Question about Necchi Sewing Machines
I have an older necchi supernova freearm sewing machine. The thread is getting behind the shuttle after a few stitches. How did I check or change the needle timing?
  • 399 Answers
SOURCE: I have a Brother SE-270D
its the problem of the timing belt in your machine its extra loosen or extra tightned or is slightly came out of its position or finally broken.
as the machine is proper just missing the proper speed as it should be .
it is running continuosly as you stated.
check the timing belt and make it proper if its worn out and needs replacement this is how its done
There is an adjusting screw on the right side of the machine head. Follow the motor bracket to the machine head and loosen that big old screw or bolt which will raise or lower the motor giving you slack to remove or replace the belt.
feel free for further queries
thanks
Posted on Sep 19, 2008
SOURCE: singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
Posted on Mar 15, 2009
SOURCE: 6022 necchi sewing machine
There is a site that has instructions with how to thread the machine properly. Click here for the www.sewusa.com threading section
Posted on May 06, 2009
bargainbox
  • 1388 Answers
SOURCE: Sewing machine not stitching at all
SIX Layers !!!!
You really need a size 16 needle that won't bend and miss the hook by the sound of it....can you sew on less challenging thicknesses OK ??
If not, the timing may need adjusting...here is a link to assist:
HERE
Posted on Aug 02, 2009
  • 152 Answers
SOURCE: bobbin thread gets bunched up and loud clicking sound
The problem is never the bobbin when you have this problem. It's the top thread. Take the thread off the top of the machine and rethread the top. Make sure the small tension dial is on 4 or 5 (the larger dial on the front left is for the pressure on the foot, not the thread tension.) After you thread the machine, put the pressure foot down but NOT on the thread. Then pull gently toward the back of the machine. When you do, the needle should bend slightly backwards before the thread comes through the machine. If it pulls with no resistance you could simply have "fluff" or remants of thread between your tension discs. If you do, put the dial on zero and using an old needle, clean between the discs and try threading the machine again with the "pull test" I described earlier.
No tension on the top of the machine, lets the bobbin tension win and it pulls all the thread to the bottom of the fabric.
Posted on Oct 06, 2009
Who manufactures the ultra dressmaker free arm sewing machine?
NO idea look on the machine for a name like SINGER
Jan 09, 2016 | Sewing Machines
Necchi supernova manual
Most sewing machines can use a double needle, the one with the single mounting shank and it turns into two needles.
MAKE sure you have Zig Zag needle plate installed to accomodate the double needle.
Turn hand wheel slowly to test then use thread and fabric and turn flywheel by hand to test sew.
Jul 19, 2014 | Necchi Sewing Machines
What is the difference in Necchi BF and Necchi BU?
Necchi BF is a straight stitch machine
Necchi BU is zig zag machine
Necchi BU Supernova had cams for additional stitches
Jul 17, 2014 | Necchi Sewing Machines
I have necchi sub22 and the thread keeps coming out
Does this happen with every spool of thread? If so, you either aren't starting the seam correctly or have slightly misthreaded, or the machine is in need of adjustment. See: http://www.picturetrail.com/sfx/album/view/22521551 Thread the machine with the presser foot up. Put it down to sew. Hold both the bobbin and top thread ends together behind the presser foot for the first few stitches of each seam -- then you can drop and sew normally. Not all machines need to have the thread ends held, but enough do that you might as well get in the habit.
Apr 28, 2014 | Necchi Sewing Machines
Need to find a necchi supernova bu check spring
check with these sites for the part--call them or email them
sewvacdoctor.com
a1sewingmachines.com
Oct 09, 2012 | Sewing Machines
Why does the shuttle hook grab the spool thread instead of the bobbin thread? It wraps the thread around the bobbin and binds the machine up.
The shuttle hook is suppose to hook the needle (spool) thread and loops it around the bobbin case to form the lock stitch. Is it possible that something was adjusted without proper clearances as to allow the thread looping around the bobbin case to do so without catching up where it should pass through freely?
~<Ray>~
Nov 13, 2010 | Necchi Sewing Machines
Kenmore Sewing Machine: stitch not forming bobbin thread problem
sounds like it needs a service call. if you do not have a sewing repair man you use regularly to clean machine the local fabric store should know who you could call.
Jul 20, 2017 | Kenmore Sewing Machines
My needle will not stay threaded. It gets gobs of thread on the underside of the fabric, and does not stitch at all evenly. I have a 1965 Necchi Supernova, and I love the machine.
try rethreading, make sure the foot is up, change the needle, make sure there are no loose threads or lints under bobbin case. You might also try rewnding the bobbin to make sure it is wound evenly.
Jun 19, 2009 | Necchi Sewing Machines
Stitch length control knob broken on my Necchi Supernova Julia
Contact Necchi directly (800-525-9987) and speak with the Service manager who may be able to get the part for you if they are available anywhere.
sewman7
Apr 24, 2009 | Necchi 4595 Mechanical Sewing Machine
Necchi 4575
I've found that my machine doesn't like Coats & Clark thread; I have to feed it Guterman
Feb 06, 2008 | Necchi 4575 Mechanical Sewing Machine
Sewing Machines Logo
60 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
