Question about Vacuums
Bissell pro heat 2x belt keeps snapping in half i have cleaned the brushes and stuff but it continues to do it
  • Lillian McCarty Nov 11, 2012
    I shampoo some of the carpet and then take it apart and clean all the parts rollers, belts, exc. and then i start shampooing it again and do it all over again when i do this i am able to look at the belt too. It still broke
    Top Expert:
  • Vacuums Master
  • 14,553 Answers
If hair etc bound to roller look for and remove that--make sure using correct belt and where it engages shaft the end is clean (black belt residue will cause belt to slip and early failure).
Posted on Nov 06, 2012
4 Suggested Answers
SOURCE: Bissell Pro Heat 2x steam cleaner, problems!
I took the side plastic protectors off because my brushes stopped working. I found one belt almost broken (held together by the fiber to the interior) and when I moved the brush rollers, I found mucho dog hair on the ends. Your rollers might be removed and see if you have the same problem. IT just takes two screws on each end to do this, so if your belts are good, take a look at each end where the metal post goes into it. I have two dogs and their hair is just everywhere!
Posted on Jun 25, 2008
  • 36 Answers
SOURCE: I have a Bissell Pro Heat 2X carpet cleaner and
The reason for the brushes to stop when it is above any surface is there is a switch in the handle that stops the brushes so it dont burn your motor up it may have a faulty switch.
Posted on Jul 31, 2009
  • 17 Answers
SOURCE: my bissell pro heat 2x will not spray water to
Here is the fix
Posted on Feb 08, 2010
Hi my Bissell pro heat 2x the brushes don't turn and nothing come out like the water what to do
Bissell 2X machines are famous for this. The brushes not turning is probably just a broken belt but the not spraying is a bad solenoid. I've never seen a 2X that didn't fail after about 6- 8 uses
Jul 02, 2017 | Bissell Vacuums
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
Bissell pro heat 2x brushes are not turning???
Brushes are controlled by belts. They must have come off or broke.
Sep 27, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell Pro heat stopped working
It sounds to me like you may have a bad brush and/or pump belt. Since you are having a simultaneous problem of the brushes not spinning, as well as the solution not spraying, this is the most logical explanation of your problem. Especially if the machine was being used on stairs, this could pop the belt off if the brushes were continuing to be run.
This will be the easiest repair on the machine, and hopefully this will take care of it. If it doesn't, there are a handful of other things that it could be, but let's hope that it's simple and just the belt(s).
What you'll want to do is open up the machine to inspect the belts and make sure that both are in place, and not off the machine.
Here's a link to a helpful video that will show you exactly how to open up the machine to check and make sure that the belt is installed.
MAKE SURE THE VACUUM IS UNPLUGGED.
http://www.bissell.com/VideoRating.aspx?id=1555
Please try this first, and if this does not fix the carpet extractor, I can walk you through some more advanced diagnosing. Just to make sure that we are on the same page, can you also please give me the exact model number of your Bissell? You may find this number on the back, or the bottom of the steamer. You had listed this repair under the Bissell ProHeat 2X 9500, but I'd like to just confirm with you that this is actually your model so I can give you the proper diagnosis. How old is the machine also?
I look forward to working with you to get this resolved. If this was helpful, please be so kind and rate my repair as helpful by clicking the 4 thumbs up icons in the top right hand corner. This is really what keeps repair professionals like myself coming back and providing free repair services. It's greatly appreciated.
Chris J.
GoVacuum.com
Apr 14, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissel pro heat unit brushes will not engage
keep in mind they only turn when the handle is down. if that is not the problem, it is usually the belt.
David
May 24, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell pro heat 2x multi surface carpet cleaner making spots
maybe there's not enough vacuum or it hasn't been primed enough. I have a proheat that drove me crazy till I started leaving the heat switch on. I get wads of carpet fiber that mat around brush and spit out on the carpet, so I frequently remove them. I'm just wondering if after you empty the water, it may not have built up the suction. Good luck! hope this may be helpful
Jan 13, 2009 | Bissell 1699 ProHeat Clear View Upright...
Bissell Pro heat 9500 2X
I had this same problem, even went out and bought a second machine, same problem. Here was my problem....I was checking the brushes while the handle thingie was in the upright position. You have to be sure and RELEASE THE HANDLE. Now i have 2 perfectly good Bissells.
Jan 04, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Must likely the brush motor is bad. The top cover has to come off to check it, this is where the tank sits on. Part # 2036757 and is #35 in the pix.
Mar 14, 2008 | Vacuums
Vacuums Logo
32 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
