Question about Western Digital WDG1C2500N MyBook Premium 250GB External FireWire USB Harddrive Hard Drive
My hard drive is not turning on once it is connected to my comp
The hard drive just sits with its light flashing making a noise like it wants to turn on but it doesn't.
  • 748 Answers
The hard drive has lost its index or master boot record. About the only thing to do is use a data recovery service if there's unrecoverable data, then replace it.
Posted on Jan 05, 2009
Flashing blue light turns on and off
try using another usb port ,or another pc, also has it been recently dropped? if you dont know then when you connect it and it make a whooshing noise then its fine, but if it make a grinding noise even if its slight then the disk is damaged and unusable.
Dec 26, 2013 | Transcend Computers & Internet
Screen is black. Blue light flashes intermittently. Makes clicking sound when it flashes. Rebooting computer doesn't help. Unplugging and re-plugging in monitor doesn't help. Disconnecting and...
is the monitor making the clicking noise or your computer
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Jan 17, 2011 | ViewSonic VX1935wm LCD Monitor
My HLN5065WX will turn on, play for about 1 minute, flash funky colors then go black. Once this happens you can not shut down the TV. You must unplug to turn off.
Bad Color Wheel, its located behind the Lamp Pull Lamp out and use a Flash Light You should be able to see it.
Encompass Parts Distribution 1-800-638-3328
Samsung Parts.com 1-800-627-4368
You can also go to Encompass website and look up your Model#
Oct 27, 2010 | Samsung HLN5065W 50" Rear Projection...
My rm laptop when powered up flashes the hard drive light then the cd light then just sits and the fan hums away
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer .
Oct 28, 2009 | Computers & Internet
Lacie 1TB External Drive flashing blue light, not being found
Hey
I know this arent a solution
Tho I have the same problem atm, this is just a networkstorage device, and this is a newly 1.
Feb 04, 2009 | LaCie d2 Extreme 250GB External with...
Installation of one touch mini 4
hello, if you are adding an extra hard drive for space make sure to change the teeny jumper to the proper pins next to the connection slots on the hard drive. the jumper makes your hard drive work as a slave (extra drive) or a master (main drive). if you have a main drive allready on your comp and you dont switch the jumper the slave position the computer will not recognize it becuase of the new hard drives jumper being in the master position or pin connector.
if your installing it as a 2nd master drive you need to use your extra hard drive slot on the mother board for this to work as a secound master then you need the jumper in the master pin slot. there is a small diagram on to the hard drive info label it looks like pins and it shows you where to locate or place the jumper for either master or slave.
for a slave drive once you have placed the jumper properly then you can instal it on the same cable with the main. look at the cable it will have a main and a slave small label printon the connector or if you prefer you can use the 2nd hard drive cable on the secound slot on the mother board turn on your comp if you are going for a extra hard drive the comp should recognize it if the jumper is properly placed. when your comp is running you can check by going into (computer) and it should be there as a new drive letter
after this you may need to format the drive for use. you right click on the hard drive letter and choose format drive
hope this helps good luck with your upgrade.
Dec 10, 2008 | Maxtor Hard Drive
Comp has a virus so now when comp is started it is bypassing the removable drives and going straight to the hard drive, windows starts and stays that it is unable to connect all drivers and then it turns...
if it's bios virus make a new flash update and if it software virus so u need to to resize your c:\ drive (use partition magic) and make a small 2 or 4 giga partition and install windows xp and with parttion magic hide other partitions and install a strong antivirus and then unhide ur partitions and scan (ahmed ghoniem)
Jun 28, 2008 | Computers & Internet
Problem with sandisk 2GB Micro USB Flash Drive
Work through My computer once putting the disk in the USB port. It should read "removable device". Click back and forth from c: drive to my computer to make the computer recognize it faster. Let me know what happens.
cynthia
Jan 09, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
My xbox no show no picture
3 Red Lights Flashing - is a general hardware failure
  • Unplug everything and let it sit for 20 min. Re-connect and try re-starting
  • If these steps do not resolve the behavior, turn the console off, remove the hard drive, and then turn on the console. If the 3x Red LED error light is no longer displayed, turn the console off, re-attach the hard drive, and then turn on the console.
  • Check the lights on the power supply. When you turn on the console, the power supply light should illuminate green even if the three lights on the console flash red.
Check here for more things to try
Oct 30, 2007 | Microsoft Xbox 360 Console
Western Digital WDG1C2500N MyBook Premium 250GB External FireWire USB Harddrive Hard Drive Logo
106 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
