Question about Saws
I need to buy a new armature assembly for my makita ls0714 mitre saw it has 230 - 240v on info plate so i presume i need a 510063-9 ARMATURE ASSY 240V LS0714/FL not a 110v is this true?......also an
Its all in the title
rowdy45176
  • 2176 Answers
SOURCE: Delta 36-075 miter saw. Motor ok, but blade will not spin
It sounds as though one or both of the items are stripped. They mesh to drive the blade so I would not take a chance on just replacing just one. Also when you look at this you might also want to look at replacing the bearings and brushes. Make sure you clean out the gear housing or you will have immediate problems again. Also check where you buy these parts for their recommendation on the grease that needs to be used.
Posted on Mar 14, 2009
rowdy45176
  • 2176 Answers
SOURCE: Compound Mitre Saw Motor turning, spindle isnt.
I have went to 3 different sites and cannot find the model number listed on them, I did look at a Ryobi saw and they indicate it is an assembly. but before I did that I would try and removing the gear from the spindle. It is possible that when it spun it put a burr in the parts and you would have to use a little extra effort to remove them I would suggest going to a repair shop and having them press them apart and see what you canfind that way. Sorry I couldn't find more for you
Posted on Aug 21, 2009
  • 670 Answers
SOURCE: craftsman # 315,10851 7 1/4 inch circular saw.
In the past I have clamped a pair of vice grips on the old blade so I could remove the bolt from the arbor.
Posted on Sep 12, 2009
  • 8404 Answers
SOURCE: Compound mitre saw won't shut off unlss unplugged
Relace the switch.
I am presuming the lock button has not been inadvertently pressed ... Check that first.
The condition you deacrive is dangerous. Please fix it before you use it any more.
If you require additional assistance, let me know.
Otherwise, check RepairClonic.com for parts and technnical instruction from their crack crew.
Thanks for the opportunity to lend you a hand
a
Posted on Sep 26, 2009
jyackle5
  • 8197 Answers
SOURCE: Right at where the brushes
If you are seeing a lot of spark where the brushes contact the armature that meens that the brushes are low and need to be replaced. If the saw is new though that meens that the brushes have not broken in to the right seat yet.
Good Luck
Posted on Oct 22, 2010
I require a new replacement motor for my Rexon mitre saw model SM2150AE.
Also check the bearings when you are replacing the anchor and you want to do well even replace the drive gear and the motor brushes and replace the lubricant
Sm2150ae Armature assy SM2150AE 2BMY Availability In stock 31 99 inc Vat
Apr 03, 2015 | Saws
Saw stopped working. changed brushes. still not working.just dead.blade turns ok.not even a click
These are notorious for burning out armatures.
The replacement process is pretty involved, I would not attempt unless you are comfortable.
Remove the brushes
Remove the 3 Screws hold the motor assy to the saw
Remove the screws holding the motor housing together.
Separate the housing and you should be able to see right away if the armature is burnt (many times the windings actually blow apart)
Often when the armature burns out it also melts the brush holder assy - I would recommend replacing it as well.
If the armature appears fine then I would lean toward the switch. Makita BSS611 18V LXT Lithium Ion 6 1 2 Circular Saw Parts
Mar 12, 2015 | Makita Bss611 18v Lithion 612" Circular...
Saw stopped working, changed brushes, still will not turn
These are notorious for burning out the armatures. If you are comfortable opening the tool up you can tell very quickly - I have sent a link with the breakdown showing how the tool goes together.
Usually visual inspection is all that is necessary - if the armature is the culprit you will see it is burnt or even blown apart.
If the armature is the problem, most of the time it also damages the brush holder assy & it should be replaced as well.
If the armature is in good shape then your problem is the switch, but my experience would have you check the armature first. Makita BSS611 18V LXT Lithium Ion 6 1 2 Circular Saw Parts
Mar 12, 2015 | Makita 18 Volt Bss611 Cordless Circular...
I can not remove armature caseing from makita miter saw
The casing at the saw end will have an inside case that is bolted either from behind the gears or from the armature side by screws. This has to be undone to allow the bearing to separate from the case
Jan 16, 2013 | Makita 10" Compound Miter Saw LS1040
How do i replace the gears on a makita reciprocating saw
Expensive job. You have to replace the armature and the gear which retails around 110 pound alone you would be better buying a new one unfortunately.
Nov 06, 2012 | Makita Jr3000v Reciprocating Sawzall
Reciprocating saw armature removal
usually there is a screw in the diaphragm to hold that assembly tight. You need to remove the brushes first and you might need to GENTLY pry the diaphragm from the motor housing. Then using a soft blow hammer tap the armature out of the plate. I would recommend replacing the bearings and brushes when doing the armature. Let me know if you need more assistance.
Dec 29, 2011 | Saws
Installing new armature and field assy how to
they generally have what is called "garter springs" which go around the brush holder. the new field should have these installed already. If you give me the model and brand (shows MAKITA) I will look at a breakdown and confirm.
Apr 01, 2011 | Makita Saws
Looking for an armature for Makita 2400B Mitre saw.
Hello I would look on ebay or craigslist for the armature. Just type in make and model armature.
Mar 16, 2011 | Makita Garden
Something wrong with the armature
If the armature is shot, it will spark a lot where the brushes are touching the armature comutator. To remove the armature:1 Remove brushes. 2 Remove 4 screws holding the gear box. 3 Pull away gear box from the body. The armature may come with the gear box or not, it's only pushed in, so you should have no problem to disassemble it. If the armature stay in the grinder, use two skrew drivers to pray it out. You may not see anythink wrong with it, but it may be no good . That's Makita special, they don't make it good as they used to. The price for new grinder is about $130, for armature $65. field $40
Mar 06, 2009 | Makita 9005B 5" Electric Angle Grinder
Saws Logo
48 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
