Question about Riso RZ220 Duplicator
Problem installing inkless riso drum
I'm having trouble installing my new inkless riso drum in my Rz-220 UI. everything seems to be going great but when I type in the code to get it to pump ink it churns for a while then says "Replace ink cartridge". if I start up the machine again and take the ink cartridge out and then back in I can get it to make a master and even start to print but no ink comes out and after shooting out about 30 sheets of blank paper it goes back to "replace ink cartridge". it's not showing me any error signs. could anyone suggest any parts I might want to hit with some rubbing alchohol and a q tip to see if it's some connectivity issue? also, it says in the instructions for setting up the drum to "lead ink to the nozzle in advance" and I have no idea what that means so maybe that's what's throwing all this off. could anyone elaborate on that?
  • 34 Answers
SOURCE: Riso Rz 220
Remove the master that is on the drum. Then check the master roll remove it cut about 18 inches off then re install master roll. hit the reset, then print bottons.
Posted on Jul 30, 2008
iservice
  • 318 Answers
SOURCE: Riso Rz 220 copies are coming out to light.
1)You can set the dencity of the riso on the controll panel before you do your masters.
2)Always use original ink.
3)If you are a bit technical you can remove the pressure roller and strip all old ink buildup from it.was it with water ann soap.
If you open the drum and take it out completely,the pressure roller is the black roller inside the machine that put directly pressure on the drum.There is only one screw to loosen and then it hooked out,but it can be tricky to hook it back if you not doing it every day.
Posted on Oct 30, 2008
  • 81 Answers
SOURCE: Displaying A05-305
make sure that you empty the master disposal box...
also check for this sensor. if it is not present you will need to have it replaced
Posted on Jul 07, 2009
  • 17 Answers
SOURCE: i have a problem error fo115 of riso rz-220
F01-115 means no master on drum at start of printing. Make sure you make a master before trying to print.
Posted on Mar 30, 2010
  • 1040 Answers
SOURCE: riso rz220UI doesn't deliver ink to master evenly.
It seems that, There is a problem with print head.. it may be clogged or damaged... clear the clogging or change the print head...
Hope this has helped you.. Thanks..
Posted on Jan 19, 2011
Riso RZ 220 UI The master drum will not come out and the green light is not on.
This is for master drawer not responding to green light to be released question. Try turning ON machine (turn off first) while holding down the reset button. Also a mechanical way is a small hole to insert a pencil, eraser end first, just below green latch area. Just insert hold in while squeezing release latch. to drawer.
Sep 09, 2013 | Riso RZ390 Duplicator
Necesito bajar el driver de la riso rz 390 ui gratis
Please follow this link to download the driver from the original source - Riso:
http://www.risographie.de/riso/index.jsp?page=187&lang=1
Please notice that this site is in German language, but do not hesitate you will find what you need!
Apr 21, 2011 | Riso RZ390 Duplicator
Somebody that speak Spanish? Riso RZ 220 UI have a code that say P18 531. What is the problem?
P18-531 means: Print drum lock sensor is still ON even after 100 milliseconds after the print drum lock solenoid is activated.
Mar 16, 2011 | Riso RZ220 Duplicator
How do I make riso RZ 220 can print image area B4?
only solution is to buy a B4 drum, to costly and involved to modify A4 or other drum and will create many problems in paper transport timing.
Jan 05, 2011 | Riso RZ220 Duplicator
I have a Riso 390 ui RZ i did an electric chock accidentaly on my building the duplicator was working, but after the chock it smelled like smoke inside the machine now it doens't star what part do I...
You have a small circuit board. That is after the power source.Unplug and open the duplo.The circuit board you can order from Riso and have installed by an authourised technition.Good luck
Aug 13, 2010 | Riso RZ390 Duplicator
Riso rz 220 falla a 16 525
Remove the master that is on the drum and press reset. You may have to press start if you see - - - - on the display.
May 29, 2010 | Riso RZ220 Duplicator
I have a problem error fo115 of riso rz-220
Jan 20, 2010 | Riso RZ220 Duplicator
F0115 riso rz-220
The code means there is no master on the print drum.
Jan 19, 2010 | Riso RZ220 Duplicator
Riso RZ 220UI
1-need to find out if image is on the drum, make a copy and stop it open and look is there toner on the drum itself? yes then the problem is with the Seperation
2-No, then the problem is with the Transfer
Sep 05, 2008 | Riso RZ220 Duplicator
RZ-220 Error Code P04-513
that is the ink overflow sensor.
Jun 20, 2008 | Riso RZ220 Duplicator
Top Riso Office Equipment & Supplies Experts
Marius Chiriac
paulfvincent
Adorjani Laszlo
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
