Question about Refrigerators
My Kenmore Model 106.58962702 Refrigerator runs all the time.
We recently bought it used and moved it in a utility trailer. My husband is not happy that we spent good money for a broken refrigerator, but I think there might be a logical solution!
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
If the fan motors are running all the time also it appears the problem will be with the cold control (thermostat). This is the only control that will cycle the compressor on and off in this unit. If there was a short in the wires the compressor would still run when the thermostat is turned off.
Posted on Nov 06, 2012
  • 3 Answers
SOURCE: Refrigerator
there is a drain hole at back of your fridge on the inside which is probely blocked take out the shelfs you should see a channel in the middel that where the drian hole is situated unblock the drain hole[DO NOT USE A SHAPE INSTRUMENT ]hope helps
Posted on Sep 20, 2007
  • 27 Answers
SOURCE: Kenmore Refrigerator Model #795.75004401 Doesn't get cold
Hi. Make sure all your fans are working. When checking fans, open the door and push the light button in. Some models the fan stops or dampers close when the doors are opened. Put your hand in front of the vent and see if you feel air. Do the same in the refrigerator and freezer. If you feel air from both, check and see of the compressor is running. There is a fan next to the compressor and should be running when the compressor is running. You have a motherboard behind a cover on the back of your refrigerator that controls all of these functions. It could be defective. Motherboard failure is common as well as compressor and evaporator motor failure. Fan Motor failure is common for refrigerators in storage for a long period of time. The motors are weak and can't start. This goes for all new refrigerators. I sell refrigerator items on Ebay as username, themackshack. Good Luck, Mack
Posted on Feb 03, 2008
SOURCE: Kenmore refrigerator
maybe its you!
Posted on Oct 11, 2008
  • 16 Answers
SOURCE: Kenmore refrigerator 26' side-by-side Model 596.52673200
on the amana rifg pull both knobs off
on the right side of control panel remove a 1/4 in screw
remove plastic panel now u can get too the part
Posted on May 13, 2009
  • 2187 Answers
SOURCE: DOMETIC RM 2214 Refrigerator in Travel Trailer
Check first if the distance of the fridge to the wall is enough or has similar air circulation as with its previous location. Inspect the coil at the back of the freezer for dirt or ice build up. See if cleaning the unit including the back of the freezer will help.
Posted on Aug 22, 2009
'04 Kenmore side by side, refrigerator part maintains 60 degrees.
HI, GIve it 24 hours before you panic. If the fans are running and the compressor is running, you should be ok. Make sure the fan underneath is running. Sometimes when moved, something will get caught and stop the blade.
Please let me know if I can assist you further.
Vic
May 30, 2009 | Refrigerators
Hi, we recently bought a 2010 Honda odyssey and ha...
is the trailer attached to the ball on the van?? could be a ground problem,,run a jumper from hitch to trailer see if that works,,
May 21, 2010 | Cars & Trucks
Kenmore refrigerator model 106 will not cool fridge or freezer
is your refridge leveled if not level it and stable. Try turn it off for a couples of hours and then put it back. does the refridge move a lot when u open it fix this refridge doesn't has to be moving when opening when on and moving this agitates the freon creates more pressure so it has a pressure switch and turns off the compressor to protect it from over or under pressure
Jul 24, 2009 | Kenmore Refrigerators
The motor on the Kenmore refrigerator is running continuously. How do I stop it? I just cleaned out the dust from the coils underneath and replaced the kick-plate at the bottom
Hi: I've dealt with Kenmore for 30 years. Unfortunately the new model numbers don't reveal the age. I must assume it's a newer model. I'm not disputing what you said about it running all the time, but please read on. Oddly enough the new energy efficient referigators run 70 to 80% of the time. They use a smaller compressor without the big amperage start-up. The best I can describe them is that they freewheel alot. The 106......of your model number means it was built by Whirlpool. A very quite and energy efficent refrigerator. If your power bill is high get a meter from your power company, most have them. Just to double check the power consumption. Good luck Jeff
May 27, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Just moved Kenmore s/s co;d spot. edges are now hot
This is caused by a failed condenser fan motor. Since it was recently moved, I suspect the fan blade has been blocked from spinning. Pull the fridge out and remove the cardboard cover near the floor. See the fan? Check for obstructions. If there are none and the fan is not spinning, reach in there and give it a whirl with your finger. It may spin right up, it may not.
If all else fails, you'll need to replace the fan motor. Write back with the model number and I'll get you part numbers and step you through the repair. Deal?
SG
Mar 29, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Freezer in my kenmore refrigerator isn't cold
Make sure the freezer fan motor is running. The wires may have come off when it fell.
Mar 08, 2009 | Kenmore Refrigerators
HOW OLD IS A KENMORE MODEL 25862
I bought my model 25862 in May, 2005. The only thing that has ever gone wrong is the plastic gear that runs the agitator on heavy duty broke. My husband ordered and replaced for under $30.00
Aug 05, 2008 | Kenmore 25862 Top Load Washer
No Ice or Water
The water inlet solenoid valve orifice may be plugged. Locate the water solenoid valve where you connected the water line to. Shut off the water and then check this orifice and screen.
Apr 02, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Jan 10, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
62 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
