Question about Technics SA-TX50 Receiver
I AM LOOKING FOR A IC PART NUMBER RSN 3655A FOR MY TECHNICS SA-TX50
5 Suggested Answers
SOURCE: Technics sa 400 Receiver
Checked fuses then sprayed contact cleaner on the fuses and the fuse holders. The speakers began to work correctly.
Posted on May 29, 2009
SOURCE: Max. wattage for speakers w/ Technics Receiver SA-GX100?
I too have a Technics SA-GX100 and it's rated at 2 x 40W @ 8 Ohms. I have the Technics SB-2840 floor model speakers hooked to it, which are rated at 200W Music Input - 8 ohms. It sounds very nice just to be a 40W receiver.
Posted on Jun 12, 2009
SOURCE: looking for user manual for Technics SA-AX720
You can download them, depending where you are, I have one!
Posted on Aug 04, 2009
dunnbiker
  • 8546 Answers
SOURCE: I am looking for a remote control for an old
It's a eur647130. Web searching turns up a bunch of them.
Posted on Aug 20, 2011
Overload display
Follow the course of the capacitor using the printed circuit board track. It should leave to an semiconductor (IC or Transistor). Replace that. As that will be causing the cap to blow.
Apr 26, 2014 | Technics SA-TX50 Receiver
NO SOUND COMING OF THE SPEAKER
I have the same issue. The power comes on but no sound goes to the AU meters or Output. I have fixed dozens of cold solder joints on the circuit board but it did not fix it. I now am removing the RB1716AB board from the transformer and noticed the black retaining clips are broken. Intermittent connections? Maybe trying to get the clips now.
Jan 17, 2014 | Technics SA-TX50 Receiver
Overload sa-tx50
Most overloads are caused by the main output devices. They will go short circuit if for example speaker wires have come into touch. Another cause is high volume or a faulty speaker. Or poor ventilation around the amp causing excess heat.
The only cure is to replace the device(s) generally located on the heat sink.
Dec 01, 2013 | Technics SA-TX50 Receiver
LOOKING FOR WIRING DIAGRAM FOR SA EX300 TECHNICS HOME RECIVER
SA EX300 Output Transistors are inside these Hybrid IC
Part Number = RSN 3403-P
Aug 01, 2012 | Technics Audio Players & Recorders
Same problem
The overload indication tells us that there is a problem in the final stage of the amplifier section. This model uses an AMP-PAC or large amplifier IC (part number RSN-3305) which is now defective. If you can solder, try resoldering the pins on this IC. Sometimes a poor solder connection can cause a voltage offset that will be detected as a fault and shutdown the system like this. If the resoldering fails, the IC will need to be replaced. Parts cost will be in the $75-$95 range.
Dan
Sep 14, 2009 | Technics SA-AX720 Receiver
I am trying to set up a SA-TX50 A/V receiver, SH-300 processor, DVD player to my Philips LCD. I also have a digital cable box, seeking assistance. Mike
1. cable box video out to video 1 in on the lcd , audio out to reciever input 1 ( tv, vcr , or what you want it on )
2. dvd s-video output to lcd video 2 s-video input , dvd audio out to reciever dvd/cd audio input , and add the optical or coax cable digital audio for dolby digital surround sound
electech
Nov 26, 2008 | Technics SA-TX50 Receiver
SA TX50
steve4trace on jul 8,2008
UNPLUG the receiver from the outlet. Take cover off. See the circuit board to the right of the dial (front facing U) behind the glass window. The bottom of those circuits are connected by pins that fit the other circuit board. Press them together or tie that corner safely to the back end using non-electrical wire (use poly-twine). When you do this you will not be able to put the cover back on. You will have to leave it exposed. If you like your receiver that much like I do - this is the solution I found. Put the receiver back where it is protected (from kids, juices, water, etc.) and enjoy your surroundsound again. You might have to do that to the other side. It worked for me. Use common sense when looking. Good luck.
Jul 08, 2008 | Technics SA-TX50 Receiver
F61 problem
DIsconnect sound Amplifier ic (RSN).After removal of the ic if the unit works o.k offcourse without sound than replace ic.If still f61 than sound ic is o.k and check voltege regulators in power supply.You can check dc detect line if it gets activated.
F61 is mainly two resons 1st sound ic or power supply problem in power bord which send signal to system control to shut down the power in order not to damege more.
Dec 13, 2007 | Technics SC-EH780 CD Shelf System
Open Questions:
See all Technics SA-TX50 Receiver Questions
37 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
