DVD DOOR WILL NOT OPEN.
DVD DOOR DOES NOT OPEN . MOTOR SOUNDS LIKE IT IS TRYING TO OPEN DOOR BUT DOOR DOES NOT OPEN
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Someone needs to open the unit to see if a jam or something is blocking this--could be easy but you have to SEE what is wrong first.
Posted on Nov 06, 2012
Dvd door will not open or close when eject/open button is pushed. I can open door and slide tray out by hand, howevery when disc is inserted in tray and pushed back in, system does not read disc as being...
The low humming sound is the motor that opens and closes the drawer. It is moving, but the movement is not being transferred to the door by a pulley, a belt or a gear, When you open the drawer completely, it should stop. When the drawer is closed completely it continues to run until the disc is in the proper position to play. As long as that motor is running the DVD will not work because the disc is not in the proper position,
Feb 03, 2018 | Panasonic PV-D734S DVD Player/VCR
Go Video DV 2150 - DVD door won't open at all. You can hear a mechanism working behind the closed door, but nothing happens and the door remains shut. Any advice??
There is a small belt under the loading tray which would have gone slack ( loose ) and the sound you hear is it slipping on the motor pulley. If you are confident you can remove the mechanism and turn it upside down and access this belt. Dismantle only if you can get the spare belt or your efforts will be in vain.
Sep 13, 2011 | GoVideo Go Video DVD/VCR Combo
My draw will not open
Hi, If you hire sound of motor (when you push the switch) who open the door then is rubber band on wheel inside DVD, or cd is stuck inside. In that case you can hook door with something and pool up easy! If no light on displey, or don`t hear motor (when you push the switch) then is electronic circuit in DVD, then you must go in service.
Good luck.
Feb 27, 2011 | Philips DVDR3440H DVD Recorder/HDD...
DVD drawer won't open. Worked perfectly the other night. Now makes the normal sound but doesn't open. I used paperclip and opened it and took case off and didn't see anything wrong, but I've never looked...
Repair it ur self,if u can,not than buy a new one,this things are cheap these days.The shop,probally cost the same to the repair priced as a new on.Check the motor that open the tray door,see if that motor is spinning?The motor that open the tray door,might be dead.Tries unplug,replug it an hour later,see if the thing reset itself.Might work again.
Oct 19, 2010 | Panasonic PV-D734S DVD Player/VCR
Hi there, My sony rdr hx510 will not open and is making a grinding rotating sound. Baby girl either put 1 one or 2 discs in incorrectly. Can you advise on how I can get it opened and renove the discs.
Must used a philip screw driver take out all the screws to the dvd player.Must take the DVD player aparts.Take aparts out the dvd player guard shield to the dvd drive to take out the dvd dic or dics out.Don't push the open button any more,the disc or discs is jamming ur dvd door tray.Will burn out ur disc tray motor,if u keep trying push the open button,trying opening it that way.
Sep 24, 2010 | Sony RDR-HX520 DVD Recorder
Unable to open the door of the dvd --when you press the eject button to open the slot---the door does not open---everything else works
Quick trick
First let's find out if the motor is dead or
the magnetic clamp is to strong for the motor.
Press eject then listen closely for the sounds of struggling motor
if you hear it trying SLAP the top right over the DVD drive
and that should break the magnetic seal and release the tray
you may have to try a few times Press eject and open hand slap kinda
hard the top of the DVD drive , don't worry you won't hurt it.
if that works email me and ill tell you how to fix this.
Rob
rsheehan@northernsteeldesigns.com
Oct 14, 2009 | GoVideo Go Video DVD/VCR Combo
Dvd player will not open disc, display lock
Sound like it either has one or two problems, the door is stuck and or the door eject motor has failed. Look in the front to the player for a small paperclip like hole, and use a paper clip to manual eject the and engage the loading mechanism usually located under the door for most cases. Check you manuals troubleshooting section for manually ejecting a CD..
Please leave comment.
Oct 12, 2009 | JVC XV-N312S DVD Player
I have a broksonic sc-20145 and the dvd player drawer will not open/close. could it be a bad motor?
With your ear next to tv do you hear the sound of a motor trying to open the dvd door. If so probaly a plastic gear that has failed that opens the dvd door otherwise could be the motor. Just go buy a $30 dvd player and connect to the tv input. not worth repairing and stay away from tv/dvd combos in the future for this reason that your having to expierence now.
Aug 15, 2009 | Televison & Video
DVD door won't open. Display says "open" & "close" when button is puched, but nothing happens. Have tried all troubleshooting steps in manual.
sure its a caused of stock up. unplug power and open cover. check the the motor belts and gears maybe have broken.
Aug 14, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Pioneer DVL-919 DVD door does not open
You can also try flipping the player upside down and shaking it a little. I bought a DVL 909 and when it arrived the tray wouldn't open. The seller told me to try that, and it actually worked. I wouldn't recommend shaking it quite so much as this video shows... but it does show that it can work.
Dec 14, 2007 | Pioneer DVL-919 DVD Player
Televison & Video Logo
Top Televison & Video Experts
