Question about Epson Stylus CX9300F Series
How do i reset waste ink pad for epson CX9300F?
Printer will not operate
  • 23 Answers
SOURCE: How do I reset the waste ink counter on an Epson
I don't know if this works but i have the same printer, if mine displays the same fault I might start looking here!
http://www.youtube.com/watch?v=mLXZ30vD988&NR=1
Posted on Feb 03, 2011
Inky
  • 691 Answers
SOURCE: Epson Stylus Photo R320
Turn off the power and look inside the machine to the right hand side. Just in front to f the print head you will see a white plastic dowel (see photo). Use something technical - like a finger, pen or screwdriver - to push this dowel in. You can then move the print head by hand to the middle of the carriage.
Once moved, turn the printer on and watch it travel back to the home position. If after returning home the dowel pops back out and does not retract itself, you will need to strip the machine out and rebuild the ASF section. Sounds hard but its just a few plastic parts to take apart and reassemble whilst looking to see if anything is broken.
Get a service manual; for the machine HERE if you need to strip it out.
Posted on Sep 19, 2008
Nic61
  • 1073 Answers
SOURCE: Epson rx620-waste ink pad replacement Instructions
No Problems M8!
Here is the manual for your printer
http://files.support.epson.com/pdf/rx620_/rx620_qr.pdf
Good luck to you
If you find my answer helpfull, dont forget to vote!
Posted on Dec 18, 2008
SOURCE: Need To Replace The Waste Ink Pad on my Epson Stylus C66
I modified a little what Worldvet had done. I opened the door as if to change the ink cartridges. I first used a pair of needle nosed pliers and carefully took out the sponge type pad which is along bottom of the printhead travel lane. One will see the two center plactic guides within this lane. The sponge is very delicate, so be very gentle in removing it. It has ink residue in it so use gloves if necessary and upon removal place the sponge on a paper towel folded in triplicate so the ink does not bleed through the towel. Remember to what position it was before removal, so there is no problem when you try to replace the sponge after cleaning.
The second sponge I removed as follows: With the power on, I pressed the ink cartridge removal light (red) (far left) once. This moved the print head to the "far left", before the position to change cartridges. With the power still on and the printhead to the far left, I was able to very gently (with the same needlenose Pliers) remove the sponge under where the printhead was parked. It too is very delicate and be careful not to rip it. It too, one will find, has two plastic slots on the botton which the sponge will have to be returned into. I then turned the printer off, which caused the printer head to return to the parked position.
I took both sponges, and with Alcohol (Pharmacy type), I placed the sponges in a disposable plastic bowl and filled it with the alcohol. I gently used the needle nosed pliers (Closed) as a device to gently press on the sponges which were submerged into the alcohol. I continued to alternate up and down the sponge pads, causing the alcohol to dilute and clean the pads. When the alcohol became saturated with the ink from the pads, I took the pads out of the alcohol bowl and placed the pads on a triple folded paper towel so the remaining ink would not bleed through anything.
I then took the bowl of alcohol/ink and while I flushed the toilet and the water was going down, I emptied the alcohol down the middle of the water spout as the toilet water was completing its flush. This keeps any ink from touching any porcelion.
I then refilled the plastic bowl again with fresh alcohol and resubmersed the pads, just incase there was any ink still left in them. Upon pressing on the pads and the alcohol remained clear (indicating all the ink was removed) I again used another set of paper towels, trippled, and placed the pads onto the paper towels, and squezzed them dry. I disposed of the alcohol the same as before.
I then, first replaced the large pad onto the printhead travel lane, back into the same position, being careful that the holes and slots fits back into its proper position and the edges are tucked under the proper hooks (little plastic hooks attached to the side of the travel lane).
Upon reinstallation I pressed gently on the pad to make sure it was secure.
Replacing the second pad, I again turned on the printer and pressed the ink replacement light (red), same as before, causing the printhead to travel to the far left as before. I then very carefully replaced the second pad into the slot from which it came from.
After I made sure the second pad was secure in its proper position, I pressed the ink replacement light twice, causing the printhead to return back to the parking position. I had already reset the counter, so that was not neccessary. I returned to the computer and printed a test page to make sure the printer was working properly, at which time it was, so I therefore returned to what I was doing and the Service Warning was cleared. My fingers got a little ink; but what the heck, soap will take care of that! Good for another 20,000 pages. Hope this helps, not as bad a it sounds.
Posted on Mar 26, 2009
tigertail
  • 163 Answers
SOURCE: waste ink pad saturated. EPSON STYLUS PHOTO R360
Replacing the pads is costly, messy and requires the printer to be taken completely apart. If you have little or no experience of stripping down printers it is best left to a proffessional. Contact Epson to find your nearest service centre, but remember to get a quote as it may be more economical to replace the printer. Sometimes the counter can "jump" to the end of life number, this especially happens where 3rd party or refilled inks have been used. If you believe this to be the case and there is no sign of ink leakage and the pads look fairly clean then you can just reset the counter using special software called the SSC utility. See these sites:
http://www.ssclg.com/epsone.shtml
http://inkjetprinterhelp.us/epsonSSC.html
More information about this issue and the "official" Epson resetter is available from the Epson web site, please read this link:
http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp
Please take a moment to rate this solution. Thanks.
Posted on Apr 14, 2009
How do I reset the waste ink pad on my Epson Discproducer PP-100
The most easy way to reset Epson PP-100 Waste Ink Pads is to use WIC Reset Utility and reset waste ink counters by Yourself.
There is video tutorial on Youtube - How to reset Epson PP-100 Waste Ink Pads Counters:
Jul 03, 2014 | Epson Office Equipment & Supplies
Tip
How To Reset Ink Counter On An Epson CX7300, CX8300 or CX9300
You must set the date in your computer to "April 11, 2008" to run Resetter Epson CX7300, Epson CX8300 and Epson CX9300 without error. If do not alter the setting of date of according to rule then software will deleted automatically when running.<br /><br />If you have an error, delete all following entry before you rerun the software.<br /><br />delete registry key: <span style="font-weight: bold;">HKEY_LOCAL_MACHINE\SOFTWARE\EPSON\PTSG</span><br /><br />and delete folder: <span style="font-weight: bold;">C:\adjustment program</span><br /><br />To reset waste ink pad counter Epson CX7300, CX8300 and CX9300F use adjustment program. I have tried this software and this software worked. To run this software without error please follow the instructions above.<br /><br />Here How to use this software:<br /> <ol> <li>Download the adjustment program (see below)</li> <li>Extract the file you have downloaded</li> <li>Go to The extracted folder then click tricks-collections.bat file</li> <li>Now set the date setting in you PC to 11 April 2008,</li> <li>Run adjustment program by click AdjProg.exe file the click accept</li> <li>Click Particular adjustment mode then select destination and printer port then click OK</li> <li>Select Waste ink pad counter from the below window and double-click to execute it</li> <li>Click [Check] button to check current protection counter's value.</li> <li>Then Click [Initialization] to reset the protection counter to the initial value.</li> <li>After finishing, you can change the date back to normal.</li></ol><b><br />Link Adjustment program for Epson CX7300, CX8300 and CX9300F</b> <ul> <li> Adjustment program for epson CX7300: <a href="http://www.mediafire.com/?8wrkugah2mj">http://www.mediafire.com/?8wrkugah2mj</a></li> <li> Adjustment program for epson CX8300: <a href="http://www.mediafire.com/?0xfnrgarvuj">http://www.mediafire.com/?0xfnrgarvuj</a></li> <li> Adjustment program for epson CX9300F: <a href="http://www.mediafire.com/?o020wlaf6te">http://www.mediafire.com/?o020wlaf6te</a></li></ul> <br />
on Mar 09, 2011 | Office Equipment & Supplies
Wast ink counter epson stylus cx 9300f rest
Extrak adjustment you have downloaded
Go to The extrakded folder then click tricks-collections.bat file
Then Click [Initialization] to reset the protection counter to the initial value. Thats all.
After finishing, you can change the date to normal.
Link Adjustment program for epson CX7300, CX8300 and CX9300F
Adjustment program for epson CX7300 : http://www.mediafire.com/?8wrkugah2mj
Adjustment program for epson CX8300 : http://www.mediafire.com/?0xfnrgarvuj
Adjustment program for epson CX9300F : http://www.mediafire.com/?o020wlaf6te
Jul 29, 2012 | Epson Stylus Multifunction Inkjet Printer/...
EPSON STYLUS T13 printer's ink pads are at the end of their service life HOW TO RESET FREE
Apr 26, 2011 | Epson Printer
I have a problem with my printer epson stylus C90. may i know what todo when parts of my printer are near the end of their life service.?how can i fix it?
It means waste ink pad full or nearly full. Reset waste ink counter using SSC ver 4.30. Find at indoreset.blogspot.com. Don' forget to replace pad, washing or extend outlite pipe to outside of printer.
Jul 23, 2009 | Epson Office Equipment & Supplies
Epson stylus c45
most problem with printers are dirt inside. if you want to experiment, try opening the printer, usually held by snaps, if accomplished clean all contacts, cables ribbon wires, then reassemble. thats easier said than done.
Jul 07, 2009 | Epson Stylus C46 InkJet Printer
Printer won't printer as message says parts are
Part are end life cycle : waste ink pad full. Need to reset waste ink counter. SSc ver 4.3 support RX 620 and 640. U can try using printer model RX 640. Menu Protection Counter, Show current value for checking. Reset protection counter. Or Try to find RX630 adjusment at indoreset,blogspot.com. Don't forget to replace or wash the pad. Or extend outlet waste ink pipe to outside.
Jun 28, 2009 | Epson RX620 All-In-One InkJet Photo...
Reset waste ink counter on Epson C60 printer
If both lights are flashing, it means the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can restore your printer to a working condition immediately by using the SSC utility - download from
and use it to reset the Protection Counter. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help.
Feb 24, 2009 | Epson Stylus C60 InkJet Printer
Epson stylus 830Uink pads full not printing help
The Waste Ink Pads in your printer are saturated with ink and the waste ink counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility - download from
and reset the Protection Counter. This will stop the lights flashing and restore normal operation. However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. Should you decide to have a go at changing the waste ink pads, the 830 service manual can be downloaded from here:
http://www.mediafire.com/?m6ouftizois
Jul 13, 2008 | Epson Stylus Photo 820 InkJet Printer
Waste ink pad
to Reset Waste Ink Counter
  • RUN AdjProg.exe file Epson C90
  • choose Particular adjustment mode
  • select waste Ink pad counter
  • Klikinitialization
That’ all!
Jun 01, 2008 | Epson AcuLaser C900 Printer
Computers & Internet Logo
486 people viewed this question
Top Epson Computers & Internet Experts
teamtech
teamtech
Are you an Epson Computer and Internet Expert? Answer questions, earn points and help others
