Question about Samsung HT-AS720ST Theater System
When turn on right front speaker static then goes away
Whe I first turn on the right front speaker has static then goes away I saw something about a pulsar card?
How to eliminate occasional but very loud intermittent static coming from front center speaker.
Probably bad speaker, but you might check all wiring to it for loose connections.
Jun 08, 2015 | 2006 Saab 9-3 Aero
Change blade without hitachi wrench
Which way do i turn the nut on the saw blade to change my blade? to me or away from me? looking at it from the front.
Mar 03, 2013 | Hitachi C10FR 10" Job-Site Table Saw 15...
On my 2003 Avalanche, after the radio has been on for a few minutes static starts in the front right speaker then travels to all of them. As the static gets louder the radio volume goes down and the static...
take out the speaker in question and test it.
a 9v battery is good enough to 'burp' it.
if it makes a scratchy noise when you put power to it then you have a short in the voice coil.
Burping a speaker is just a short power up. Don't hold power to it.
Tap it on and off like a music note measure.
Apr 16, 2017 | 2003 Chevrolet Avalanche
I have been experiencing static noise/crackling from my front left and right speakers just recently. (I have a 5.1 dell system - the front center - attached to the monitor and rear speakers do not emit...
This seems like at cables have gone bad or either the connections in the speakers went bad. Its best to replace them unless you know how to disassemble and re-soder the connections.
Mar 01, 2011 | Dell WL6000 Computer Speakers
Basically, I've noticed a fairly faint static noise while listening to music at about 30%-40& with the Logitech z-2300's. I dont know if the problem persists when the speakers are any higher because I...
Most speakers I have owned or listened too have a faint buzz or static to them. If you are using a computer turn up the volume on the computer all the way and then you should not have to turn the volume knob on your speakers past 20% that's what i did with mine and they sound fine. If you are using something else like an i pod or something like that make sure you turn the volume on the device all the way up to ensure you don't have to turn the speakers up that high. If that's not your problem then i don't know.
Dec 12, 2010 | Logitech Z-2300 Computer Speakers
When I plug in my speakers, they make a constant static sound. It can become quite loud at times and I've found that turning the input chord around can sometimes work, or unplugging the charger for my...
if your speakers are near to some electronic devices you'll get theses static noises try to keep them away from electronic devices which solves it very easily..
Sep 30, 2010 | Audio Players & Recorders
Speaker sounds very staticy
This is normally due to a bad connection, however it can also be caused by a blown speaker. replace with another speaker to see if the static is still there, if you still hear the static then the speaker is fine and the wire is broken somewhere, is the sound of static goes away then problem solved.
Apr 04, 2010 | 2003 Mitsubishi Eclipse Spyder
Static crackle on yamaha 6030 in 5.1 ..static dissapears if you switch to two channel. coming from bell hd pvr...and sony ps3. with ps3 i have to select audio from dvd or blu ray menu and then 5.1 and...
It might be a bad connection then. First try and swithch it to a different outlet and settings. If it does not work it mightn have to be fixed then.
Mar 28, 2010 | Yamaha HTR-6030 Receiver
Dryer makes squeaking, rattling noise whe starting. Goes away after a couple of minutes.
sounds like your bogie wheels may be starting to ware out they are bottom left and right drum inside front panel if worn they take 10 mins to replace
Dec 18, 2009 | LG DLE2532W Electric Dryer
Static from right from speaker
The noise is in the pre-amp stages of the Denon AVR. It might be caused by bad capacitors.
Mar 08, 2017 | Denon AVR-1803 Receiver
Samsung HT-AS720ST Theater System Logo
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
