Question about Samsung SyncMaster 2333SW 23" LCD Monitor
The Monitor menu constantly pops up even ingame this just started the last few days, I have a Samsung Syncmaster 2333sw
  • Donna Nov 08, 2012
    Now it is almost constantly staying up on the brightness tab, the brightness up button also flashes.
    Also, the brightness stays at 100, even when lowering it it self adjusts back up to 100.
  • 34 Answers
HI there,
You problem seems to be related to the of control push buttons. Some of them are probably loosing its functionality and react as they are pushed. It is a common problem. They need to be replaced, but i strongly suggest qualified persoal to do it if you are not familiar with electronic. Hope this helps.
Posted on Nov 14, 2013
3 Suggested Answers
  • 1684 Answers
SOURCE: Samsung 214t syncmaster flickering
It sounds like you have a monitor with a common problem. After a few years some LCD monitorswill blow a power supply. The problem is caused by parts calledcapacitors overheating in the confined space of the monitor. If you aregood at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should workfine.We just posted a repair guide showing how to remove the case ansreplace the parts. The capacitors do need to be installed with thecorrect + and -connections, note the stripe on the old one and insert the new one thesame way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Posted on Jul 25, 2009
Starworx
  • 4 Answers
SOURCE: my monitor 940n samsung syncmaster gone in black...
I have just had this same problem. The problem mostlikely is a blown fuse on the inverter board. Mine was blown on the board and also a Capacitor (470nF/25V) was bad beside the Fuse.
I replaced both and monitor is working now again. After install the picture was a little grainy with little artifacts. In another post i found that the Power Supply board needs to be cleaned for unwanted residue. After that picture was fine again.
BEWARE that you need a soldering iron and a steady hand to replace these parts. If you are unfamiliar with soldering at all have an expert take a look at this. The Power boards uses 220v so DO NOT connect it to the Power when opened.
Starworx
Posted on Dec 17, 2009
Samsung syncmaster 2233sw driver for windows 8
I would make sure my video drivers adapters are up to date. Use windows update to automatically set the proper driver to the display and to your video adapter.
Mar 24, 2014 | Samsung SyncMaster 2333SW 23" LCD Monitor
Samsung syncmaster 2333sw goes to sleep mode when turned on
C242 470uF 10V, C241 & C242 1000uF 16V, C261 & C319 680uF 35V failed, replace them at once
Feb 17, 2013 | Samsung SyncMaster 2333SW 23" LCD Monitor
Syncmaster 2333sw
Most common failures in these LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply. C242 470uF 10V, C241 & C242 1000uF 16V, C261 & C319 680uF 35V failed, replace them at once.
samsung-2033sw-2233sw-ip-43135a-bn4400124s-power-board-dfydxumns33ohqc3bsmt22yf-1-1.jpg
Jul 27, 2012 | Samsung SyncMaster 2333SW 23" LCD Monitor
Hi, I bought my samsung 2333 syncmaster in the U.S. but moved to New Zealand where the voltage is 230, can I use the monitor with a converter plug or with a NZ compatible cord?
Samsung 2333 have switching power supply and it can work from 100-240VAC 50/60Hz with out any modification or adaptors. Feel free to use it in USA or New Zealand. You need only to arrange plug converter. Check specifications on Page 49 of 2333SW user's manual available on: https://www.manualslib.com/manual/201694/Samsung-Syncmaster-2333sw.html?page=11#manual Samsung SyncMaster 2333SW User Manual Your Monitor Initial Settings
Jun 03, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
Screen menu auto-adjust ghost
never try to fix crt monitor you need a new one cos thay are so cheep cost you lots for reppers ,bye an lcd ,,,,nice
Apr 05, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Samsung SyncMaster 2333SW 23" LCD Monitor Logo
101 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
