Question about Refrigerators
What is the fridge only capacity of my whirlpool fridge model GS2SHEXNS02?
I have space for a 64in.height,32 in. width,26 in. depth refrigerator. What size in cubic feet should I get?
Well, these measurements will limit the outside of the cabinet. The size of fridges almost always refers to the inside capacity. The relationship between the two varies a little from model to model. For instance if you get one with an ice maker, the inside capacity is less, but the outside is the same as the same fridge without ice.
You could buy for instance a Whirlpool 14 cu ft top mount freezer model, which is 63" h x 28" w x 26" d. The 18 cu ft is too big. Another possibility is the Frigidaire 14 cu ft.
Nov 13, 2015 | Refrigerators
Freezer not working whirlpool model gd25dixb02 also puddle of water coming out from under.
IF it started leaking after you turned the fridge off - you have problem with defrost system.
OTHERWISE you have problem with the sealed system or compressor start device. I will cover the latter only.
First, read this recall, check your serial number and call Whirlpool if necessary.
If your fridge is not affected by the recall and the fridge started leaking while still running:
Check the start device first. If there is clicking noise every few minutes - this is what you need to know. Unplug fridge. Remove cover on the back of fridge. On compressor (black roundish metal thingy with copper tubing coming out of it) there is a start device with wires coming to it. Remove from compressor, turn it contacts side down and shake it a few seconds in your palm. If small pieces, looking like sand fall out or you can hear those pieces loose inside the start device - replace it.
This is the part you need: 8201799 Installation instructions are enclosed
"New10" coupon takes 10% off on that site.
If your start device is ok - check the capacitor, which is either attached or wired with black wires to the start device. Check if its capacity is close to whatever is printed on it. Replace if capacity is way off, capacitor shorted or open. That part is here. It's very unlikely that you'll need to replace it.
If both things are ok, you may have a problem with compressor or refrigerant or refrigerant lines, which you cannot legally touch without an EPA license for refrigerants handling.
Oct 25, 2009 | Refrigerators
New whirlpool refrig. freezer ok at 0 but refrig
The freezer get the first crack at cooling and combination units have a fan and adjustable vents to steal some of the cooling capacity for the refrigerator. The vent are normally located in the back of the refrigerator compartment and with these, you can balance the cooling capacity between freezer and fridge. I recommend you swap your thermometer back and forth until you get the balance you want; typically the freezer should be at 5 degrees F or below and the fridge at 35-40 degrees F. Adjusting the control for temperature and having the vents set to supply the cold air you want in each compartment should give you the range you want in each.
Sep 09, 2009 | Whirlpool Freezers
Whirlpool fridge incessant buzzing
The knocking noise when cuts off , is a compressor internal motor support spring , broken . This does not mean the compressor is bad , only noisy for the rest of the compressor life , but should be covered under the 5 yr warranty . The gurgling sound is the refrigerant being pumped thru the system . The buzzing could be from the compressor also . My suggestion , would be to call a factory warranty company , to see if they can replace the compressor under warranty .
Sep 07, 2009 | Refrigerators
Hello, RE a 1980 Kenmore 20821 Large capacity washer 1) the machine does not extract fully. I have tightened the belt which was loose but that has not corrected the problems. Also, I would like to know...
I would you recommend you make a burial date for that machine. The best ones out right now are whirlpool, or one of their models like roper etc... just get the standard models. I do not recommend front load models. This goes the same for the Fridge. The better one out is whirlpool, maytag and the other models are having a bad compressor issues... let me know if i can be more assist to you.
Apr 26, 2009 | Kenmore Washing Machines
Need Cubic Foot Capacity of this refrigerator please
Find a five year old child with a tape measure
and ask the child to measure the inside of the fridge
then width x lenght x hight = result
Then give child a lollie
Apr 16, 2009 | Refrigerators
What is capacity of my whirlpool LEQ9858LW0 dryer?
try whirlpool.com should be able to find your model and info
Mar 26, 2009 | Whirlpool LEQ9858L Electric Dryer
Light won't light in fridge, circuit is buzzing
Pull the switch at the front door. Take off the 2 wires and put them together. No light then, Live chat me. If this has proven help, please list as fixya
Jan 10, 2009 | Whirlpool Gold Series GI15NDXT 15"...
Refrigerators Logo
20 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
