Question about Maytag Neptune MDE6700A Electric Dryer
Maytag neptune dryer making loud banging noise mde6700ayw
Dryer is drying but making really loud banging noise
    Top Expert:
  • Maytag Master
  • 9,472 Answers
First, check the vane's (paddles inside the drum) to see if one is loose. Post back the results.
Posted on Nov 06, 2012
  • 686 Answers
SOURCE: Maytag Neptune Dryer making vibrating noise while working
a bearing in the back for your drum sounds like what you describe. It needs to be taken apart and the bearing lubricated with high temp grease
Posted on Feb 23, 2009
  • 326 Answers
SOURCE: squeaky loud noise maytag gas dryer
Maytag dryer - common noise problems: See "how to take apart" first. The most common noise maker is the fan blower, it breaks on the motor shaft and makes a loud "rumbling" noise. Other common trouble makers are the rear rollers and idler pulley, they often can make a screeching noise.
A common noise with Maytag dryers is a rumbling noise that often still rumbles for a few seconds even after the dryer shuts off. This usually a broken fan blower, the inside part of the fan blower has rounded out and the fan blower is free wheeling on the motor shaft = new fan blower time. These pliers help make the repair a little easier...Snap Ring pliers.. From Tools Accessories section... How to take the dryer apart. Part is # 303836 for the mytang models. Maytag fan blower order link
Posted on Jan 13, 2009
abhishek33
  • 1239 Answers
SOURCE: Maytag Neptune Dryer Model # MDE3000AYW
Motor malfunctions usually call for service by a professional. There are three main causes of motor failure: lack of lubrication, a defective motor switch, or worn or frozen bearings. A humming sound can be related to a burned-out motor or a defective switch. Check these trouble spots before you call a professional service person or take the motor to a repair shop. Here's how to check a dryer motor:
Step 1: Remove the back access panel. Then reach behind the drum, motor pulley, and idler arm pulley. If these areas are clogged with dirt and lint, undue strain on the motor may be causing the humming noise. Worn or broken belts can also cause a humming noise. Check the belts for wear and damage. If the belts look all right, you may be able to stop the noise by spraying them with fan belt dressing, available at automotive and hardware stores and home centers.
Step 2: Turn the dryer on. The noise you hear may be the whirl of the spinning drum, not the motor. Some noise is normal.
Step 3: Force a little 20-weight nondetergent motor oil (not all-purpose oil) around the ends of the motor shaft. This lubrication may stop the humming noise. If this doesn't solve the problem, remove the motor and take it to a professional service person.The centrifugal switch on the dryer motor may be located on top of the motor. Humming, no motor power, and no heat can be caused by a faulty centrifugal switch. If the switch is externally mounted, check the terminals of the switch to make sure they are tight and not burned. If you spot trouble, remove the switch and take it to a professional service person for testing. A faulty switch will probably have to be replaced. Some centrifugal switches are located inside the motor housing; you won't be able to remove the switch in this case. Remove the entire motor and take it to a professional for repairs.
If the motor hums, but won't run the pulley on the end of the motor shaft, try turning the pulley by hand.Caution: Before turning the pulley, make sure the power to the dryer is turned off.
Posted on Sep 12, 2008
localwonder
  • 6784 Answers
SOURCE: maytag neptune dryer makes a loud squeaking noise
This noise will normally come from a defective idler pulley. Access to the idler pulley varies by model, if your dryer has a lower front panel (kick plate) start there. It should lift up and off or it may be held in place with a few screws or snaps; it may also have a catch at the edges or center gap between the kick panel and main panel. To release the catch, push a putty knife, wrapped with masking tape, into the gap and push back the catch. The next easiest access point is the rear panel. The rear access panel is held in place with several screws along the outer edges. The last resort method of access is the removal of the entire front panel. The front panel supports the front of the drum and so removal is more difficult. Front panel removal varies. In general, access is gained by lifting the top (remove the lint trap screws first), removing the screws that secure the front panel, and detaching the panel from the drum.
When reaching into the dryer be careful of sharp edges on the cabinet and interior supports. Reach in to the belt and give it tug. It should be taught and have only a little give. The belt should go under the idler pulley and over the motor pulley. Lift the idler pulley toward the motor to relieve tension on the belt and remove it from the motor pulley.
Turn the idler pulley wheel, it should turn smoothly, quietly and without any wobble. Inspect it for cracks or uneven wear. If the idler pulley does not maintain proper tension or is damaged it should be replaced. Depending upon your model, the entire assembly or just the wheel or bearing may be replaced. Check the bearings as well for excessive clearance also(roller bearings)
Posted on Sep 29, 2009
arikrom
  • 528 Answers
SOURCE: The dryer is making a loud noise as it tumbles.
you need to open it most of the dryer need maintanace every 4-5 yars and if you keep runing it you may do more damage.
there are several parts that the drum is turning on them and they get bad after few years. like felts,riders,belt...
Posted on May 02, 2010
Maytag neptune dryer makes loud noise on the right side when top dryer is on
The belt tensioner bushing could be shot or there may be a piece missing from the belt. Did you check the back for a removable observation cover?
Jan 05, 2014 | Maytag Neptune MCE8000AY Electric Dryer
My Maytag Neptune is making a banging sound while it dries. The motor was just replaced last year. Could something be loose or is it more serious than that?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Jan 12, 2011 | Maytag MDE2400AYW Neptune Electric Dryer
My dryer makes a loud sqeeling noise when its drying clothes our maytag neptune is a gas dryer thats about ten years old
heatman101
ghgh
May 14, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Loud banging noise in dryer (maytag). Have taken dryer apart. don't know how to tell if drum rollers, belt, and blower wheel are okay. Don't know what else could be causing loud noice.
the most common culprit of banging is an uneven spot on one of rollers. It may not be really noticable, but a slight flat spot can form on them.
Nov 15, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune Dryer makes loud noise while drying.
heatman101
ergfgfjk
Sep 06, 2009 | LG DLE2514 Electric Dryer
My dryer is making a loud banging noise on the left side of sounds like something is rubbing in it. Any idea what it might be, and how to fix it?
heatman101
76fg
Jun 24, 2009 | Maytag Neptune MDE4000 Electric Dryer
Maytag Neptune MDE9700AYW Elec. Dryer. Drum Not Turning
the problem is with its motherboard .. i too had the same problem.. ask the repairing persons to change the motherboard if it is warranted. ( but there is no other way)..
Apr 21, 2009 | Maytag MDE9700AYW Neptune 174 Electric...
Maytag neptune dc
I have a Maytag Neptune drying center. The top unit is making a very loud banging noise. How can it be repaired, is this a common problem?
Apr 18, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE6700A Electric Dryer Logo
471 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
