Question about Car Audio & Video
What's your problem?Kenwood kac-6295 shuts off then turns back on at high volumes
    Master:
  • 689 Answers
You got a (Problem) I have never heard of a amp doing that, In the 40 pus years, That i was a certified electronc technician, But like they stay you learn something new everry day,
Posted on Nov 07, 2012
  • 3 Answers
SOURCE: Why does my KAC-8404 cut off at high volume bass?
My uncl had the same problem and he went back to the audio shop twice...Then called me...I discovered that the powr cords they used were not thick enough,giving the amp a low current to work on...but if you have the original cords you got when you bought the amp...it might also be a weak power supply....try playing the music while driving on a high speed or while reving the car to give more voltage from the alternator...If that doesnt work...come and shoot me please...im out,PEACE
Posted on Dec 29, 2008
jhall1793
  • 60 Answers
SOURCE: how to hook up kenwood kac-7204 1000watt amp
I found the manual & have pasted the url here for you. some things to keep in mind. according to the instruction manual this unit is rated @ 500W, not 1000W. Also to maximize the output you should use 2ohm speakers for stereo applications. Also make sure if you need to extend the power wire, use 10 gauge copper & make sure it's connected to the car battery thru a 60 amp fuse. Also make sure the ground is attached to a clean metal frame or body part by using a bolt & nut not merely a screw. Good luck. If you need additional assistance let me know.
http://inform3.kenwoodusa.com/manuals%5Ckac7204.pdf
peace-out
Posted on Jan 06, 2009
  • 5 Answers
SOURCE: Kenwood KAC-8103D Power Amplifier wont turn on
it sounds to me like its burnt.but with some amps the screws that hold it in place have to be screwed into the car chassisfor grounding. be careful not to srewe into hidden wires.
Posted on Apr 15, 2009
etirbynnor
  • 655 Answers
SOURCE: To bridge a Kenwood KAC-9102D
Hello laurogleal,
The Kenwood KAC-9102D is a mono amp. There is no bridging. Having two sets of terminals is just a more convenient way of connecting two subwoofers. The amp is stable down to 2 ohms impedance, so it is safe to run 2 4 ohm loads in parallel.
Hope this helps.
Posted on Apr 28, 2009
97F350diesel
  • 1326 Answers
SOURCE: i have a kenwood amp. kac-7285 dont turn on
Not much to solve this one. Either blown fuse if fuse is good and you have solid ground (check continuity), power and remote (use volt meter) your amp is no good!!!
Posted on Sep 14, 2009
Did you wire the speakers in series or parallel? 4 ohm speakers in parallel actually come out to equal 2 ohms wich most amps would see as a short causing protection issues. 4 ohm speakers in series equals 8 ohms which should be fine for your amp. been there : expert-tech / SAM
Mar 27, 2012 | Car Audio & Video
I have a kenwood kac-9152d amplifer and it works just fine for about 10 minutes then just shuts off and subs dont work, about 30 seconds later my amp turns back on with the subs.
make sure it's well ventilated. If there's no air flow, then there is no way of cooling down and to protect itself it will shut off. Make sure the speakers are wired correctly as per amp specs. too many subs or subs connected improperly can draw too much current and shut the amp off, but you will notice this when you turn up the volume to a certain point and the amp shuts down.
Aug 30, 2011 | Kenwood KAC-9152D Car Audio Amplifier
When I turn up the volume the amp shuts off and displays an E-03
do you have your subs wired down to 1 ohm? The reviews on this amp is not very good, a lot of people said they had a lot of problems with this amp, a lot of blown fuses and cant take a 1 ohm load
May 12, 2010 | Kenwood KAC-X1R Car Audio Amplifier
HAVE A KENWOOD AMP MODEL KAC-9102D . iT KEEPS SHUTTING OFF WHEN i TURN THE RADIO LOUD. ANY SUGGESTIONS
either bad ohm load or over heat if the ohs on the speaker wires to the amp are lower than specified use in the manual it will act funny cause it is pusing harder than its meant to and if it gets too hot either bad location or bad amp you can try turning the gain down a little until the amp stays on constantly at high volume
May 18, 2009 | Kenwood KAC-9152D Car Audio Amplifier
Poor sound/ Unable to play anything load without distortion.
i can tell you right now base on the vehicle you have a bad system hook wosrt if you are using factory head unit
Mar 25, 2009 | Kenwood KAC-8151D Car Audio Amplifier
Amp shutting off
your amp is likely over heating.Does it have enough air space around it? You may be over driving it does your head unit have variable out put? if so try lowering the output volume to the amp
Hope this helps...........Good Luck!
Dec 14, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Kenwood KAC-6201 AMP
The Kenwood KAC would be 2 ohm stable.
I ran my sub's in parallel and the amp did not shut off and hit pretty well for long periods of time.
If you are running two dual voice coils.
Bridge amp, run pos and neg to pos and neg outside of box.
neg and pos to one side of sub
The other side of the sub run to the next sub
the other side of the sub to the inside of the box pos and neg.
pos and neg outside of box to the other outside terminals to create a complete loop.
If this isn't a good description post back and I'll email you a picture of it.
Apr 03, 2008 | Kenwood KAC 6201 Car Audio Amplifier
Kenwood KAC-9152D monoblock
The amp says it's 1 ohm stable, so assuming the DVCs are dual 4 ohm, you should be able to connect all "+"'s together and all "-"s together, like the picture below:
As for the amp shutting off for a few seconds, it sounds like it's either:
A) Not getting enough power at high volume.
OR
B) Overheating.
The cap on the +12V to the amp should help, but putting a meter on the +12V might tell you whether it's dropping too low (<11V).
When you first turn the volume up, how long does it work fine before shutting off? Is it with the vehicle running or not?
Mar 25, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Off and On at mid and high volumes
sounds like you have a problem with your grounding on you amplifier. check for shorts on your amplifier and the place where you have it grounded. (or check the power wire also.)
Nov 01, 2006 | Kenwood KAC-7202 Car Audio Amplifier
Car Audio & Video Logo
41 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
