Question about Casio EXILIM ZOOM EX-Z60 Digital Camera
Casio EZ Z60
Casio EX Z60 camera was working fine. After a day of shooting pics, I got it home, and all of a sudden the the camera malfunctioned Now, when I turn the camera on. the green LED comes on and there is a beep, but the lens does not extend and no LCD screen function. I cannot even review the pics I took using just the LED screen.I re-charged the battery and tried other SD memory cards. Just once so far, I was playing with the buttons and holding down each one individually just to see if there is some kind of a rest. It worked once where the lens extended and the LCD screen worked fine. Shut it off and then powered up again. Same problem is happening. If I hold down the REC button for 30 sec, I get a check connections error. I am not trying to connect this camera to any other device.
  • Curtis Golden May 23, 2007
    I think I may have found a partial (or perhaps) a full resolution. Once I saw the check connections error on the LCD screen, I referenced the manual. It said it has to do with the external plug for the PC connect. I just plugged the cable into the external camera port, (not to the PC), and viola, the camera works. Could be a bad or temporarily shorted contact on the port that interfered with the function? Repeated this step a couple of times being sure the connector really made good contact and then removed it. So far, so good.
    Genius:
  • 2,985 Answers
This is a major malfunction take a look here http://www.fixya.com/support/p472784-casio_exilim_zoom_ex_z60_digital_camera and contact the makers Tech Support
Posted on May 23, 2007
When i capture a pic in day light than picture will come faded and when i capture in night it comes nice one my camera model is exilim ex z60
make sure the camera's settings are set to normal, since, the lens might be sensitive to daylight. You can actually change this at the settings, and, you said that it works fine at night or at dark areas? Yeah, the lens could be sensitive to bright lights! Simply adjust the sensitivity and you're all set!
Jun 25, 2009 | Casio Exilim EX-Z60 6MP Digital Camera...
Casio Z600
your issue is most likey your ccd replacement ccd i charge 65.00 part and labor to fix this issue all the time.let me know if i can help.
Oct 22, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
I have a Casio EX 260, not the EX-S600
Try resetting camera. If that doesn't work more than likely there is a lens error. 800-706-2534 and keep choosing option 2 and they will tell you where to send it.
Feb 07, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Casio Exilim EX-Z60 Start up and screen problem
This is the lens focus gears. They are either knocked out of alignment, or debris has jammed them.
Dec 15, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Casio EXILIM ZOOM EX-Z60... Problem
The power leads that are soldered from the main circuit board to the LCD are near the lens assembly ( about 7 o'clock). Did you break one of these? If so, it will need to be resoldered.
Casio EXILIM ZOOM EX-Z60 problem with not being able to get the LCD working after dis-connection and re-connecting the connectors
The LCD will not show the picture until you put the ribbon all the way inside the connector
Hope this helps
Joe
EXILIM EX-760
Try resetting the camera. If that doesn't work then it is a repair issue.
In picture taking mode press menu
go to setup
go up to reset
press right arrow
highlight reset
press set
If that doesn't work then send it into repairs and they will send you an estimate on what it would cost to fix it. Give them a call at 800-706-2534 option 2.
Nov 20, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Casio ex-z60 cannot read memory card
Make sure that the SD card you are using is either a SanDisc, Toshiba, or Panasonic. Those are the only cards that have been tested with Casio cameras. Also make sure that you format the card WITH THE CAMERA before you try and use it the first time. If it still doesn't work I would try resetting the camera and then you should have no problem.
May 29, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Casio EXILIM ZOOM EX-Z60 Digital Camera Logo
286 people viewed this question
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
