Question about Maytag MER5775Q Electric Kitchen Range
Maytag range oven does't work
The oven doesn't work and the control panel won't even light up
Unplug the stove and remove back panel, check to see if you have some burnt wires. If so, you can replace them with electrical wire and new marrets. But before you do that, check to see if your timer is on.
Posted on Jan 05, 2009
I have a gas stove/oven the ignitors to the top clicks but doesn't spark and the oven doesn't work at all?maytag performance
Number 13 and 22 is the parts I suspect.
13 is the ignitor which even if it glows could be weak, It must pull at least 3.5 amps to open the gas safety valve. The spark module(number 22) could also be weak and not putting out enough juice to light them burners. Seen it.
Sep 18, 2011 | Maytag MGS5770 Gas Kitchen Range
I have a Maytag gas stove model MGR5730BDW. The oven won't light. The broiler works just fine. The bottom ingiter glows orange and gets hot but the burner won't light.
Hello, Thank You for using FixYa. I will be helping you today.Just because the ignitor glows does not mean its good..switch the two around and see if the oven comes on. They still glow even when they start to go bad.
Thank You and please rate my answer if it was helpful..
Jun 16, 2011 | Maytag 30" Self-Cleaning Freestanding Gas...
Where are the fuses on maytag mer5752acw electric stove panel is dark oven won,t work only the oven light does.
This factory service manual will help you.
First,verify 220 volts to the range at the terminal block on the rear where the cord connects.
http://servicematters.com/maytag_library/docs/16025644.pdf
Oct 03, 2010 | Kitchen Ranges
Oven & broiler not heating on our Maytag MER5530. Lights on the control panel indicate it should be working. When I set oven temp, the oven "thinks" it's at that temp already. Turn broiler on and no...
May be the heating coil is bust?
The control panel is in parallel usually so as long as the controls are getting power they will turn on. But if the coil is gone you wont get heat. If you want to try fixing it, you may need a multimeter, or a continuity tester.
Jul 08, 2009 | Maytag MER5530 Electric Kitchen Range
The digital panel on maytag does not work- can't use oven.
no there is no fuse for that.
the clock board seems to be finnished.
May 27, 2009 | Maytag MER5775Q Electric Kitchen Range
I have a spectra gas range and the broiler works but the oven doesn't. When I turn the oven on the middle light blinks but oven won't light, what's wrong? Model#348A8035P017
Mar 30, 2009 | GE Kitchen Ranges
I was baking in my Maytag range when there was a loud popping noise and the oven stopped working. The broiler, clock and timer do not work either. The control panel will do nothing. The burners work and...
Well on most electronic controlled ranges with the problem your describing alot of time it is the clock that needs replaced. And yes most ovens have 2 ignitors.
Jul 11, 2008 | Maytag Kitchen Ranges
Had a power outage and since then my inglis digital stove does not work. all the light's come on but no heat on burners or oven.
my control panel doesn't light up for both ovens and the clock too. The porclain stove top all five panel do work... could i have blown a fuses? in the oven its self .
Apr 15, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Maytag MER5775Q Electric Kitchen Range Logo
121 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
