Question about Kodak EasyShare DX6490 Digital Camera
I have a scratched lens. Can a new lens be bought?
I dropped the camera. Camera is still working but the lens fell out and was scratched. Can a new lens be purchased? I have a kodak easyshare dx6490
    Genius:
  • Kodak Master
  • 1,019 Answers
Hello, I have several of these cameras myself and really like them,but the problem is the cost to repair would exceed the cost of a newer camera that you could purchase on E-Bay. Check it out and you can get a nice used camera.Hope this helps.
RUSS
Posted on Jan 23, 2013
  • 979 Answers
SOURCE: Kodak Easyshare M753 Camera LCD vertical purple lines bad focus
There is no hope for the display..Plan on spending about 50 - 70 dollars for a new TFT display.
Posted on Dec 02, 2008
sandipmistry
  • 56 Answers
SOURCE: lens problems
there is a problem wit your lens section, get it repaired with your company professionals. Your camera may be fallen or being pressed from front side by someone. The new ZOOM will give the same best result and no further problems.
Posted on Apr 24, 2009
t00nz
  • 4738 Answers
SOURCE: kodak camera dropped lens cockeyed stuck open
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on May 05, 2009
  • 11967 Answers
SOURCE: Kodak easyshare lens error
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move. The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason. A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth. Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods. The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired: Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on. Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time. Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera. Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots. Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one). Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes. Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens. Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on May 06, 2010
lock123
  • 6831 Answers
SOURCE: kodak easyshare ls743. lens wont retract. camera error #E45 shows on screen. battery is fully charged.
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Dec 14, 2010
Nikon d3000
did you try a different lens if you did send your camera in for repair . the lens gets damaged easy
Feb 07, 2013 | Nikon D3000 Digital Camera
Nikon coolpix s8100 lens error lens won't retract
Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them.
Sep 07, 2011 | Nikon S8100 Digital Camera
I bought my new Fujifilm finepix JX360 today, and i accidently dropped my camera on my decking, the lens then slanted and fell off, ive been frantically trying to put the lens back on but its not working!...
You have a damaged lens
If your camera is still under warranty, I will repair it for 35.00. If it is out of warranty, then I will fix it for 165.00
call Continental Photo, 718-268-6440 Mon - Sat 10am - 6pm, ask for vic
Jul 31, 2011 | Fuji Cameras
My Nikon d40x is roughly three years old and the lens has had to have been repaired twice due to it being dropped. Lens is working fine though now. Yesterday i was getting out my car and the camera fell...
Time for some "tough love"...suggest you buy one of the new Pentax point-and-shoots that are especially made for people who continually drop their cameras. This one can be dropped from 3 feet and still work. Leave the good DSLRs to the rest of us.
Jul 11, 2010 | Nikon D40x Digital Camera
My camera dropped and both lens fell out need to reasemble
It does not pay to fix this camera. This camera can be bought on Amazon for about $55. A brand new camera with specifications that blow away the Olympus can be bought for less than $100.
Sorry for not instructing you on repairing this camera, but you won't find any reputable person that would repair it.
Jul 29, 2009 | Olympus Cameras
My neice's camera fell onto a tiled floor when the zoom lens was out and now it is bent and the camera doesn't turn on or off is this fixable?
Nope.. they are disposable.. My son worked in a camera store and that was the best "new purchase" feature, a dropped camera.
Jul 23, 2009 | Cameras
Lens locked in open position after batteries fell out
mine sometimes does that. 1.get a new cheaper camera. 2. use duck tape 2 secure the door.
Jan 26, 2009 | Kodak EasyShare CX4230 Digital Camera
Lens focusing problem
Dropping a camera is no laughing matter.  I assume you have severely damaged the wide angle lens, and the only solution I have it to purchase another one.   Certainly if the front element fell out that is serious and there are probably other things wrong with the lens, and continued use of it could damage the camera body.   Just be more careful and chock it up to experience and buy a new lens. Sorry to hear about your accident.   Good luck.
Apr 13, 2008 | Nikon D40x Digital Camera
Dropped my camera canon sd450
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but they're worth a try:
Feb 17, 2008 | Canon IXUS V2 Digital Camera
Lens error
your lens are stuck! did you drop the camera? you need to get a repair on the lens
Jan 10, 2008 | Nikon COOLPIX L3 Digital Camera
Kodak EasyShare DX6490 Digital Camera Logo
50 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
