What are the error codes f6 and f12 for Elin 65SD800?
Right now, I'm having problem with the code f12, and when, because of not knowing what to do, I started rinsing program it started flashing "door", even tho I closed the door. Few times before this I was having f6 after the end of washing.
IB4G2008
  • 3587 Answers
SOURCE: Error Code "OE"
sounds like your machine needs rebalancing..check the feet and floor to ensure it's level and balanced
Posted on Apr 26, 2008
jsrock516
  • 5911 Answers
SOURCE: Kenmore HE2 Plus Front Load Washer; Error Code F12
Is this a model 110.47512601 HE2 Plus? If it is, I do not see an F12 error code listed. I have a tech sheet for an HE2 Plus, but I only see an F21 error code.
There is a tech sheet inside your washer that explains all the error codes. You will have to remove the lower panel under the door to access it. Its usually mounted to the inside of the lower panel on along the interior walls of the cabinet. There will be instructions on how to enter diagnostics mode and a full list of error codes, followed by procedures to follow on how to correct. If you require further assistance in determining the source of the error, please let me know.
PS Don't tell Sears I told you where they keep their "secret" error code list. Don't you find that irritating? The repairman would have come to your home, opened the washer, and read the tech sheet right in front of you - then charged you for it. Good luck.
Posted on Jul 13, 2008
SOURCE: error code de
hi, i've got the same problem. But when i leave it for a minute or two with the beeping, it will automaticaly start its washing program. Without opening and closing the door. We probelbley need a new door sensor. I've seen them on the internet for $100. But as long it's washing like it does now. I'am leaving it like it is.
Posted on Oct 10, 2008
ghost4548
  • 776 Answers
SOURCE: nec nw-891 washing machine will not complete the programmed cycle
Apparent malfunction in the timer circuits. Specific Component replacement not available.
Posted on Jun 30, 2009
localwonder
  • 6784 Answers
SOURCE: dE code on WM0642HW TROMM washing machine
HI, this is a Door Open Error.
Possible Causes are..-
* Door not all the way closed
* Loose electrical connections at door switch and pwb assembly(Control Board)
* Door switch assembly is out of order(Miss aligned)
* Gasket on door may be creased in
Most common issue here will be a defective door lock switch. check all causes before replacing the switch.
Posted on Jul 12, 2009
Mod.KHMS155LSS-1 Getting F-6 Fault code ????
Search Results
    Combination Microwave Wall Oven - Error Code/Message ...
    www.kitchenaid.com/...microwave...error-code...f6-error-cod...
    KitchenAidQuestion: Combination Microwave Wall Oven - Error Code/Message - F6 Error Code -F6 E8. Answer. Product Symptom: Combination Microwave Wall Oven ...
    Over-the-Range Microwave - Error Code - Starts with F ...
    www.kitchenaid.com/...microwave-error-code...f...f6...code/P...
    KitchenAidKitchenAid's product help articles give answers to your frequently asked questions (FAQs). ... Microwave - Error Code - Starts with F - Starts with F6 - F6E0 Code.
    Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kitchen Aid Model # KEMS308SSS02 and I getting the follow error message... is working and was always working but the top microwave/oven does not work. ...Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost Err/ F6 E0/ ... Most "F6/E0" fault codes is usually because of a loose wire connections, loss of ...
Feb 05, 2016 | KitchenAid Microwave Ovens
Code f1 f3 f6
virtual machine - VNC send Ctrl+Alt+F1-F6 to server - Unix ...
unix.stackexchange.com/.../vnc-send-ctrlaltf1-f6-to-serv...
Stack ExchangeMar 15, 2012 - Hence I can switch to the TTY's if my CTRL + ALT + F1 - F6 ... As I understand it, you want to send CTRL-ALT-F3 to the remote .... What numeric keycodes do I need to send for the magic sysrq functionality in a VNC session?
error code f1 dishwasher model gldt696tss 00 KVM Switches
www.fixya.com > ... > error code f1 dishwasher model gldt696tss 00
KVM Switches error code f1 dishwasher model gldt696tss 00 questions and ... 6F 23 20 F1 01 = F2 46 B1 59 04 61 77 71 Telewest 00 = 75 4A 66 04 CF 7F 55 F3 ... ...96 F6 1F C4 01 = 6D EA BE 97 6A AA DA 71 NTL 54 01] 07/10/09 00 = F0 ...
kleenmaid f6 code KVM Switches Questions & Answers - Fixya
www.fixya.com > Forum > Tags > kleenmaid f6 code
KVM Switches kleenmaid f6 code questions and answers. ... 01 = C6 64 1D EF 47 5A 0E EF tellywest 00= B7 DE 73 DE 2F A4 F3 BO 01= FA 4B 82 4C ... ...in bradford area plz 5a 01 83 5D 12 B8 96 F6 1F C4 6D EA 8E 97 6A AA DA 71 Hope ..
Jan 27, 2016 | Computers & Internet
I have an f6 code and the machine will not operate once it comes up
The F6 error code means that the computer on the control didnt detect that the motor reached a high speed on the spin cycle, sometimes it thinks the washer didnt spin fast enough because of a loose wire connection either on the motor or the control boards (motor &machine control) if you find that the washer did actually spin at high speed (clothes dont come out sopping wet at the end of cycle) the wire connections or the motor control board will be the potential causes of the F6 error code. Try unplugging the machine for five minutes to let the computer reset then try again. Next check the control panel wires. f6 code flashing on display Kenmore Elite HE3 Washing Machine
May 19, 2015 | Washing Machines
F6 error code first time star unit show f6 code
good day I have a problem with my aircon its ECOAIRE aircondition with error F6
Sep 09, 2014 | Electrolux Heating & Cooling
F6 error on Hitachi washing machine Sk 120KJS
Jul 09, 2012 | Washing Machines
Srartup Repair Not working?
Try:Turn the machine off, turn it back on and IMMEDIATELY press two keys: CTRL +F6. If you hear a distress series of beeps (around 5/sec) keep pressing for about 1 min. After that release F6 but keep pressing Ctrl for a while.At this point the MS Windows Boot Console should appear and offer you choices. Choose Boot in Safe Mode With Internet.
Now, that combination Ctrl+F6 is maker specific. It worked for my DELL
towers. Other manufacturers reportedly have other "secret" codes.
You may try Alt, Del, PgUp, PgDn instead of Ctrl. Also F6 is not cast in
concrete. You may try other function keys. Some machine may require only one key to be pressed.Every machine MUST have a code like this. It took me about 10 min to find.1. Remove all floppy disks, CDs, and DVDs from your computer, and then restart your computer.
Click the Start button, click the arrow next to the Lock button, and then click Restart.2. Do one of the following:• If your computer has a single operating system installed, press and hold the F8 key as your computer restarts. You need to press F8 before the Windows logo appears. If the Windows logo appears, you will need to try again by waiting until the Windows logon prompt appears, and then shutting down and restarting your computer.
• If your computer has more than one operating system, use the arrow keys to highlight the operating system you want to repair, and then press and hold F8.3. On the Advanced Boot Options screen, use the arrow keys to highlight Repair your computer, and then press ENTER. (If Repair your computer is not listed as an option, then your computer does not include System Recovery Option as a preinstalled recovery option.)4. Select a keyboard layout, and then click next.5. Select a user name and enter the password, and then click OK.6. On the System Recovery Options menu, click system restore and restore the computer to the date it was working fine.
Apr 18, 2012 | Dell Inspiron 1545 Notebook
I have a problem with washing machine ELIN 65SD800. Machine display F4.
check your drainage pump, that should be your problem...
Jan 05, 2011 | Washing Machines
SIR, I wish to known MS Office 2007 advance functining & sortcuts
Function keysTo do this Press
Get Help or visit Microsoft Office Online. F1
Move text or graphics. F2
Repeat the last action. F4
Choose the Go To command (Home tab). F5
Go to the next pane or frame. F6
Choose the Spelling command (Review tab). F7
Extend a selection. F8
Update the selected fields. F9
Show KeyTips. F10
Go to the next field. F11
Choose the Save As command (Microsoft Office Button ). F12
SHIFT+Function keyTo do this Press
Start context-sensitive Help or reveal formatting. SHIFT+F1
Copy text. SHIFT+F2
Change the case of letters. SHIFT+F3
Repeat a Find or Go To action. SHIFT+F4
Move to the last change. SHIFT+F5
Go to the previous pane or frame (after pressing F6). SHIFT+F6
Choose the Thesaurus command (Review tab, Proofing group). SHIFT+F7
Shrink a selection. SHIFT+F8
Switch between a field code and its result. SHIFT+F9
Display a shortcut menu. SHIFT+F10
Go to the previous field. SHIFT+F11
Choose the Save command (Microsoft Office Button ). SHIFT+F12
CTRL+Function keyTo do this Press
Choose the Print Preview command (Microsoft Office Button ). CTRL+F2
Cut to the Spike. CTRL+F3
Close the window. CTRL+F4
Go to the next window. CTRL+F6
Insert an empty field. CTRL+F9
Maximize the document window. CTRL+F10
Lock a field. CTRL+F11
Choose the Open command (Microsoft Office Button ). CTRL+F12
CTRL+SHIFT+Function keyTo do this Press
Insert the contents of the Spike. CTRL+SHIFT+F3
Edit a bookmark. CTRL+SHIFT+F5
Go to the previous window. CTRL+SHIFT+F6
Update linked information in an Office Word 2007 source document. CTRL+SHIFT+F7
Extend a selection or block. CTRL+SHIFT+F8, and then press an arrow key
Unlink a field. CTRL+SHIFT+F9
Unlock a field. CTRL+SHIFT+F11
Choose the Print command (Microsoft Office Button ). CTRL+SHIFT+F12
ALT+Function keyTo do this Press
Go to the next field. ALT+F1
Create a new Building Block. ALT+F3
Exit Office Word 2007. ALT+F4
Restore the program window size. ALT+F5
Move from an open dialog box back to the document, for dialog boxes such as Find and Replace that support this behavior. ALT+F6
Find the next misspelling or grammatical error. ALT+F7
Run a macro. ALT+F8
Switch between all field codes and their results. ALT+F9
Maximize the program window. ALT+F10
Display Microsoft Visual Basic code. ALT+F11
ALT+SHIFT+Function keyTo do this Press
Go to the previous field. ALT+SHIFT+F1
Choose the Save command (Microsoft Office Button ). ALT+SHIFT+F2
Display the Research task pane. ALT+SHIFT+F7
Run GOTOBUTTON or MACROBUTTON from the field that displays the field results. ALT+SHIFT+F9
Display a menu or message for a smart tag. ALT+SHIFT+F10
CTRL+ALT+Function keyTo do this Press
Display Microsoft System Information. CTRL+ALT+F1
Choose the Open command (Microsoft Office Button ). CTRL+ALT+F2
Jan 05, 2011 | Microsoft Office Computers & Internet
Error "F6" on my Smartwash Quite Pak9
I believe the F6 code is a motor failure. I suggest you call a pro to come out and look at it.
Sep 22, 2009 | Kenmore Elite 45986 Front Load Washer
Jul 13, 2008 | Washing Machines
Washing Machines Logo
300 people viewed this question
Top Washing Machines Experts
