Question about Vacuums
Bissell pro heat 2x belt keeps breaking - Vacuums
    Top Expert:
  • Vacuums Master
  • 14,553 Answers
Check for roller bound up and shaft belt attaches to being covered in black belt residue--position of belt may be critical here.
Posted on Nov 06, 2012
reddevil6
  • 1673 Answers
SOURCE: Bissell Pro Heat Turbo 2X
Here are things to check when there is no spray from hose or nozzles.
• tanks are not sealed into receivers
• faulty auto load receiver
• pinched/clogged line
• defective component allowing air into system
• pump not mounted so it can move freely
• defective bridge rectifier
• clogged heater
• defective pump
• defective circuit board
Posted on Jun 03, 2008
SOURCE: Bissell Pro Heat 2x steam cleaner, problems!
I took the side plastic protectors off because my brushes stopped working. I found one belt almost broken (held together by the fiber to the interior) and when I moved the brush rollers, I found mucho dog hair on the ends. Your rollers might be removed and see if you have the same problem. IT just takes two screws on each end to do this, so if your belts are good, take a look at each end where the metal post goes into it. I have two dogs and their hair is just everywhere!
Posted on Jun 25, 2008
SOURCE: My Bissell Pro-Heat 2x 12
my bissell 9200 won't release water or solution when the trigger is pulled.
Posted on Nov 20, 2008
  • 120 Answers
SOURCE: My Bissell Pro Heat 2X will not release water or
its probably a solenoid that controls the flow to the floor, take it to a bissell repair center, because its not an easy fix.
Posted on Jul 06, 2009
  • 17 Answers
SOURCE: my bissell pro heat 2x will not spray water to
Here is the fix
Posted on Feb 08, 2010
Hi my Bissell pro heat 2x the brushes don't turn and nothing come out like the water what to do
Bissell 2X machines are famous for this. The brushes not turning is probably just a broken belt but the not spraying is a bad solenoid. I've never seen a 2X that didn't fail after about 6- 8 uses
Jul 02, 2017 | Bissell Vacuums
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
Bissell pro heat 2x belt keeps snapping in half i have cleaned the brushes and stuff but it continues to do it
If hair etc bound to roller look for and remove that--make sure using correct belt and where it engages shaft the end is clean (black belt residue will cause belt to slip and early failure).
Nov 06, 2012 | Vacuums
Bissell pro heat 2x brushes are not turning???
Brushes are controlled by belts. They must have come off or broke.
Sep 27, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Want to use Bissell Pro Heat 2X Clean Shot. Have
You can download a user manual from the Bissell website
Sep 15, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
I need instructions for bissell pro heat 2x cleaner
you can dawnload it from the manufacture,s website.you should go to there and dawnload it.
Sep 11, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Jul 02, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
Vacuums Logo
101 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
