Question about Eagle Cuda 242 Fishfinder
Need pin outs for eagle cuda 168
Which is pos and neg pins on plug receptacle
    New Friend:
Coda has flat D 6 pin with center pin grd for 4 wire vs old arrow 6 pin round black one. Flat on bottom, count cw 12345 pins w pin 6 center... 2 pin minus 12 v, 4 pin +12v. For other 4 wire like speed/temp... 1 blue, 3(top) white, 5 pin bot right yellow, 6 center ground for spd/temp. White for speed wheel, rest not known. I used 2wire cable and 4wire cable with 2ft pigtails and 3amp fuse in red wire. I used old radio stereo 2 and 4 pin male female connectors at end of pigtails.
Posted on Feb 02, 2013
  • Bob Bogert
    Bob Bogert Mar 15, 2014
    Are you looking at the back of the unit or the cable harness when you count cwAdd a Comment
3 Suggested Answers
SOURCE: I need a manual for a eagle cuda 168.
www.eaglenav.co.uk/en-gb/.../CUDA-168/Downloads
DALEHANDY@YAHOO.COM
Posted on Dec 18, 2009
SOURCE: Problem with Eagle Cuda-168 fish
I NEED A TRANSDUCER FOR AN EAGLE-168.
SOMEONE CONTACT ME. PLEASE..............
EAMARONEY@AOL.COM
Posted on Apr 25, 2011
How do I connect 36 volt battery charger to electic golf cart?
Maybe you have an Ezgo cart? Black is negative, white is positive, and the small red wire is connected to the white inside the charger receptacle.
Sep 04, 2015 | Golf
Trying to install kenwood kcd mp238 cd player into a 1996 Ford Expedition. I need to know wiring data to connect the wires of cd player to harness, which colors should I match wires up to, so I can just...
Black Ground, yellow, battery, red switch battery, blue not used, blue white power antennea/amp, brown tel mute, white black front left neg, white front left pos, gray black front right neg, gray front right pos, green black rear left neg, green rear left pos, purple black rear right neg, purple rear right pos
Oct 24, 2012 | Car Audio & Video
The battery on my 5230 wont charge up even tho its on the charger overnight ,ive charged it externally ,that is connecting the pos and neg from the charge lead diectly to the battery pos and neg this way...
just use a ziner diod neg leg of ziner sold to positive of charging connector and positive of ziner to battery connector plus ur problem will be solved
u can find ziner diod in old mobile like 1100 , 3300, 3310, 6600 etc.
Jun 06, 2011 | Nokia 5230 Cell Phone
Have a 2000 gmc sierra ext cab pickup and two type R swr-1042d subs and would like to know the best enclosure for the subs to get maximum performance and the best ways to hook up a one channel mono alpine...
it depends on the amp what can it handle. will it do 2 4 or 8 ohm is it 1 ohm stable are the subs dual 2 ohms or dual 4 ohms. 1042s are dual 4 ohm subs so if you wire them both in paralel it will drop both subs into a 2 ohm load for each sub that is pos of one coil to pos of sec coil then pos to pos on amp and same with neg to neg to neg on amp. now if your amp is 1 ohm stable i would do both subs the same way you will get the most power out of the amp. but itll run a littl hot if you dont have adaquate power running to the amp. now i wanna think your alpine amp maybe only 4 ohm stable. i would run both subs like i had said pos to pos then neg to neg now both subs will be a 2 ohm load so what you do to bring it back up to 4 is you run the 2 bridged subs into a series which is pos from one sub to neg of the other sub the remaining pos and neg will run to the amps pos and neg. which will make it into a 4 ohm load. now the last scenereo is your amp is 4 ohm or 2 ohm stable. this is how to wire it to 2 ohms and not 1. take one sub go pos to neg then pos to pos on amp and neg to neg on amp this will make an 8 ohm load with one sub take other sub and do the same neg to pos on sub then pos to pos on amp and neg to neg on amp this will tell amp to run a 2 ohm load. 2 ohms is a good run for these subs if the amp can handle a 2 ohm load. now if you would have given the amp model number i could have looked it up to just give you what you needed but with this short info i gave all possibilities.
Apr 20, 2010 | Alpine Type-R SWR-1042D Car Subwoofer
Wiring ??? I'm installing dual 12 volt battery's
pos to pos and neg to neg for 12 volt but if your system is 24 volt thats a different story it will be pos to neg.and pos to neg
Nov 02, 2009 | Ford F-450 Cars & Trucks
I HAVE A GE 600W DIMMER TWO SCREWS ON RIGHT HAND SIDE WHICH IS POS? NEG?
I think this is an AC dimmer so therfore no polarity. Dosent matter which poles are used.
Sep 19, 2009 | NRS 2C-2S 2-Gang Cover 2 Single...
Baja 90 is difficult to start
Check for spark using a new spark plug and clean the carburetor / air filter.
Aug 01, 2009 | 2005 Qianjiang QJ150
Car stereo wire diagram for 88 toyota tercel
1988 toyota tercel sedan as follows
pink = (+) pos. for left front speaker
violet = (-) neg for left front speaker
light green = (+) pos. for right front speaker
blue = (-) neg for right front speaker
blue/yellow = (+) pos at all times (power)
grey = (+) pos. only in the accessory or run position
brown = (-) neg gound
red = (+) pos. right rear speaker
black = (+) pos. left rear speaker
white = (-) neg right rear speaker
yellow = (-) neg left rear speaker
verified at 2 resources . fixya
Dec 26, 2008 | 1988 Toyota MR2
I bought a 500/1 jl audio amp and also a w7 10 sub
if its cutting off and right back on then check your ground and your power wire makes sure both are connected good and none of your fuse's are blown, either that or you got a wire hooked up backwards in the sub.. but my guess is that the sub is hooked up wrong... that sub should be hooked up in a series or in parallel,
ok if your running just one speaker, it should be hooked up like this and 2 speakers are a different way...
this is parallel :pos to pos , neg to neg, then one wire coming from pos on sub to pos on amp then neg on sub to neg on amp but bridge the amp on your amp should be 2 pos and 2 neg in two different channels take the pos off the sub into the pos on 1 channel and then the neg from sub to the neg on the other channel,
this is series : on the sub it will go pos to neg then the other neg and pos will go to the amp, but make sure the pos and neg r on different sides of the sub, dont hook them both to the same coil
if your need more help give me your email and ill send you a pic of how to do it...
Aug 12, 2008 | Jl Audio 500/1 Car Audio Amplifier
NO SOUND
HELLO MR GRUMPY I HAVE A SOLUTION FOR THIS IF YOU CAN DO IT YOURSELF ALL YOU NEED IS A PP9 6 VOLT BATTERY 2 WIRES AND 2 PINS THIS INJECTES 6 VOLTS ..... THE 360,S SOUND COMPATABLITYS ARE __Audio __Multi channel surround sound output __Supports 48khz 16-bit audio __320 independent decompression channels __32 bit processing __256+ audio channels ....__..........................................__PLEASE DICONNECT ALL RF LEADS /POWER SUPPLYS/WIRED PADS FROM 360 BEFORE TRYING THIS AND ANY DISK IN THE CONSOLE TAKE 360 APART TILL YOU HAVE THE 360 BOARD IN FRONT OFF YOU USE THE GRAPH ON THE BOARD I HAVE POSTED AND FIND THE PART ON THE PIC LOCATION 8N/8P MEANING 8 POSITIVE 8 NEGITIVE ......__NEXT BATTERY WITH 1 WIRE COMING FROM NEG AND 1 WIRE COMING FROM POS YOU ONLY HAVE TO TOUCH POS WIRE TO POS LOCATION ON BOARD AND NEG TO NEG ON BOARD BOTH AT THE SAME TIME NOW PUT YOUR 360 BACK TOGETHER ....WARNING DONT PUT NEG TO POS OR VICE VERSA I WONT BE HELD RESPONSIBLE FOR ANY DAMAGERS ETC
Jun 01, 2007 | Microsoft Xbox 360 Console
Eagle Cuda 242 Fishfinder Logo
480 people viewed this question
Top Eagle Boating Experts
Steve
Steve
ray gallant
Phil Walker
Phil Walker
Are you an Eagle Boating Expert? Answer questions, earn points and help others
