Question about Apple MacBook Mac Notebook
I dropped my laptop in my garden and had trouble closing it. I thought that a piece of mulch had gotten trapped in the hinges so I tried to get it out. Unfortunately, I cut what I believe is the inverter/isight cable not really sure of the name but it runs long side the three (gray, blue & black) WiFi cables. Anyway, the backlight no longer works but I can still the screen when I shine a light in the back of the display. What I really need is the correct name of this cable so I can order the part.
  • Mori Atobatele Dec 06, 2012
    Thank you it was the isight camera cable. I replaced it and now the webcamera works but still no backlight.
    Master:
  • Apple Master
  • 545 Answers
Isight Camera Cable:http://www.powerbookmedic.com/MacBook-Pro-17-iSight-Camera-Cable-p-19553.html
If you've lost video:
LVDS Cable
http://www.powerbookmedic.com/Macbook-Pro-Display-Cable-LVDS-17-Models-p-17115.html
Posted on Nov 09, 2012
5 Suggested Answers
SOURCE: Screen works up to about 45 degrees open then
Having display cable replaced.
Thanks!
Posted on Nov 06, 2009
  • 502 Answers
SOURCE: I changed my macbook screen,
This could be a backlight issue, an inverter issue or a logic board issue. Look at the screen closely, if there is a faint image it's either a backlight issue or inverter issue. To weed out between the two you can just order on inverter, they're 20 bucks on ebay, if that doesn't work, replace the backlight. Maybe the new screen was not wrapped right when it was shipped, that can easily break the backlight bulb. make sure you connected the inverter to the white and pink wires correctly. Backlight repairs are somewhat difficult. As much as I would like to be able to tell you a quickfix that will solve backlight the problem, it's a pretty arduous repair that requires 1-2 hours for a trained person. It's feasible to do it yourself if you're tech savy, but you'll most likely have to google for guides that show you exactly how to replace the backlight step by step. I work for Mac Repair NYC and i have to fix this problem a lot, it's so easy to break the lightbulb in the process.
Posted on May 27, 2009
shawty-lozzy
  • 151 Answers
SOURCE: Display has light, no picture
It may be any one of them, Best bet is if you are on apple protection plan or any other insurance they will fix it for you for free.
Regards
Posted on Jul 23, 2009
  • 16 Answers
SOURCE: macbook pro 17
This is very likely due to a problem with your video card, you can use Apple's Hardware Test to make sure though. You can find detailed instructions on how to use AHT here. If it is found to be, in fact, the video card; you may want to replace it. Find the exact specs of your specific Macbook (perhaps on the Apple website), find the exact model of your card and buy it from the manufacturer or a place like newegg, it should not be too difficult to replace.
Posted on May 03, 2010
How to remove mulch from fleece jackets?
You can try a lint roller, duct tape or packing tape. They work wonders for my kids clothes.
Dec 14, 2017 | Garden
My sliding door hinge broke
if it will go back in the track reinsert it in and slowly close the door..and dont use until a replacement hinge is gotten from the towyard...
Jan 21, 2013 | 2000 Nissan Quest
Oven door not shutting fully
Make sure there is nothing trapped at the bottom of the door to prevent it closing properly.
If nothing obviously wrong, then you will probably need to replace both oven door hinges as the door springs are probably weak.
A common problem with this type of oven with a drop down door.
Dec 18, 2010 | Whirlpool RBS305PDS Electric Single Oven
Del 1525 webcam not recognized. Re-installed software, no luck. Is it fried?
Usually these kinds of problems are caused by the webcam cable going bad or shorting out on the hinges. These wires are usually run very close to the moveable part of the hinge and they can get rubbed or pinched in the hinges pieces. Sometimes the cables just go bad and need to be replaced. Other times if the laptop is dropped or shocked in some way, it is feasable that the cable may come loose from the socket on either the camera or the motherboard where it plugs into.
May 28, 2010 | Dell Studio 1535 Notebook
My frigidaire refrigerator door is sticking. I have to lift it up to close it. I have moved everything off the door and it still sticks
Sounds like the door hinges have gotten loose and let the door drop. With the door open can you move the door up and down? If hinges are tight you should NOT be able to.
Apr 30, 2010 | Frigidaire FRT21P5A Top Freezer...
How do I install a mulching Kit on my Husqvarna riding lawn mower?
having trouble with mulching unit on 22hp tractor.Mulching kit installed by dealer at time of purchase.What is happening is grass is kicking up on the top of the mowing unit,covering the belts and everything else.I need to do a major cleaning every time I use the tractor.Any one got some solution.
Apr 09, 2010 | Husqvarna 22 Hp 46" Deck Yard Tractor
Can't get the oven door back on. it was sitting
As you said they are spring loaded so be careful. You will need to pull on the hinge, which takes some muscle and you should see a small hole to put a pin or small screwdriver in to hold the hinge out. When this is in place on both the hinges you can put the door back on. This is the most common hinge style on Wpl or there may be tabs on the tops of the hinges to hold the hinge out. If the door still does not close all the way after getting the hinges all the way on you will need to take the door apart and replace the hinge/spring assy. Thanks for rating me after you read this.
Dec 13, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Apple MacBook Mac Notebook Logo
69 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
