Question about Sony STR-DE475 Receiver
I want to set up my surround sound i need to know what the cable looks like for digital in and video in looks like is it a fiber optic
    President:
  • 948 Answers
That is called a TOSLink cable, it is indeed fiber optic. It is for digital audio only, video is carried by HDMI (which also carries digital audio), component video cables, S-video cable, coaxial cable, or RCA jacks.
For your surround sound from a DVD player, connect your digital audio from the DVD to the receiver's input, then the video out from the DVD to the receiver's input. Now the video out from the receiver goes to the TV and the surround sound should now be coming through your speakers. Post again in this thread if you need more help or explanation.
Posted on Jan 05, 2009
In 5.1 creative music system only two are working.
Verify the media you're playing is coded for 5.1 surround (bluray or DVD with 5.1).
If it is, you'll need to go into the sound settings and go through all the settings in there for your sound card, to be sure it will push the appropriate codec (5.1, 7.1, stereo, mono, etc.) out the output.
Verify you are pushing the sound through either an HDMI cable, digital coax cable, or fiber optic cable. Regular RCA jacks will only push stereo (2 speaker).
I couldn't get all my speakers to kick on through my Harman/Kardon until I made my PC force Dolby Digital through the fiber optic cable.
Oct 21, 2013 | Audio Players & Recorders
Not getting sound thru speakers only tv with hdmi cable connected do I need to connect Digital fiber optic cable too Also able to download owners manual for vsx1017txv
Receivers of this complexity require some patience. I believe the HDMI on this receiver is only for on screen display and video pass through. The audio needs to be separately connected. For digital audio you need to connect either via the digital audio coax or fiber optic input. I replaced my entire 1980s audio system with this unit and have been very happy. It's compact, and I feed it everything via a 35' fiber optic cable (under $20!) tied to a 3-way passive fiber switch (under $10) connected to my computer, a Tivo, and a DVD player. Sounds amazing (make sure to run set up to get the unit to perform with all of your speakers! -- I use an 8 speaker 7.1 surround set up).
Jun 17, 2010 | Pioneer VSX-1017TXV-K - iPod Ready, XM...
I have a LG plasma, do i need a optical digital audio out cord to use surround sound?
In order to get true 5.1 surround sound you need to use either digital optical (fiber optic) cord or digital coax cord(RCA style ends) to link between your TV and your digital source such as DVD,digital cable box,digital satelitte receiver.You can route the audio through the TV but that's not the best way to go,I recommend going directly from the digital source to your surround sound receiver for optimum sound. Good luck !
Nov 29, 2009 | LG 42PX5D 42 in. Plasma HDTV
Looking for a diagram on how to hook up my dish network box to my STR-de597
There is a wiring diagram PDF posted on Sony's support site. However it lacks a configuration for a satellite receiver. Without knowing your particular Dish setup, I'd say use the Component video cables and a fiber optic for the audio if you can. Otherwise, the component video and coaxial cables are your next best choice to get decent video and surround capability.
In both cases, you need 2 sets of video cables One for the in and another for the out. You only need 1 fiber optic or coaxial for audio if you do not plan on running the TV speaker system. Use the video 2 inputs for either video type.
Oct 27, 2009 | Sony STR-DE597 Receiver
Problems with hearing sound from bravia LCD tv through bravia DAV-HDX275 theatre system
The fiber optic port on back on your bravia tv is only for when your using a over the air antenna and watching local atsc channels in your local market. You need to run the fiber optic from your hd cablebox if it has one or your hd sat box if it has one. If you don't have a set top box with the fiberoptic port on it you can use a digital coax cable from the cable or sat box to sound system. The only other way to get sound if you don't have a cable or sat box is to run the red and white rca audio cable from the tv to the sound system and got to the audio setup on tv and turn the tv speakers off and you might have to adjust the audio to fixed instead of variable.
Nov 05, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
Cannot get sound from tv to surround sound speakers
you will need to connenct audio cables red and white from audio out on tv or from programming source(cable box sat box) to the audio in on back of jvc unit. then set unit to appropiate source (where you connect cables on back of unit it will be labaled and remote will have button to get to that connection labeled the same) if you want to get digital sound you will need and digital coaxial or fiber optical cable from source(cable box or sat box) and then set unit to video 1 for coaxial and video 2 for optical
Oct 22, 2008 | JVC THD-50 System
I hooked up a fiber optic cable directly from a samsung hdtv to my onkyo surround sound system. Sound, however, does not come out of the speakers. Also, I am running cable directly to the tv from the wall...
Make sure that the place it is plugged into the TV is an output and not an input for the fiber optic cable, and the place it is plugged into the Onkyo is an input and an output for the fiber optic cable. This can be connected backwards very easy. Then you want to make sure that the Onkyo is properly set on the right function to listen to the TV. Check your owners manual on how to set up the optical input and have it assigned to the function you are trying to use. Sometimes these type of receivers have an input mode button that you can set to "optical" or "analog" or "digital" or "auto". Try changing those settings after you make sure the TV optical is an "OUTPUT" and the optical on the Onkyo is a "INPUT".
After you have these thing set right you should be able to listen to it like this.
I hope this helps, if you need more help just reply back on this post, but please give more detail about the connectors and on the TV and the Onkyo, and about the digital input settings on the Onkyo. It would also help to know the model numbers of both the TV and the receiver. There is no way to check out what each of your devices are capable of doing without knowing the model numbers to look up the specs.
Thanks,
Dave
Sep 07, 2008 | Onkyo Audio Players & Recorders
Yamaha HTR 5740 no surround sound with DVD
i have the htr 5230 and i had the same prob ... are you using fiber optic ??? try the effects like pro logic. or 5.1
Sep 23, 2007 | Audio Players & Recorders
Connecting tv/dvd combo to reciever to obtain surround sound
look for a connector that reads "Optical"..if none, then not supported.
Jun 08, 2007 | Technics SA-AX530 Receiver
Sony STR-DE475 Receiver Logo
112 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
