Question about Whirlpool GI5FSAXVY Stainless Steel Bottom Freezer French Door Refrigerator
The control panel on the door where I select ice or water will not let me select between ice or water. The lights are off on both and when I press either all of the other lights turn blue or red.
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
If you have no control at the dispenser, you will need to replace the HV control board. Here is the board to order.
Once you replace the board it will need to be programmed. The Program Code is located on the Serial Plate on this unit after the word Code.
Posted on Nov 08, 2012
  • 61 Answers
SOURCE: Whirlpool ref in door ice not making ice
check the teperature of the freezer compartment . the ice harvest actuates on teperature. and refill with water at the end of harvest cycle.. a lot of times the condensor under your fridge can become plugged with dust and the freezer teperature never achives low enough to harvest ice..good luck
Posted on Oct 06, 2008
  • 6 Answers
SOURCE: When pressing on the rubberized panel so that the ice will dispense from the refrigerator - the ice maker makes a noise like it is going to dispense ice - but then nothing happens.
the ice bucket has two possable problem the worme gear are need to takeout the ice bucket and defrost it
Posted on Jun 01, 2009
  • 291 Answers
SOURCE: red light flashing on ice control panel in freezer
The red light is supposed to flash. The number and frequency of flashes is a diagnostic tool we use to determine what is wrong if the icemaker is not working. If your icemaker is not working, count how many flashes before it rests, and let us know. Good Luck, Appliance Specialists
Posted on Jan 21, 2010
Testimonial: "thanks"
SOURCE: the water through door or light in door or ice
I am having the same problem do you have any schematics for the control panel
Posted on Feb 01, 2010
SOURCE: when you push the dispenser for ice no ice or
look underneath the small door for two small openings to get a screwdriver into, pops right off!
Posted on Feb 17, 2010
There is a constant buzzing noise coming from the lower freezer ice maker. It is producing very few ice cubes. The control bar is down and in proper position to make ice.
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
Cause of Beeping Noise in Frigidaire Refrigerator eHow
May 21, 2015 | Whirlpool Gold Series GB2SHTXTS (219 cu...
Ice and Water not dispensing. Light button not working
http://www.repairclinic.com/0100_1.asp
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Jul 04, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Filter light on
Water Filter Status Light and Filter Reset
The filter reset control allows you to restart the water filter status
tracking feature each time you replace the water filter. See "Water
Filtration System."
After changing the water filter, reset the status light. Press the
OPTIONS button to enter Options mode, then press LOCK to
initiate the reset, then press MEASURED FILL to confirm that
you want to reset the status light. When the system is reset,
the "Order" and "Replace" icons will disappear from the
display screen.
These instructions can be found in the=> GZ25FSRXYY2 User Manual . As for the dispenser and ice dispenser problem this could be related to a loose connection in the door where wiring attaches to control panel and/or where door wires go from door to cabinet also a defective pressure switch where glass is pressed to get water or ice. Can you tell me when this additional problem began?
I am here should you need me, Thanks John Tripp Appliance 911
Apr 21, 2014 | Whirlpool Refrigerators
I just connected the ice maker water line to the unit. The Frig has electrical power and ice is making. My problem is that the controls at the front of the Frig is not working. I cannot dispense the ice...
Without a model number here how they usually operate. The DOOR / LIGHT switch disables water and ice in door functions. I.e. it is not supposed to operate with the door open. If the switch is open... i.e the light is not working door open, (Switch has 2 functions Light and Water / ive in door operation) Then the control panel / water / ice in door will all not work either. It is possible for the light to work while the CP / H2o / Ice do not work. Usually if a door switch fails the light stops working also. It is not always the case.
Try holding to door switch plunger depressed and see if your CP works and water in door work. DO NOT try ice in door as you can damage things.
If you respond with a model number and brand; I will see what I can dig up for you use while troubleshooting your unit. Expect to see parts data also.
Thanks for choosing FixYa,
Kelly
Sep 02, 2011 | Refrigerators
The water will not dispense and the ice cubes will not come out. I noticed on the front panel that IWD is "off" and that it shows "lock"ed at the bottom of the screen. I know that the...
Press Freezer and Super at the same time for 5 seconds to turn Ice & Water Dispenser on. This will remove "IWD Off" indicator. If it is locked, press the Alarm/Lock button for 5 seconds to unlock it.
Feb 17, 2011 | Bosch B22CS50SNS Side by Side Refrigerator
The control panel does not seem to work on the door. None of the switches work, ice,water, options, alarm. The change filter sign on the main display is highlighted. I tried turning the refrigerator...
Yes the filter needs to be changed after the change filter light is indicated.After changing the filter the unit has to be reseted.The reset procedure is as follows:--- press and hold the Water Filter Reset button for 5 seconds. Newer models: press the Options button until "filter change" is selected, press selection buttons +/- until the "filter change" display goes out.-------------------- Thank you.
Jan 31, 2011 | Siemens KA62DV50GB Side by Side...
I need to know how to set pre set stations on this model
Here is the info, for a link to the user manual go here for all the functions
http://www.fixya.com/support/p920294-pioneer_deh_p4000ub_cd_player/manual-26899
Storing and recalling broadcast frequencies You can easily store up to six broadcast fre- quencies for later recall. ! Six stations for each band can be stored in memory. 1 Press LIST. Preset screen is displayed. 2 Use MULTI-CONTROL to store the se- lected frequency in memory. Turn to change the preset number. Press and hold to store. # You can also store the frequency in memory by pushing and holding MULTI-CONTROL right. 3 Use MULTI-CONTROL to select the de- sired station. Turn to change the station. Press to select. # You can also change the station by pushing MULTI-CONTROL up or down. # To return to the ordinary display, press BAND/ESC or LIST. # If you do not operate the list within about 30 seconds, the display automatically returns to the ordinary display
Sep 22, 2010 | Pioneer DEH-P4000UB CD Player
No water,light, or ice on the door
The control panel is most likely at fault. They are all controlled by the panel. Very rare for all 3 devices to go faulty seperately
Aug 27, 2009 | Freezers
Ice & water control buttons
sound like a bad(shorted) dispenser user interface INTERFACE DISP ASM WR55X10415
Apr 03, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool GI5FSAXVY Stainless Steel  Bottom Freezer French Door Refrigerator Logo
345 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
