Yamaha rx-v1900 receiver suddenly cut out all sound after 20min of working perfectly. Wires are secure. Ps3 and HD cable box hooked up all through HDMI...including HDMI to 1080P TV.
  • joeldayao May 19, 2009
    Same problem- whenever I turn it bit louder to at least +14 volume and playing a hard rock music.
  • 120 Answers
Do you have the ventilation holes covered so air cant get in to let heat out? it sounds like a thermal related problem.
Posted on Jan 06, 2009
How do I link mt remote (rx-v1900)with my tv
OK. So did it come with instructions? If not, it is a rip-off. I suggest you contact your retailer in that case.
"I know what I know because I know what to do!"
Feb 07, 2010 | Yamaha RX-V1900 Receiver
I need to hook up a yamaha 465 receiver
It has two HDMI inputs and one HDMI monitor output for the TV, so assuming all your devices are HDMI-capable, YES.
Nov 28, 2009 | Yamaha RX-V463 Receiver
HDMI out jack physically broken on my rx-v1900. Fixable?
An audio repair shop should be able to get a replacement connector and swap it for you. I doubt that the part is available from Yamaha (and it would be pricy if it was). The connector shouldbe available generically. Digikey or Mouser should be a good source.
Nov 18, 2009 | Yamaha RX-V1900 Receiver
Hi where can i downlowd a manual for the rx-v1900
I would start at the web site's support page. Find a Support page, and then look for Downloads. Be prepared to enter specific info about your device, like model number, serial number, etc.
If that fails, enter something like: yamaha rx-v1900 user manual in Google and you should see many different references to it. Spend a few minutes browsing the most likely places by reading the headings.
Aug 21, 2009 | Yamaha RX-V1900 Receiver
Intermittant Audio with Yamaha RX-V465 only from cable box
I have the same receiver... You can try pressing the Option button and choosing Signal Info to see what audio signal the receiver sees and if that changes over time. Maybe the cable box is not outputting according to specifications... TV can live with that, but receiver maybe can't.
You can also try to connect the cable box via SPDIF cable (optical or coax) to see if it helps or not.
Jun 05, 2009 | Yamaha RX-V463 Receiver
Problem hooking up my Yamaha RX-V461 to my PS3
When you connect the optical cable to the ps3 you must change the output to optical on the ps3. To do this, startup your ps3 then go to settings then audio output settings and change it to Digital Out (Optical).
Dec 01, 2008 | Yamaha RX-V461 AV Receiver
No dolby digital signal
Put your optical cables into the amp and not the tv,also make sure the ps3 audio is set to bitstream.
hope this helps.
Jul 12, 2008 | Audio Players & Recorders
Setting up Cable with HDMI
Yes, the firmware on your hdtv box has an old firmware, I switched my old hdtv box with a newer one box and the problem was solved. It seems that it can't work if your hooking up with DVI to HDMI cable to your receiver to tv. Your hd box must have an HDMI out otherwise it causes problems. I also have rx-v661 and i finally hooked up everything HDMI to the receiver and then to the tv and it was having the problem you speak of. After I switched out the hd box for a newer one everthing worked fine.
May 13, 2008 | Yamaha RX-V661 Receiver
My HDTV has no HDMI and I'm not getting a picture on the TV except for the Yamaha Backscreen
tell cable box 480 i putput not 720 p even tho big screen has hd inputs its not true hd ok unplug plug back in see if get cable box to defult u or take card in front in and out most likely tv cant handle 720 p or 1080 i if its on 1080 i bring to 720 still no pic tak ethe cable box out settings to 480 i ok try that 1st
Jan 06, 2008 | Yamaha RX-V2700 Receiver
348 people viewed this question
