Question about Dryers
Remove drum from dryer - Dryers
    Top Expert:
  • Dryers Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Nov 06, 2012
My kenmore 87872800 dryer wont spin. everything else is working but drum wont spin.
Left the top of the dryer top, check to see if the belt isn't broke or loose, if that is in tact try turning the drum by hand to see if it turns easily. if not, the bearing in the back of the drum needs replaced. this is easy to replace, remove the drum by removing the dryer top and then remove the belt, and the drum slides up out of the machine. replace the bearing then reassemble dryer.
Jun 16, 2011 | Dryers
Dryer stopped working?
  1. From the top of the dryer, remove the lint trap. Using your screwdriver, unscrew the assembly that houses the lint screen and remove it from the dryer, setting it aside.
  2. Using your screwdriver as a lever, insert it under the front right side of the dryer, between the top and the body. Press down to force the top slightly up from the body. Repeat this process on the left side, and lift the top off the dryer.
  3. Remove the lower panel from the dryer by inserting the screwdriver into each side and rotating to release the clips that hold it in place. Slide your phone book under the now-exposed dryer drum so that the drum will be supported.
  4. Loosen the screws at the bottom of the front cover, but do not remove them (this allows access to the belt without requiring you to remove and replace the entire front cover). Move to the top of the dryer, and remove the screws holding the front of the dryer in place. (These will be located at the top, behind the front.) Tip the cover toward you, exposing the drum, and slip the broken belt off the drum without fully removing. Slip the new belt over the drum, and lift up on the drum while returning the cover to the closed position. Replace the screws to the front cover and tighten the lower screws. Remove your phone book from its position under the drum.
  5. Check the rear drum seal to the back of the dryer, and position the new belt identical to the old, with the textured side facing down.
  6. Directing your attention to the motor area, remove the old belt and feed the new belt through, passing the entire belt, doubled over, under the idler pulley. Push the belt toward the motor pulley, placing the belt around it, and allow the tension to release on the idler pulley.
  7. With your hand inside the dryer drum, rotate the drum counterclockwise to ensure that the belt has been properly installed. Replace the top of the dryer, exerting downward pressure for a snug fit, followed by replacing the lint screen assembly, and the lint trap, and then replacing the lower front cover.
  8. Run the dryer for several minutes to ensure that the dryer is operational and that you have installed your belt correctly.
  9. please comment on there by rating or voting,saying how helpful
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Dec 23, 2010 | Maytag Neptune MDE5500AY Electric Dryer
The dryer drum will not turn, even manually with the belt removed
Sounds like something became wedged against the drum. Maybe a bearing?
Feb 20, 2010 | Frigidaire GLEQ2152ES Electric Dryer
My maytag dryer makes a loud noise when on. It sounds like a belt. Can I fix it and how? It's an older model, I don't know where the model number would be. It's loudest when first turned on. Thankyou
To remove the belt go the the rear of the dryer and remove the two or four screws holding the inspection door near the bottom corner of the dryer.Remove this small door. Unplug the dryer. Look inside and see how the old belt is positioned on the pulleys. Releive the tention on the belt by moving the belt tentioner and sliding the belt off the motor pulley.
Go the the front of the dryer and remove the two screws holding the front panel on. Tilt the dryer front forward and remove. Mark and remove the two door switch wires and move the front panel out of the way. Undo the four screws holding the drum support from the front of the dryer and remove. Grab the drum and sllide it forward out of the dryer.
Vaccum the inside of the dryer and inspect to make sure the rollers move freely. If they don't move freely or show wear, replace rollers and lubricate with light oil. Replace belt.
Put belt over drum. Reinstall the drum into the dryer. On some of the older dryers there were teflon drum gliders located inside the front drum support. Inspect glides and replace if needed.
Reinstall the front drum support and four screws. Reinstall the front panel with two screws.
Replace door switch wires.
Lift the top and make sure the belt is positioned on the drum where the old belt was.
Go the rear of the dryer and pinch the belt sliding threw the belt tentioner under the pulley and over the belt pulley.
Reinstall the rear door with all the screws.
Faster the top down and plug the dryer in and test.
Your done.
Jan 03, 2010 | Maytag PYE2300AY Electric Dryer
Dryer is making a banging sound even when drum is empty
The dryer drum support is worn and must be replaced.Unplug the dryer. Open the top lid and fold it back. Remove the front panel,dryer belt and drum. To remove the drum pull UP on the rear of the drum. There is a ball and cup support on the rear of the drum and rear cabinet. They are worn down.
Nov 03, 2009 | Frigidaire Electric Dryer
How do I replace bearings on the drum roller for the Amana electric dryer?
remove front cover then top cover remove belt around drum remove 3 or 4 screws inside drum that holds bearing onto drum, repl bearing and mount and reverse procedure
Sep 27, 2009 | Amana DLE330RAW Electric Dryer
GE DRYER HEATING ELEMENT
Yes, the whole drum needs to be removed:
Before you go trough this make sure you know for sure your elements need replacement by checking for continuity at both element terminals.
Make sure you do the same with your high limit thermostat on housing.
How to remove the drum?:
Disconnect the power source to your dryer before you begin to remove the drum. Either unplug the unit from the wall outlet, remove the appropriate fuse from the fuse box, or flip the appropriate breaker in the circuit breaker panel.
Pull your dryer out from the wall. Behind it, on the bottom, you will find a lower panel that will give you access to the unit's belt tensioner (also known as an idler pulley arm). Remove the screws holding this panel in place, and then remove the panel itself. Reach inside and release the belt tension by removing the belt from the motor pinion.
Older GE dryer models have a small drum bearing inspection plate in the center of the back of the dryer. This drum bearing inspection plate provides access to the dryer's circlip (also known as an e-ring). This clip holds the rear drum shaft in place. Newer models do not have this circlip or the drum bearing inspection plate.
If yours is an older GE model with an inspection plate, remove the plate now. It will be held in place with a single screw. With the plate removed, you will be able to see the drum support shaft and the e-ring (circlip) holding the shaft in place. Use a small screwdriver to remove the e-ring. You may also want to use a magnet to keep the circlip from falling into the dryer. You will also find several metal and nylon shims between the bearing and the e-ring, inside the bearing, and between the bearing and the drum. Take careful note of how they come off so that you will be able to put them back on again in the right order.
Now remove the front panel of the dryer. There are a couple of different ways this is accomplished. Whichever method you use is dependent upon your model. Some older models have two spring catch clips under the cabinet top, one on the left side, and one on the right side of the front. Use a putty knife, or some other flat and thin object to wedge in under the cabinet top. Release both spring catches and lift the cabinet top off the dryer. In some newer models, there will be screws joining the cabinet front panel to the cabinet top. You will have to open the door in order to find these screws. Once they are found, remove them and then slide the cabinet top forward and lift it off the unit.
Next, there are two screws located in the bottom of the front panel, one in each corner. Loosen these, but do not remove them just yet. Locate and remove the two screws at the top inside of the dryer's front panel. Again, there is one screw in each corner. Proceed to remove the other two screws you have just loosened. Disconnect the door switch wires and then lift the front panel off your dryer. With the front panel removed, lift the drum and slide it out of the dryer.
NOTE: In some models, you will have to remove the dryer drum glides before you can remove the drum. Also, now that the interior of your dryer is completely exposed, it might be a good time to vacuum out all of the dust and lint that has built up in there.
Aug 17, 2009 | GE DSXH43EF Electric Dryer
How to remove the drum from the front and replace the drum support cup kit.
Release the top by pushing in the clips with a putty knife at the front right and front left of the dryer. Once you release the top you can remove it by disonnecting the ground wire at the rear of the top panel. Remove screws that secure the front panel to the dryer. Once all the screws are removed give the front panel a tug to pop it from the clips. Unhook the wiring harness and remove the front panel. By now you can see the drum. Remove the belt from the motor and idler wheel pulley. Yoy will need to get to the rear of the dryer and remove a grill (lower left corner).to gain access to the pulleys. Once the belt is removed, grasp the drum at the rear and give it a quick **** upward to release the drum from the rear bearing. The drum can now be removed through the front.
If you are replacing the rear bearing, consider also replacing the front plastic glides/slide that are located at the top of the door.
May 23, 2009 | Frigidaire FDE647RF Dryer
Inside dryer silver flaking off
If you need a new drum. Follow the instructions below.
Ordered drum from Sears parts. 3045EL1002D
Cost of 85$ + 15 to ship. It came in 5 days.
Here is how to do it on a DLE2514W. Takes about an hour. I only used a phillips screw
driver. Take your time and look over the situation. I hope that I rememberd
everything. Good luck.
Dryer Drum Repair
Dryer Drum Repair
1. Remove L bracket with 6 screws at the top, rear.
2. Slide top back 2 inches to unlatch and remove.
3. Remove control panel with 2 screws at top, inside corners.
4. Carefully unplug 4 plugs from back of control panel.
5. Looking at inside at the top. Remove wiring bundle from 2 guides.
6. Unplug wire from dryer light.
7. Open dryer door and unscrew 2 screws behind door just below lint trap.
8. Remove 4 screws at top of front panel that holds the door.
9. Lift up front panel to remove. I couldn't get the door switch plug to disconnect
so I carefully rotated it an set it on top of the dryer.
10. Remove upper case bracket with 2 screws in front and 2 screws inside at top.
11. slide up a bit to unlock from sides. Watch routing of dryer switch wire bundle.
12. Remove lint trap duct with 2 machine screws. Carefully slide down to remove.
13. Remove front drum support with 4 screws attached to sides. Lift up to disengage
sides. Lift drum to free from rollers.
14. Observe how drive belt is routed around motor and tension roller. Push tension
roller up and release belt. Carefully take belt off and remove.
15. Almost done. Lift drum up at rear to free from rear rollers. Remove.
16. While your're there vacuume up dust and reverse procedure to install.
Mar 07, 2009 | LG DLE2514 Electric Dryer
Cracked Drum on LG Dryer Model #DLE2512W
I had a 2514 with a similar problem. Cracked drum. This is what I did to fix it. With the new drum. No noise at all.
Dryer Drum Repair
Dryer Drum Repair
Feb 10, 2009 | LG DLE2515S Gas Dryer
Dryers Logo
27 people viewed this question
Top Dryers Experts
