My dell xps 420 just lights up but does not turn on and it sometimes the fan makes a loud noise
    Sergeant:
  • 265 Answers
Hi ,
Two things come to mind ,
1st , check you video card to make sure its ok , you can do this by hooking up a 2 nd monitor to see if it does boot
2nd , depending how old the unit is , it just might be the cpu or prosessor has fried , and that would cause it not to boot if it got to hot .
so , try the 2nd monitor , and let me know what happens.....Roy
Posted on Nov 06, 2012
    Genius:
  • 2,432 Answers
Hi not clear in the video what display in the screen after you turn on the pc.if the pc rebooting the system or no signal appear. will anyway to ensure if not monitor problem tried first to use with other monitor,if the same problem so it was pc issue. now the first thing you have to check will be the video card since their is no video appear in the screen. remove the video card then hooked up the vga cable into the vga port of the pc let see if you can get video. by the way what fan are you telling us? the fan from the power supply or the fan at the processor?.
3 Suggested Answers
joecoolvette
  • 5660 Answers
SOURCE: My Dell XPS 420 will not turn on. Power light
Hey! Nice Computer! ( At least while it was working! Specifications show some high-end hardware parts)
Steady amber light on the Power On light, means a bad power supply.
The Dell XPS 420 uses the standard ATX style of power supply found in 90% of computers out there.
(Personal computers. Not the Cray Supercomputers!)
This is Dell Support, and the User Manual - Removing and Replacing Parts - part of the manual,
http://support.dell.com/support/edocs/systems/xps420/en/OM/HTML/parts.htm#wp1466871
From Me:
1) Computer unplugged from power, computer case open. TOUCH the metal frame BEFORE you reach inside.
Your body carries Static electricity.
Static will fry out computer hardware components.
You won't see it, or feel it.
Computer unplugged from power, you are safe.
Touch the metal frame Before reaching inside, your computer is safe.
Should you get up for any reason, walk away, then return, Touch the metal frame again)
You either have a 375 Watt, or a 425 Watt power supply.
I would recommend a power supply with more Wattage, and more Amp's on the 12 Volt power rail.
The Dell XPS 420 comes with an Intel Core2 Duo processor, or an Intel Core2 Extreme processor.
These puppy's can use a lot of power when gamin', or other intense programs are being used.
The Nvidia GeForce 8800 Series of graphics cards offered, use a lot of power when maxed out.
The motherboard with the Intel X38 motherboard chipset, uses a lot of power.
I would recommend a 600 watt power supply for a replacement.
My recommendation would be an OCZ StealthXStream 600W
Why?
1) If the temperature of this PSU is kept under 118 degrees Fahrenheit, the PSU can put out 728.8 Watts reliably. (47.9 degrees Celsuis)
2) It has Four - 12 Volt power rails.
EACH power rail can handle 18 Amps.
That's a total of 72 Amps!
3) It has all the power cables you'll need.
A) 20 + 4-pin ATX motherboard power cable
B) 8-pin 12 Volt power cable (8-pin EPS)
C) 4-pin ATX power cable
D) SATA power cables [ 3 ]
E) Peripheral power cables, (4-pin Molex) [ 6 ]
F) 6-pin PCI power cables. [ 2 ]
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3092557&CatId=106
Not advertising for the above website, nor the PSU manufacturer. Recommendation supported by personal preference, and experience.
Information about the various PC power cables and connectors,
http://www.playtool.com/pages/psuconnectors/connectors.html
Posted on Jan 04, 2010
  • 78 Answers
SOURCE: my dell xps 420 will not power on. power light
Hi
If your system's power light blinks amber, it means the computer is receiving electrical power, but an internal power problem might exist.
Do the following to tackle this issue:
  • If applicable, make sure that the voltage selection switch which is at the rear of your system matches AC power in your area.
  • Ensure that the power cable is securely connected to system board.
Here are links with pictures to assist you in opening the system and reconnecting the internal cables.
Please follow safety instructions before you perform these tasks. Here is a link, which gives you complete safety instruction.
http://support.dell.com/support/edocs/systems/xps420/en/OM/HTML/parts.htm#wp1372453
http://support.dell.com/support/edocs/systems/xps420/en/OM/HTML/parts.htm#wp1372490
Next is to see the system board design. Here is the link.
http://support.dell.com/support/edocs/systems/xps420/en/OM/HTML/parts.htm#wp1402834
and if you wish to research a bit more here is the link,
http://support.dell.com/support/edocs/systems/xps420/en/OM/HTML/trouble.htm#wp1076480
http://support.dell.com/support/edocs/systems/xps420/en/OM/HTML/trouble.htm#wp1097292
Here you will find complete manuals for further research
If this does not resolve the issue, then the motherboard or processor is faulty and you need to get it replaced, so if your system is within warranty why pay extra, get it replaced from Dell. Else contact a local tech and he'll help you out.
Please rate as per the assistance level. Thanks :)
Posted on May 22, 2010
Testimonial: "Very detailed and organized. Very helpful."
Xps 420 fan
as long as it has the same connector than yes. fans are usually the same when it comes to personal computers
Mar 05, 2014 | Computers & Internet
Xps 420 start up problems error codes 1 and 3
Dean Fowler,
The 1-3 error code that you are saying that your computer is making represents a Video Memory Test failure. Try reseatting the video card in your computer or replace the video card.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jan 29, 2013 | Dell XPS 420 Desktop Computer
Xps 420 air temperature sensor
I would remove your fan & heat sink to check that your thermal paste isn't dry first.
Jul 15, 2012 | Dell XPS 420 PC Desktop
Dell xps 420 noisy fan black screen
more than likely bios isn't letting it boot, i'd make sure the fan bearing hasn't gone out, if it has you can order a new one
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Jul 03, 2012 | Dell XPS 420 PC Desktop
DELL XPS 420 Fan noise, and goes into sleep mode
Maybe the fan is going bad. Open the case and check it to make sure it is tight by tightening the screws. Also make sure a cable or wire is not hitting the fan blades causing the noise.
Go into the Power Option in the Control Panel and set your Sleep or Hibernate options up higher or set them to NEVER.
Click Start/Control Panel or Start/Settings/Control Panel and look for Power Options.
May 23, 2012 | Dell XPS 420 PC Desktop
My Dell XPS 420 will not turn on. Power light shows a steady blue color. No diagnostic lights show up.
The RAM maybe faulty.
Try resetting the RAM modules to make sure it is seated correctly in the memory slot.
If the computer still does not boot up then the RAM maybe faulty. Remove the RAM module/s and take them to your friendly computer repair shop and get them tested. If faulty then replace the RAM.
Feb 25, 2012 | Dell XPS 420 PC Desktop
I have Dell destop model XPS-420 my computer is not getting on NO FAN and no noise please advise me what should I have to do
hi
are you saying the fan is not working ? if that's the case, you need to replace the fan.
get the service tag # located on back of your desktop PC, go to this link below, place service tag in appropriate box . it will give you part numbers for the peripherals of this computer. locate the fan and purchase replacement.this is all you have to do. DO NOT TURN ON THE COMPUTER UNTIL THIS FAN IS REPLACED, or you will damage the mainboard and/or CPU.
http://search.dell.com/results.aspx?smh=sup&c=us&l=en&s=dfh&k=XPS-420%20&cat=sup
Nov 14, 2010 | Dell XPS 420 PC Desktop
My dell xps 420 will not power on. power light
Hi
May 21, 2010 | Dell XPS 420 PC Desktop
Low sound and buzz from speakers / Hum noise from sub-woofer
Select Start > (right click) My Computer > Manage
In the Management window select > Device Manager
Next to Sound, Video and Game Controllers click the + sign
A yellow triangle will signify a problem so if one is present, right-click that device and select Properties
You can then choose to update the driver
For more details check Dell Xps 420 Manual.
Dell Xps 420 Manual
Apr 14, 2017 | Dell A525 Computer Speakers
Xps 420 keeps freezing or going to blue screen
Same with my Dell Vostro 420. At this rate I will just buy a new PC as I am wasting too much time on this. We tried usual stuff like cleaning inside, making cooler, removing certain virus software, still no luck. I have to restart 4 times a day and keep saving material. Can only restart by turning it off by pulling out power socket.
Jun 24, 2009 | Dell XPS 420 PC Desktop
Computers & Internet Logo
121 people viewed this question
David Payne
David Payne
