Jan 08, 2014 | Siemens Washing Machines
Water dripping inside tub of washer when washer not in use
Your water inlet valve is not shutting off completely ,should be replaced if it fails completely it will flood and not stop seen it happen more then once
Feb 18, 2013 | Whirlpool Cabrio WTW5500XW Top Loading...
Water dripping
Turn the water off at supply valve, this will stop the water. Then you will need to replace the fill valves on the washer.
Jul 05, 2010 | Kenmore 24032\24036 Top Load Washer
My washer wont stop filling with water it will run over into floor it will agitate but water keeps running . it is a whirlpoot top loading.
you nead to check the plastic hose from the water leval switch to thbe outer tub.if line is good than you have a bad water leval switch.
Oct 29, 2009 | Whirlpool LSR5132PQ Top Load Washer
GE washer does not agitate does not stop filling up
If your washer is filling until it overflows without agitating, and will stop filling if you turn machine off or interupt power to it, the machine is not seeing that it is full. This may be caused by a blocked water level tube (usually some "goop" where it connects to the tub), a hole in the water level tube (look near the suspension rod or where a mouse may have chewed a hole in it), or a bad water level switch. You do not state a model number, or even if it is a top loading or front loading machine, so that is the most information I am able to provide at this point.
Oct 19, 2009 | GE Washing Machines
Kenmore 80 Series top loading washer--will not stop filling with water at the beginning of the wash cycle and for the rinse cyle. Is there an easy fix or should I purchase a new washer? How much can I
The pressure switch is failed - remove the tube from inside the top console area and blow it out. If you're lucky it will again work - with no charge.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 31, 2009 | Kenmore Washing Machines
Water Overflow
hi there,
i would recommend checking the water level switch or lid switch and also the cable leading to it. that is what sends a signal to the machine control to stop filling with water.
Oct 10, 2008 | Whirlpool LSR7333 Top Load Washer
Washer filling up with to much water
is your printer front loading or top loading?
the prob is in the pressure switch or in the pressure hose, usually the hose is clogged up and fails to produce enough presure to activate the switch to shutdown all solenoid to stop the water from overflowing.
if you can open up you unit you can see a small hose 1/2 " trace the bottom hose until you find the clogged part, you can remove and clean this if not you can order a new one for immediate replacement.
if this is a top loading this is much simplier
Aug 16, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
15 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
