Question about Apple iPhone 3G Black Smartphone
How do u remove the battery in a i4s phone - Apple iPhone 3G Black Smartphone
  • 61 Answers
2007 Compass. What are the probable causes of DTCs P161B and P0700?
which engine? first year is 2007
which one? errors very by , ENGINE!
2.0 L World I4 (gasoline)
2.0 L VW I4 (turbo diesel)
2.2 L OM651 I4 (turbo diesel)
2.4 L World I4 (gasoline)
p07 means transmission errors,. and need a real scan tool to read them ALL full codes, 700 means (have errors in trans scan me the correct and full way)
P161b (p1 means jeep factory codes, power train)
not B161 or P1618
are you sure, it matters.
this means the battery was low
the battery was disonnected
or while cranking at -40F starter overloaded a weak or discharged battery.... (heard the starter run slow, did you?)
it means battery voltage discover too low for any reasons.,.
P161B-BATTERY DISCONNECT / TCM INTERNAL
Feb 16, 2016 | Jeep Cars & Trucks
How change belt on aerio 2006
the cam or accessory fan belt.?
fan. (guess fan)
same on all cars.
remove or relax (as the case my be ,varies by engine size)
the tensioner.
the remove the belt.
put new belt back just like the old one came off
adjust the tensioner to spec, (depends on engine there)
there are these engines used.
1.3 L I4; 1.5 L I4; 1.6 L I4; 1.8 L I4; 2.0 L I4; 2.3 L I4; 1.4 L Diesel I4
the USA car, has
Models in North America got a larger and more powerful 2.0 L engine with 145 hp (108 kW).
is your car in USA and with 2.0L:?
the tensioner is
the 2.0L is 2 steps (quoted from FSM)
  1. Loosen tensioner by turning the tensioner pulley clockwise.
  2. While holding the tensioner, install belt.
there you go spoon fed, no asking to read the FSM.
hint2, the bolts are metric.
Jul 05, 2015 | 2006 Suzuki Aerio
I cant remove starter and need help
disconnect battery remove all wiring to the solenoid and remove 3 bolts that hold starter to bellhousing
Jun 22, 2015 | 2008 Suzuki SX4
Suzuki Baleno waggon clutch removing instructions
wow, no year stated ! a 12 year run.
1995-2002 (Japan)
1999-2007 (India)
the manual transmission clutch (not A/T TC or A/T internal clutches)
M/T stick clutch.
NO year stated, and not sold in USA (we are USA) hear, but is sold
here as an Esteem.
our car , has 2 engines, the G16 or the J18.
so servicing any clutch on any engine can vary by, engine, type.
but ill post the steps for your car.
alldata.com
or suzuki pit stop plus, both have FSM on Esteems.
out side USA they have these engines.
1.3 L G13B I4
1.5 L G15A I4
1.6 L G16B I4
1.8 L J18A I4
1.8 L BP-ZE I4
1.9 L XUD9 diesel I4
now the steps ,based on our car.
Ill spin the wheel of fortune, 1998
first is obvious, trans mission removal to reach said stick clutch
phase 1:
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Drain the transaxle oil.
  3. Remove or disconnect the following:
    • Battery cables (remove car battery first or NEG lug)
    • Battery and tray
    • Clutch cable adjusting nut, joint pin from the cable and cable from the bracket
    • All the wiring harness clamps and connectors involved with the transaxle removal, tag if necessary for location to aid during installation
    • Speedometer cable boot, case clip and cable from the case
    • Radiator outlet pipe from the transmission side cover, on Swift models
    • Transaxle retaining bolts
    • Starter
    • Fender apron extension on the left side
    • Bolts connecting the exhaust pipe to the exhaust manifold and disconnect the joint
  4. On Esteem models, with the engine supported, remove the vehicle center mounting member by removing the 7 nuts and 4 bolts.
    • Gearshift control shaft nut and bolt
    • Control shaft from the gearshift control shaft
    • Extension rod nut and washers
    • Clutch housing lower plate
    • Sway bar
    • Left and right front wheels
    • Left and right ball joints
    • Left and right halfshafts
    • Transaxle stiffener
    • Transmission to engine bolt and nut
    • Engine rear mounting bracket bolts
  5. Install an engine support.
  6. Support the transaxle with a suitable jack.
  7. Remove the left engine mounting bracket and stiffener.
  8. Lower the transaxle with the engine attached. Pull the transaxle straight out toward the left side.
  9. Lower and remove the transaxle.
phase 2: the clutch.
  2. Remove the transaxle.
  3. Hold the flywheel stationary.
  4. Matchmark the pressure plate and flywheel for installation reference.
  5. Loosen the pressure plate attaching bolts 1 turn at a time (evenly) until the spring pressure is released.
  6. Remove the clutch disc and pressure plate.
does this help.?
Feb 18, 2015 | Suzuki Cars & Trucks
Why wont my toyota carina 2 ltr. E start its always been so good but we had one hard frost and the next day it would not start with a jump but did start with a tow, the following day went to start it
Not familiar with your specific engine so some of this may not apply. Generally, sounds as if whatever acts as a choke on your engine has failed. Most common would be a coolant temp sensor, cold start injector, or very likely a moisture related issue, such as bad plug wires,cracked distributor cap, etc.
Dec 30, 2014 | Toyota Cars & Trucks
Replace the altinator in a2007 Suzuki reno
wow, you want super basic service questions. even placement.
what country
which engine, ?
1.4 L E-TEC I4 (petrol)
1.6 L E-TEC I4 (petrol)
1.8 L Family II I4 (petrol)
2.0 L Family II I4 (petrol)
2.0 L RA 420 I4 (diesel)
try reading the manual.
pull the battery negative lug first. or boom.
I will never tell you how to jack a car ,not me.... read a book first.
read the FSM pages on Safety.....
https://suzukipitstopplus.com/Products/1068-2007-forenza-reno-service-manual.aspx
the steps are the same on all cars.
only access to ALT varies.
all cars made.
  1. neg lug off
  2. gain access
  3. unbolt wires at alt
  4. release belt
  5. unbolt alt.
the FSM may tell you the best way to gain access.
no engine stated, so I pass on details.
Oct 08, 2014 | 2007 Suzuki Reno Hatchback
Replacing water pump 2004 forenza...bolts are out but pump is frozen in place and have tried loosening w/ mallet and tried to turn it in place won't budge...any tricks to get the darn thing to
which of 6 engines is it? we cant ever guess this. and nobody ever post that. oddly
FSM quote: 2.0L USA, only.
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Disconnect the negative battery cable.
  3. Drain the cooling system into a suitable container and tighten the drain plug.
  4. Remove or disconnect the following:
    • Timing belt
    • Timing belt tension roller retaining bolt
    • Water pump mounting bolts
    • Water pump from engine block
    • Ring seal from the water pump
id, place wood block on the front of head.
and pry the pulley to the front, hard,
or rad out? use slide hammer to the pulley, last resort.
what engine:????? note there are two, 2 liter engines.
Sep 29, 2014 | 2004 Suzuki Forenza
My screen went black
this is happens whit i4 i4s after you drop the phone . you have to solutions . one if you know a technician hes gonna put back the flex of LCD witch removed after the drop its very easy or gonna change LCD & digitizer .
if your phone is not 4 or 4s you have to change the lcd digityzer for sure .
Mar 02, 2014 | Apple iPhone 5c
Engine head removal
no year, stated, nor even the engine,,,, surely you know what you are working on>?
here is the list
1.3 L I4; 1.5 L I4; 1.6 L I4; 1.8 L I4; 2.0 L I4; 2.3 L I4; 1.4 L Diesel I4 and the answer is always in the FSM , contact suzuki get FSM book
and bingo, tell them which engine or it will be problematic.
Feb 09, 2014 | Suzuki Aerio Cars & Trucks
Remove peugeot 307 harmonic balancer
A Peugeot toyota. , is this an engine swap , question?
post to Peugeot forum?
no year stated. 307 is just a body, and means zero.
2001 to 2008? WHICH ENGINE??????
1.4 L ET3 I4 (petrol)
1.6 L TU5 I4 (petrol)
1.6 L DV6 HDi I4 (diesel)
2.0 L EW10 I4 (diesel)
2.0 L DW10 HDi I4 (diesel)
Jan 30, 2014 | 2005 Toyota Tundra SR5
Apple iPhone 3G Black  Smartphone Logo
47 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
