How to get audio on my magnavox tv - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
If no sound look for : does it get sound with a dvd player connected, check speaker/s to make sure not bad, and last if a earphone jack is there try that---the jack often cuts the sound off when it should not--gets dirty or worn from age.
Posted on Nov 06, 2012
How would I connect external speakers to a Magnavox 40MV324X smart tv. I don't see audio out ?
most smart TV's today connect a surround or ext speakers via Bluetooth (wireless)
although is that I see a digital optical audio output on your photo (yellow)
Oct 28, 2015 | Magnavox Televison & Video
How to hook up a magnavox dvd to a panasonic tv i tryed useing all the imput that i know and i still can got get a picture
If your Magnavox DVD player has outputs for left audio, right audio, and video, they connect to corresponding inputs on your TV. You may be misconnecting the wires.
Dec 11, 2013 | TruTech PM1919BXA1 19 in. LCD TV
Dvd/vcr recorder magnavox model mwr20v6, i got probelm hooking up my dvd/vcr recorder to my cable converterbox an tv , because i broke the antenne/ out socket on the back of the unit, how can i get it to...
Hi,If I understood correctly you broke antenna out socket of Cable box..ok no problem,your TV and cable box should have other jacs/socket for this connection as well..
Take the A/V output of your cable box into TV possibly with RCA cables..than you can select the channel thru Cable box on TV ..(AV mode needs to be selected on TV )
** in order to listen and watch your
magnavox DVD 's "2xRCA audio" and "1x RCA Video" cables "OUT" should go to Tv or Cable box "IN" connections separately ..("IN" goes to "OUT" of other ..pls remember,Always reverse connected ) (audio will come thru Receiver and TV.)
Since you successfully connected your Receiver to play video on TV (one way only ) ,here is the second reverse action if you wish to listen or RECORD a program on your TV on
magnavox
** you need to connect "Audio Output " as can either be : RCA jacks or "Optic cable output" or "SCART "connector " of your TV or Cable box .( every TV -cable box has different type of Audio out jacks )
** to "iRCA nput or "Optic Cable input"
of your
magnavox (whichever you want ,based on the necessary cables on your hand )
There you go..Tv/Cable box video and sound are both on the
magnavox for recording..
Hope this helps!..if more help requires pls let me know.
Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to
continue f
or Helping out the Community :)
Jul 15, 2011 | Televison & Video
No audio and have a thin white verticle line across tv
Always suspect a bad EEprom...very common on this TV! See a tech, he will have to select one of six eeproms to fix this!
Jan 10, 2010 | Philips Magnavox 27MS343S 27" TV
How do I connect my magnavox dvd player to my tv?audio in or video out? I also have wave braodband but disconnected
Audio out and video out should be connected to the tv using rca jacks. Or you can use the cable connection to the tv and set the tuner to channel 3 or 4.
Sep 26, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
HOW DO I CONNECT MAGNAVOX DVD/ VCR TO VIZIO FLAT SCREEN
Is simply. get the audio/vido cables and look on the back of the TV and connect from the audio video outputs from the combo to the audio video inputs on the tv. remember the colors of the terminals and connect them that matches the red, white (audio) and the yellow (video). Using the remote locate the button "input" or "source", and select video 1 or 2, depending where you connected it.
Nov 18, 2008 | Philips Magnavox DVD/VCR Dual Player
Philips magnavox rear projection tv mn 9p5514c101
If you have any of the following problems you may want to check the site www.tvrepairkits.com for a repair kit. Most of the issue below are fairly common with the older Magnavox projection sets.
Symptom: Screen shrinks and expands - may or may not correct itself after the TV warms up. After a few days, weeks, or months of having the shrinking/expanding problem you may loose all audio/video but the power light will remain lit!
(Note: The below symptoms typicaly occurs after having the expanding/shrinking screen problem above)
Symptom: No Audio or Video but power light is on
Symptom: Audio works but no Video. Power light still work
Symptom: No Video. Audio is intermittent. Power light still works
Oct 11, 2008 | Philips Magnavox 9P6034C 60" Rear...
Magnavox lcd flat screen tv
Is it only one time? If it is out of the speakers this could be going from analog audio to digital audio. It could also just be the cabinet expanding and contracting.
Feb 04, 2008 | Philips Magnavox 27MS343S 27" TV
Magnavox tv
In menu page Audio>Stereo>Mono>SAP.......Audio is sometimes called MTS........................T.
Jan 24, 2008 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
Electro Med Services...
